Go to Post The only odd part about this competition is that rather than further convince me that I want to be an engineer, it did the converse... I want to be a teacher. - pauluffel [more]
Unread 21-03-2007, 22:41
youngWilliam14's Avatar
youngWilliam14 youngWilliam14 is offline
Team 461 Electrician and Operator
AKA: Will Crabtree
Team Role: Electrical
youngWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud of
Send a message via AIM to youngWilliam14
Exclamation i need help w/ setting up a palm pilot for dashboard
ok, here's the deal. i need some help finding a dashboard program to put on a palmOne "Zire31" palm pilot. also, i can only use one kind of cable end to connect it to the port, so i need a usb converter or somthing. if you can tell me where to get an adaptor, or can give me a diagram to make one, that would be great.
the end i need to plug into my palm pilot is in the pic
thank you!
-Will Crabtree
WBI--Team 461
"C.N.C." lyrics/"Driving on Regolith" lyrics
Let's all go nuts! Robots! Robots!--Team 461 chant
Unread 21-03-2007, 22:58
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: i need help w/ setting up a palm pilot for dashboard
Find a male to male, USB Mini to USB cable. That's what that connector is, btw -- USB Mini. I have no idea where to find one, though.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 21-03-2007, 23:14
So far as I know, the Zire 31 doesn't have a serial port you can get to. It's strictly a USB peripheral device. An older serial-connected Palm (III series, for example) would work, as would one of the newish ones with a "universal" connector (e.g. Zire 71), but I don't think what you have can do what you want it to.
Unread 22-03-2007, 00:22
Otaku's Avatar
AKA: Michael Baker
Originally Posted by Alan Anderson View Post
So far as I know, the Zire 31 doesn't have a serial port you can get to. It's strictly a USB peripheral device. An older serial-connected Palm (III series, for example) would work, as would one of the newish ones with a "univeral" connector (e.g. Zire 71), but I don't think what you have can do what you want it to.
You can buy or even make a Serial to USB converter. While I don't have a link on hand, I'm sure a quick Google search would show you all you need to know.
Unread 22-03-2007, 06:42
Not the kind young William needs.
A USB to Serial converter is not a problem, but what's required here is a converter in the other direction. The Zire 31 is not a USB master.
Unread 22-03-2007, 07:16
AKA: Will Crabtree
i have the cable, i just need a program and adaptor. would the chicklet work, or is it illegal to put the chicklet on the dashboard port?
Unread 22-03-2007, 07:30
Suitably programmed, the Chicklet hardware could at least connect to and communicate with the Zire. However, it doesn't have any way of connecting to the OI's Dashboard port.
You've chosen a particular handheld device that is just not suitable for the application. Depending on how urgent your need is, you might consider buying a used Palm III and serial cable, or just going with a small laptop PC.
Unread 01-04-2007, 07:12
AKA: Will Crabtree
ok, so i found a diagram to convert a usb cable to a 9-pin connector: http://pinouts.ru/Converters/usb_ser...r_pinout.shtml
if anyone knows where i can get a program for my palm pilot, you would be one of the most awesome people in the world. but if no one knows where i can find one, i'll just bug my team's programmers to make one
thanks!
Unread 01-04-2007, 11:25
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Even if you could build that cable the Zire31 would not be able to use it. You need to find a device that has native serial support.
Eric Haskins KC9JVH
Unread 01-04-2007, 12:16
AKA: Will Crabtree
i've been able to trick a few devices into thinking that they're getting data from something they're supposed to get data from, so who knows how this one will work. i'm sure that there is/our programmers can cook something up that will make the palm read off data from the O/I
Unread 01-04-2007, 12:44
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
I don't want to step on your dreams, but let me try to reiterate what Alan was trying to say. Apparently (I'll trust the engineer on this one) the device you're using is a USB client, not a USB host. You can read up on how USB works on Wikipedia, but I'll try to explain anyway. Computers are USB hosts... they can accept USB devices, and communicate with them. USB clients (like printers and Flash drives) can also communicate, but they require the presence of a USB host to do so. It's not uncommon for a computing device to not act as a host... the Gumstix mini computer does the same. So, before you spend a lot of money and time on this project, you might want to do some research to see if your device can host USB peripherals (such as a USB to serial adapter), because Alan seems to think that it won't. If that's the case, it is a limitation of the hardware that programmers won't be able to overcome.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 01-04-2007, 12:48
Chris Marra's Avatar
Chris Marra Chris Marra is offline
The Blue Alliance Staff / 177 Alum
no team (TBA / Bobcat Robotics)
Chris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond repute
Such an endeavor would require very low-level programming though, as any program written for the Palm would look for USB data through the port by calling up the Palm API for USB communication. You would have to specifically write a dashboard program that undermines the Palm OS and gains direct access to what bits/packets are being passed through the 9 pins. At this point, many devices fit the application much better for the amount of programming required.
We have several Palm III's lying around that we used to use for pit scouting, and they have serial interfaces (we use them to control winamp through such), and have tried using them as dashboards, but never felt like doing the programming when we could just use a laptop. As Alan said, it is much easier to just use a laptop or an older Palm model for a dashboard application, and considering the rules against interacting with your dashboard, it actually makes more sense to use a laptop that has a much larger screen so information is visible.
Team 177 - Bobcat Robotics
Unread 01-04-2007, 16:11
That page describes something which lets a USB host talk to an RS-232 serial device. The Zire 31 does not, and can not, act as a USB host. You're trying to do the equivalent of using a table lamp to run a portable CD player. With the proper wiring you can connect them, but since the lamp does not supply power it won't work. In your case, since the Zire does not provide USB bus mastering, it won't work.
Many other Palm devices can talk to a serial port without putting another computer in the loop, but the Zire 31 cannot.
If you want a long-term project, you might have fun making a little box with RS-232 on one side, a simple processor in the middle, and IRDA/IRCOMM on the other. Then any Palm with infrared (that's basically all of them), and many Pocket PC devices, should be able to talk with the dashboard port through it. But I stress that it'll be a long-term project, not suitable for this year's competition season.
I need help setting up BuddyB309 3D Animation and Competition 6 19-09-2005 22:43
Palm Pilot evulish Chit-Chat 0 22-09-2004 22:27
Palm Pilot Software GregTheGreat Programming 7 14-07-2003 22:20
Need help setting up phpBB on a coolfreepages.com website LBK Rules Website Design/Showcase 5 30-03-2003 20:02
Score Keeping Program For Palm Pilot GRR_340 General Forum 0 17-02-2003 14:54
