Go to Post ...when the rack starts swaying you start praying! - Wayne C. [more]
  #91   Spotlight this post!
Unread 21-03-2007, 15:46
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Team Update #18
Originally Posted by Brandon Holley View Post
What you stated right there is exactly what people are trying to say here.
This is not my opinion but here is what others are trying to get across..
You put 6 weeks into creating a magnificent robot that can score a few ringers and can lift 2 of your partners off the ground 4 inches.
You can score 30+ points every match...
This wooden box can now score 30 pts every match by doing NOTHING. Yes it is unfortunate that they were unable to secure enough help to make a more competitive machine, but they need to learn eventually.
What others are trying to express here is that this shouldnt be a strategy because it rewards teams that may not deserve it as much as others.
Excellent point and I see both sides but I have to respectfully argue that everyone puts in 6 weeks of hard work and whether the result is "a magnificent robot that can score a few ringers and can lift 2 of your partners off the ground 4 inches" or a "wood box bot" often has less to do with how much time was spent on the robot and more to do with other resources the teams have at their disposal. Neither team is more or less deserving of the 30 points simply based on how their robot looks. Keep in mind that that wood box bot may be your opponent this match and then you both score 30 points or maybe you win by a few ringer points but you are better off because you have now increased your RP. However, they may be your partner in the next match and you are going up against a robot "that can score a few ringers and can lift 2 of your partners off the ground 12 inches" for 60+ points in every match so you may be glad to have that 30 point wood box bot rather than a wood box.
  #92   Spotlight this post!
Unread 21-03-2007, 22:23
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Team Update #18
Originally Posted by Liz Smith View Post
I also don't think this is really "flip flopping" on FIRST's part. The relevent Q&A response only pointed out that there was no rule against it. Now there is a rule against it.
Liz,
There is currently no rule against using sprockets, gears, COTS transmissions, etc. Specifically in the Q&As, the GDC has said:
There is no rule limiting the number of spike relays
There is no rule against using IR LEDs on the OI
The set containing all rules for a given season is far, far smaller than the set of all rules not for a given season. Do you think it would be right for the GDC to then, in the middle of the competition season, declare a rule that outlaws sprockets, gears, or COTS transmissions? Limits the number of spikes you may use to 3? Outlaw your nifty IR OI system? Outlaws the use of black paint? Decrees that sans serif fonts are unacceptable for robot team numbers? Mandates that 2 wheel robots suck and won't pass inspection?
Just because there wasn't a rule against something shouldn't give the GDC license to make up a rule that could seriously impact a team's robot and strategy in the middle of the competition season 5+ weeks after a teams has finished building their robot.
  #93   Spotlight this post!
Unread 21-03-2007, 23:01
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Team Update #18
Originally Posted by DeepWater View Post
Yesterday that wood box was worth 30 points. Unfortunately, today it is just a wood box.
That's where you are mistaken. Given the right circumstances, it can still be worth 30 points. There is no rule that says an alliance partner can't push little 'ol boxy up another partners ramp. In fact, I've seen several teams help each other up ramps, I'm sure we all have. Why not set up boxy in the home zone next to where the ramps/platforms will be deployed so he can be pushed up before the end of a match? Sure, it'll take a few more seconds, but it'll be worth 30 points.
A somewhat similar display of teamwork can be found in this thread:
http://www.chiefdelphi.com/media/photos/27817
  #94   Spotlight this post!
Unread 21-03-2007, 23:16
Re: Team Update #18
I believe, according to the rules, that they would still recieve 30 points if touching a ringer. They just can't be supported by that ringer.
Definition of supported from the 2007 manual? There's a YMTC about that one.
  #95   Spotlight this post!
Unread 21-03-2007, 23:29
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Re: Team Update #18
Originally Posted by Kevin Sevcik View Post
... Just because there wasn't a rule against something shouldn't give the GDC license to make up a rule that could seriously impact a team's robot and strategy in the middle of the competition season 5+ weeks after a teams has finished building their robot.
C'mon Kevin ... There is NO WAY this rule has seriously impacted any team's strategy ...
It is clear that the intent of the game is for the bonus points to be scored by the action of the robots, not by humans stacking them before the match begins.
