Team 16's Autonomous (Bomb Squad)
Hello everybody,
Click HERE for a video of our autonomous. Instead of using a camera this year, we're using ultrasonic sensors. Some pictures if you're interested... http://farm1.static.flickr.com/172/4...6a7e48.jpg?v=0 http://farm1.static.flickr.com/145/4...6a7e48.jpg?v=0 Thanks. |
Re: Team 16's Autonomous (Bomb Squad)
NEW! EXCITING!
Hah, actually, that's really cool |
I recognize those MaxBotix sonar sensors. We haven't yet attempted to put them on the robot, but we did do a bit of testing with them. I saw your robot via webcast in KC - it looks like the robot came close to scoring several times in autonomous. Do you get false range readings that cause the robot to lose lock on the spider feet?
I'll try to catch webcasts from Lone Star Regional, otherwise see you in Atlanta. Good luck and good "hunting". (Yeah, I'm Clayton's Dad...) |
woa nice omni wheels?
Nice! I'm looking forward to seeing ya'll at Lone Star.
#7
That's very cool. We had routines worked out with sonar, but the camera worked so well we didn;t use it.
The fact you can go sideways works well with the sonar. |
#9
WC ![]() Last edited by Wayne C. : 21-03-2007 at 20:19. |
#10
I am actually the head student programmer on the robot.
We have two sensors on the base of the robot, they are bouncing off of the lower flat vertical piece below the spider legs. They dont use a diode, we simply have code that fires them at seperate times so not to catch each other. Occasionally they will catch one of the poles, but we are working on a solution on that. The two sensors on the bottom get us lined up on the leg and then a third sensor on the arm itself tells the robot if a leg is in front of it. If it is, then it drops it, if not then it tries to circle the rack. I dont have the pwm numbers right for the circle so it doesnt really work yet. Watch out for us at Lone Star... I should have most of the problems fixed after Thursday. Last edited by Ryan C. : 21-03-2007 at 20:25. |
| pic: Team 16 Bomb Squad 06' | SnareDrummer37 | Extra Discussion | 10 | 04-04-2006 15:08 |
| Bomb Squad Brawl | Clell Chatman | Off-Season Events | 2 | 20-04-2004 18:41 |
| Image Discuss: Baxter Bomb Squad Team Picture | CD47-Bot | Robot Showcase | 21 | 23-02-2003 21:53 |
| baxter bomb squad-16 | robomama | Championship Event | 5 | 29-04-2002 20:44 |
| Thanks to team 16 Baxter Bomb Squad | Gene F | Thanks and/or Congrats | 1 | 07-04-2002 00:36 |
