Re: Bane Bot replacement gears?
I agree, it sounds like you are using the transmissions past the (unspecified by Banebots) design parameters.
256:1 reduction gives a LOT of torque, if you load the transmission too much, something has to give. These little transmissions just are not big enough to handle that much torque. Is there any way you can reduce the load on the gearboxes? maybe add some type of counterbalance, or spring, or gas spring, or surgical tubing, or something? |
| Anyone Not Using Their 56mm Bane Bot Gearbox? | fhsteam613 | Motors | 3 | 22-02-2007 12:59 |
| Mini-bike motor on the bane bots gear box | free_rider_151 | Technical Discussion | 2 | 12-01-2007 21:17 |
| Replacement for Bevel Gears? | Greg | Technical Discussion | 3 | 30-03-2003 19:56 |
| replacement gears | joni_m | Technical Discussion | 1 | 22-01-2002 18:01 |