IMO this rule change is mostly benign, and only serves to preserve the "intent" of the game.
Most here are upset only because their feathers were first ruffled by the TU#16 fiasco. I would agree that was a serious mistake by FIRST which would have had a devastating impact on many teams ... but fortunately has now also been corrected.
We should all let this go, and MOVE ON ...
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
  #96   Spotlight this post!
Unread 21-03-2007, 23:55
Re: Team Update #18
190 said they were considering this and only passed on complication issues. I submit that there aren't 1000+ teams represented in this thread so we don't actually know if this has affected someone. However, this is beside the point. Saying it's okay for the GDC to change rules and make up rules mid competition to "preserve the intent of the game" invites bad things. What if the GDC hadn't outlawed tube herding and then decided that wasn't how they wanted the game to be played? I submit that it is NOT the GDC's perogative to define the way the game can be played during the build season and then change the way the game can be played after the build season. Teams at GLR were highly upset that a ref changed the way the game was played to "preserve the intent of the game". Why is it somehow okay for the GDC to do this? I'm honestly confused how one is significantly different from the other, except that this affects a much smaller, much much less represented portion of teams. I do understand that this is unlikely to affect more than a few teams, but I remain unconvinced that that makes it okay.
  #97   Spotlight this post!
Unread 22-03-2007, 00:19
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Re: Team Update #18
IMO... if all you have is the "wooden box" then you need to rethink even coming to the field. Your pride in yourself should keep your dead bot off the field.
I agree with this rule change!
To the builders of the "wooden box" well think of it as a learning experience.
Just cause you drive a car don't mean your ready for NASCAR.
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
  #98   Spotlight this post!
Unread 22-03-2007, 00:49
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Re: Team Update #18
Yeah, yeah... I've seen the YMTC. Poor choice in phrasing on my part. What I meant to say was, just because it is in contact with a game piece, wouldn't necessarily negate the end game bonus.
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
  #99   Spotlight this post!
Unread 22-03-2007, 00:58
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Team Update #18
Sometimes, you need to swallow your pride and do what's best for your teammates.
Nothing frustrates me more than when a team has simply accepted that their robot is broken or doesn't work well and makes no more effort toward improving it. There are people at these events who're relying on you and have some expectation that you'll do everything that you can to field a robot -- and when you've done all that you can, you ought to go find someone else who can do more.
--Madison--
...down at the Ozdust!
  #100   Spotlight this post!
Unread 22-03-2007, 07:25
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Team Update #18
There is no rule against having tube manipulators either. So you are saying it would be OK for the GDC next week to outlaw those? And ramps the week after?
The GDC is setting a dangerous precident here by stating in the Q&A that there is no rule against it (therefore tacidly accepting the strategy) and then outlawing it 3 weeks into the competition AFTER a team successfully used the strategy.
Personally, I think Wildsatg and their alliance partners should share the Xerox creativity award for useing such a unorthodox strategy successfully.
But thats JMHO.
___________________
- Tennyson, Ulysses
  #101   Spotlight this post!
Unread 22-03-2007, 07:59
Re: Team Update #18
IMO... if all you have is the "wooden box" then you need to rethink even coming to the field. Your pride in yourself should keep your dead bot off the field. ...
This should only be considered after all other options have been exhausted. There should never be any distinction based on robot design that should keep a robot from taking the field. Every team should make it one of their top priorities to make sure every team can play and have an enjoyable weekend. That goes double for rookies. An event should be a learning experience coupled with fun or this won't work. We must say to ourselves "leaving a robot in the pit is not an option".
One thing that the GDC has designed into the game is the ability for any robot design to have a function in this game. Whether it be purely defensive, purely offensive or a full up, does everything, robot. No robot can win alone for the majority of the matches. The GDC has made a good game for all robots and human players alike, and I think we have to applaud them on this account. Once the game is chosen, modifying it for all of these factors is the real challenge.
  #102   Spotlight this post!
Unread 22-03-2007, 08:43
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: Team Update #18
Whats next?
[SARCASM]
Team Update # 19: No defense allowed. You must get out of anyone's way to let them score. The game isn't going how we wanted it, so we are changing things half way through so people will play the game the way we want.
