Go to Post But when it comes down to it, the best teams usually end up winning regardless. - Cory [more]
Unread 22-03-2007, 23:07
Bharat Nain's Avatar
Re: Team 25 elevator
Originally Posted by Calvin_1631 View Post
Now, are you using a timing belt, or just a regular belt. And is there any advantage of using a belt over a cable? Also, how you do achieve a fast descent of the elevator, if the motor only pulls it up? Surgical tubing?
We are using a timing belt. I don't know about the advantages of disadvantages of going with timing belt over cable, but we felt like trying a timing belt system because we made a cable system in 2005. The timing belt system is designed such that the motor can pull it down also. Because of needle-bearing pulleys and precise machining of the mast there is very less friction involved so gravity does do some of our work in bringing the elevator down. Surgical tubing was used to keep the gripper from swaying left and right violently during a match.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Wiring an Elevator Joe G. Technical Discussion 8 16-02-2007 00:15
Elevator Trouble: The Marta Ben Lauer Championship Event 26 29-04-2004 20:06
1418's Elevator Party? phrontist Chit-Chat 0 26-04-2004 03:03
Space Elevator Ian W. Chit-Chat 28 31-07-2002 14:04
Combined Pneumatic Wonderpaloozistic SeeThrough Elevator archiver 2001 0 23-06-2002 22:18
