Go to Post I've learned that the measure of success isn't the money you make, the education you get, or the car you drive. Your success can only be measured in the amount of people in whose lives you've made a difference and the size of your heart. - Amanda Morrison [more]
Unread 20-03-2007, 20:21
Kelly Kelly is offline
FRC #1418
Kelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud of
Re: How to lose 6 pounds in 8 hours
Two years in a row our team has made the mistake of weighing our robot with the scale on carpet, which makes the weight seem significantly lower than it really is, until it finally occurs to us that our robot looks way heavier than the scales says and discover the problem. By this time it's usually hours before ship and we're scrapping major components.
Unread 20-03-2007, 20:55
Billfred's Avatar
Billfred Billfred is online now
Last season with 1293, we started Palmetto about four pounds overweight. We went to two pounds underweight in one day with a few changes.
Anybody familiar with 1293 is familiar with the team's love for 1/8" aluminum. The hopper that year used a lot of it, so we initially cut large holes in it and filled those holes with garden mesh riveted in place (and painted, natch). When that didn't cut it, we took a slugbuster (a hydraulic device for putting round holes in things, in this case with a little hand pump) to it. Ultimately, we had the hopper remade in a Fix-It Window using thin-gauge stainless steel, which we then re-swiss-cheesed. The end result was plenty durable (even for blocking shots--sorry, 1676), but far lighter.
Similarly, we could've fabricated a lot of things differently with 1618's robot this year. Paper is a terribly underrated material--we're using it for our graphics, with a few extra numbers printed up as spares. On the arm, the numbers are backed by a piece of cardboard. Sure, it might not be particularly heavy-duty--but it'll hold, and replacements are cheap and plentiful. Similarly, we picked pegboard over metal for our electronics and pneumatics panels--they're cheap, easy to mount to, and light as beans. If we needed to drop weight (which we don't--ten pounds under FTW!), we can get it cut with nearly anything.
Oh, and don't count out the kit wheels either--they're nice and light, and are roughtopped with relative ease.
And, if worst comes to worst, never be afraid to ask around for advice. Odds are that someone at the event will have some tool or part that will knock a pound or two off.
Unread 20-03-2007, 21:14
wingnut1705's Avatar
wingnut1705 wingnut1705 is offline
AKA: Kevin
FRC #0453 (Gears)
wingnut1705 is an unknown quantity at this point
Send a message via AIM to wingnut1705
On the shipping date 10min before the FEDEX guy came we weight our robot and found that we were 10lbs overweight. As it turned out the scale that we used was very shoddy and we were actually 5lbs under. As an example of the shoddiness of the scale, I could change my own weight 25lbs up or down.
Unread 20-03-2007, 21:28
CraigHickman
Posts: n/a
We found our team weight to be exactly out team number: 114 pounds. It was entirely accidental, and pretty awesome.
Unread 20-03-2007, 21:30
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
The most important lesson is that every team should buy a scale. They come in handy more than you can imagine. No need to cut 6 pounds at competition, you can weigh everything as it goes on the robot and weigh the robot at different points.
Buy a scale.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 20-03-2007, 21:34
robotguru1717's Avatar
robotguru1717 robotguru1717 is offline
AKA: Martin Cacan
FRC #1717 (D'Penguineers)
robotguru1717 will become famous soon enoughrobotguru1717 will become famous soon enough
We were 1 pound over weight and so we took the chains off that ran to the front two wheels of our 6-wheel drive robot. #35 chain is heavy and taking it out can save u if u need it. then u can take out holes and bring the chain back onto the robot.
-Martin
Quote of 2007: "That nub looks cattywampus" -Amir Abo-Shaeer
(fyi there were about 50 nubs on the robot)
Team 1717: D'Penguineers
2008: LA-Regional Winner
2008: SD-Regional Winner
2008: SD-Delphi "Driving Tomorrow's Technology" Award
2007: LA-Semi Finalist
2007: SD-Finalist
2007: SD-Imagery Award
2006: Phoenix Semi-Finalist
2006: Phoenix Regional-Rookie Inspiration Award
2006: LA-Rookie All-Star Award
Unread 20-03-2007, 21:40
DonRotolo's Avatar
Back to humble
FRC #0832
We lust after that hydraulic slugbuster, it is SOOO Cool! One of our parents this year donated a set of greenlee punches, so we're halfway there...
This year, we had to remove two of the four clippard tanks to save nearly 2 pounds. Oh, and about 2 pounds of excess armor (we let the bumpers do the work).
At one point, we were seriously considering drilling out the center of fasteners.
On a more serious side, there is a process by which a team can triage what is essential and what can go. List and prioritize all of your tasks. Start with your least important quality (ours was 'score on the middle rack') and remove that feature. Keep removing the least important feature until you make weight.
This, of course, only after all non-essential parts are removed, and holes are placed in anything that doesn't need the structural strength. For example, in 2005 we saves 1/2 pound per wheel by drilling holes in the (heavy rubber) treads.
