Go to Post Robots can be fixed, glory is forever - Brandon Holley [more]
Unread 22-03-2007, 22:16
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
Re: Bane Bot replacement gears?
Originally Posted by squirrel View Post
I agree, it sounds like you are using the transmissions past the (unspecified by Banebots) design parameters.
256:1 reduction gives a LOT of torque, if you load the transmission too much, something has to give. These little transmissions just are not big enough to handle that much torque.
Is there any way you can reduce the load on the gearboxes? maybe add some type of counterbalance, or spring, or gas spring, or surgical tubing, or something?
We are currently working on adding a gas spring to reduce the load
Anyone Not Using Their 56mm Bane Bot Gearbox? fhsteam613 Motors 3 22-02-2007 12:59
Mini-bike motor on the bane bots gear box free_rider_151 Technical Discussion 2 12-01-2007 21:17
Replacement for Bevel Gears? Greg Technical Discussion 3 30-03-2003 19:56
replacement gears joni_m Technical Discussion 1 22-01-2002 18:01