[/SARCASM]
Oh, wait, that almost happened in 2005.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
  #103   Spotlight this post!
Unread 22-03-2007, 08:46
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Team Update #18
Most probably true.
Then why didn't they preserve this intent of the game back in January when the question was asked?
You're right. Without the uproar from a couple weeks ago, this would be only a small tempest in a teacup.
Unfortunately, if we just move on, it will be business as usual. Others have pointed out absurd rulings that the GDC could make at any time - and I don't believe they ever would make such rulings. The point is that they can, any time they want. And issue it without any explanation except, "Because I said so."
Rules can be tweaked to make them consistent with other rules. Updates can be issued for important issues - Banebots, IFI radio. Teams can be reminded of best-practice issues, such as how your ramp contacts the floor in Update 11, which didn't change a rule but amplified the existing rule. They can correct obvious misprints (parts lists) or unclear wording (ringer direction through the chute). Even in the first half of build season, I'd be accepting of a new rule that changes game strategy or robot build, due to an oversight that created a huge loophole.
The argument everyone is having is that FIRST is making these arbitrary decisions so late in the season. FIRST isn't big enough to be a bureaucracy - why do they act like one?
(since 2004)
  #104   Spotlight this post!
Unread 22-03-2007, 09:41
Stu Bloom's Avatar
Re: Team Update #18
Most probably true.
I can't argue with that logic, however I feel that was the mistake ... TU#18 is how it was fixed.
Remember, it is explicitly stated that the Q&A is NOT official. I will concede there is a problem with that since all answers are signed "GDC". I fully agree with those who would ask what good the Q&A system is if the teams can't rely on the GDC answers. But that is a completely separate issue.
Unfortunately, as with many situations in life, that is entirely true. The only real recourse we have is to pack up our toys and go home. I prefer to play ...
We can debate "principle" and offer "what-if's" all day long. I know that any decision to publish a rules change is NOT taken lightly by the GDC. These are NOT "arbitrary" changes ... Every imaginable scenario is discussed and hashed out in an attempt to understand the full impact of the proposed change. The problem is, as Dave has stated numerous times (paraphrased), it's 10 brains (defining the game) vs. 30,000 (dissecting it for "loopholes") ... and 30,000 will always win ...
I often think I would like to be part of the GDC ... but then something like this comes along and I see how ungrateful some people are. I believe most of us share a real passion for this program ... for the RIGHT REASONS. Let's keep the big picture in focus and not forget why we are all here.
Stuart Bloom
Mechanical Engineer
  #105   Spotlight this post!
Unread 22-03-2007, 09:42
Liz Smith's Avatar
believes in robots
AKA: Pika1579
FRC #3940
Re: Team Update #18
There is currently no rule against using sprockets, gears, COTS transmissions, etc. ...Just because there wasn't a rule against something shouldn't give the GDC license to make up a rule that could seriously impact a team's robot and strategy in the middle of the competition season 5+ weeks after a teams has finished building their robot.
But thats JMHO.
Ok, in my opinion (emphasis on the opinion part... don't hurt me), I believe the main difference between these counter examples, and the issue at hand is that this update in all likeliness is not going to affect any team's main strategy. Outlawing manipulators? Over 1/2 the teams would be out of commission.. same goes for the other examples.
I understand that the timing of this update seems a little 'after the fact', but once again, I really don't think it will affect the game play very much. I'm pretty sure the GDC is not out to get you.. they just want to make sure the game is fair and interesting for you, the players and also the spectators.
I applaud Wildstang for their creativity, and any other team that attempted this strategy, but I do not thing that outlawing it will seriously impact any team's personal strategy. Hopefully they will not be stuck in a similar position again, and if they are, perhaps they will come up with an equally creative solution.
AndyMark, Inc.
Team Update 17 ntroup General Forum 33 14-03-2007 16:58
Team Update #3 dez250 General Forum 4 21-01-2004 11:56
Team Update 19! Vincent Chan General Forum 3 26-02-2003 20:51
Team Update 18 Steven Carmain General Forum 10 25-02-2003 23:29
Team Update # 2 Brett W General Forum 1 09-01-2003 20:47