Don
Unread 20-03-2007, 21:44
Adamskiy's Avatar
Adamskiy Adamskiy is offline
Team Founder
AKA: Brandon Adams
FRC #1261 (RoboLions)
Adamskiy is on a distinguished road
We were actually underweight this year, not sure by how much, and didn't even specifically design it that way. Two years ago I remember us the weekend before shipping drilling holes in all of our sprockets. We seriously must have drilled out nearly half of the weight of each sprocket....and it was done in a symmetrical pattern, so they actually looked pretty cool afterwards
Team 1261 - Motorola/Cognex/EMD Software & Peachtree Ridge High School
- 2005 Peachtree Regional Champions
(Thanks 281 and 801)
- 2006 Peachtree Regional Champions (Thanks 1414 and 1057)
- 2006 Peachtree Regional Delphi "Driving Tomorrow's Technology" Award
- 2006 Peachtree Regional Underwriters Laboratories Safety Award
- 2007 Peachtree Regional Innovation In Control Award
(Guitar Hero controller )
- 2007 Peachtree Regional Semi-Finalists (Thanks 1746 and 1057)
Unread 21-03-2007, 00:25
dtape's Avatar
dtape dtape is offline
AKA: Jeff
FRC #0467 (The Duct Tape Bandits)
dtape will become famous soon enoughdtape will become famous soon enough
can beat that.
a scale said that one of my teammates (who weighs about 150) weighed about -4 pounds with his back pack on. (and yes, the scale was calibrated and on tile)
Unread 21-03-2007, 17:06
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
yeah GRR had two robots, one ~10lbs under and the other one ~1-2 lbs over our weight class. besides swiss cheesing The programing team had to have more 0's than 1's in the code
on a more serious note:
drill holes in places like under the rc and speed controllers if it really comes down to it. Do not punch any holes in a part of the frame that bears any weight or is a support.
If possible replace any lexan/polycarbonate with a thinner sheet. if you can replace 1/8 with 1/16 it still should hold up fine.
If you guys have a camera on board and aren't using it take all wires, hardware, "perches" off for us that claimed about 1.5 lbs.
Also, if you have a compressor or pneumatics check to see if you can get away with having four tanks instead of having the compressor on board(~5-6 lbs). If you just can't part with your compressor then consider taking a tank off(~1lbs).
Unread 21-03-2007, 17:18
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
adjust your arm so your robot's starting posision is shorter than 48 inches.
therefore, your not breaking the rules.
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
Unread 21-03-2007, 17:21
Pirate_Nelly354's Avatar
Pirate_Nelly354 Pirate_Nelly354 is offline
FRC #0333 (Megalodons)
Pirate_Nelly354 is a jewel in the roughPirate_Nelly354 is a jewel in the roughPirate_Nelly354 is a jewel in the roughPirate_Nelly354 is a jewel in the rough
Our robot's name last year was Swiss Cheese.
A well deserved name
That robot was a monster!
To lose a lot of weight we drilled holes practically everywhere.
Total number of holes: 1299
2005-2013 Team 354 - G-House Pirates
2014- ? Team 333 - Megalodons
Unread 21-03-2007, 19:00
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
-Cheese the Bot
-Take off excess chain (large serpentine designs where a short, simple system will do = no good)
-Calculate the weight before
-Search CD for the other "weight loss" thread that's something like 20 pages long... lots of good information there.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 21-03-2007, 19:13
Frinkahedron Frinkahedron is offline
Wants to go sledding
AKA: Mark Umansky
FRC #0612 (Chantilly Robotics)
Frinkahedron is on a distinguished road
Send a message via AIM to Frinkahedron
Use aluminum bolts instead of steel ones
All those little nuts and bolts can add up to a pound or two.
(612 actually came in a pound under at both VCU and Chesapeake this year)
Hokie Hokie Hokie Hi
Tech Tech VPI!
Unread 21-03-2007, 20:05
1359th Scalawag's Avatar
1359th Scalawag 1359th Scalawag is offline
AKA: Eric
FRC #1359 (The Scalawags)
Team Role: Marketing
1359th Scalawag is just really nice1359th Scalawag is just really nice1359th Scalawag is just really nice1359th Scalawag is just really nice
You wouldn't believe it, this years robot for us came in about 2 to 3 pounds overweight. We eventually drilled holes in the ramp and came in around .2 pounds overweight. We actually had to remove the pink bolt that we place on the robot for one of our mentors. How in the world did we make it so precisely that to lower the weight we had to remove a bolt?!
After that it was about 119.9lbs. Strange year for us.
How to lose that extra weight (Was: Major Help!!) dagger Technical Discussion 16 14-02-2006 00:26
How many hours? Jeff Sharpe General Forum 29 29-01-2003 23:15
15 pounds not easy archiver 2000 0 23-06-2002 23:14
