Go to Post Guess i don't know what the secret weapon is, but i bet if it can be wedge shaped it is. - Chris [more]
Unread 21-03-2007, 06:58
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
NBD help
OK before anyone says anything, YES, I searched.
I have been trying for some time now (when I have time) to get the dewalt transmission working on a CIM motor. I have followed the white paper, exactly and have the parts made to spec as described in the whitepaper. There is only one small problem. I noticed a little clicking noise while it was running, so I took it apart and tryed to figure it out. So I put it back together with just the 2nd stage in and the click was still there. So I know is is somewhere between the motor and the second stage. I just cant figure out where. I am thinking it may be the clearences. Has anybody else had this problem before?
Sine I don't have a press in my basement(to test this theory), but could the pressed stage on the motor shaft be too far away fromt he motor?
**Other then this little noise it works fine, I just know the moise means something isn't working like it should, and I am a perfectionist when it comes to these things.
-John
Unread 21-03-2007, 08:38
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: NBD help
We had a small problem withe the motor shaft and the gear pressed on it bottoming out in the transmission. All we did was grind it down a little bit.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 21-03-2007, 10:16
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Re: NBD help
John call me and I think I can help. Our team uses the NBD system ( Our team developed it - Joe Johnson). I will send you a pm with my phone number.
Right off the distance the carrier gear (we call it the Hat) is pressed on is critical and the backing plate is important - many teams leave this off.
Mike Martus
Grab Frame - Help Help Help... nmihailidis Programming 2 04-03-2007 14:44
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
NBD: A Shameless Plug... Joe Johnson General Forum 0 02-01-2005 14:55
