Go to Post Let's see. There's the Dean of Students, the Dean of Admissions, The Dean of Engineering, and the Dean of Kamen? Sometimes known as the Denim Dean. - Bill_B [more]
Unread 22-03-2007, 22:25
Lifelessimp Lifelessimp is offline
FRC #0192 (GRT)
Lifelessimp has a spectacular aura aboutLifelessimp has a spectacular aura about
Re: Rough Play in Rack N Roll
On the subject of tipping, I feel that as long as the hit is in the bumper zone, it is ok. If a team builds a robot that is prone to tipping, then that is a problem with their robot.
There are a lot of variables that teams have to think about when building a robot, and building something robust should definitely be a large consideration. If you go outside of your footprint with an arm, and the arm gets hit, you shouldn't complain about it. Last year, our team was penalized when other robots hit our hopper when it was extended outside of our footprint. So, a big consideration went into our robot design this year to stay within our footprint as much as possible.
Unread 23-03-2007, 00:12
clean399's Avatar
clean399 clean399 is offline
Mr. Clean
AKA: Nick Hayes
FRC #0399 (Eagle Robotics)
clean399 is a jewel in the roughclean399 is a jewel in the roughclean399 is a jewel in the rough
Send a message via AIM to clean399
I totally agree with this I have had this happen where we were the pushing robot and I didn't realize how high the cg was on the other robot and they fell over. My contact would not have caused it if it was just bumping with a lower cg robot. The drivers should not be held responsible in occasions like these because they don't know how high the cg is on the other robot.
Unread 23-03-2007, 09:26
GaryVoshol's Avatar
Cogito ergo arbitro
Both points are true. However, if you see your opponent teetering, you would be well-advised to back off, even from bumper-zone contact. If you continue to bump against a wobbly robot, your bot could be the reason that it finally went over, and then you could be charged with tipping. It will all depend on what the ref saw each of your bots doing.
(since 2004)
Week 1 Impressions of Rack 'N Roll Pavan Dave General Forum 103 12-03-2007 15:38
Human Rack N Roll wendymom General Forum 12 03-02-2007 14:28
Team 40 invites you to play Rack n Roll using Vex kits! Jessica Boucher General Forum 13 22-01-2007 16:07
RACK & ROLL Reaction Greg Perkins General Forum 219 10-01-2007 22:48
Rack n Roll Animation Joe Matt General Forum 1 06-01-2007 14:28
