Go to Post We put our alumni to work. That either benefits all or drives them out for good. :) - Wayne C. [more]
  #46   Spotlight this post!
Unread 23-03-2007, 07:46
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Autonomous Target Tracking at Regionals
If you are using Kevin's code - you can also lower the required confidence requirement or you can increase the delay after each camera search increment.
You can also use his newest code for the 0-90 degree mapping of the full 255 pwm range for increased accuracy - though we didn't use it at the Detroit regional.
On thing I hope many teams considered is that using degrees is very inefficient. Use the straight PWM values so you don't have to do any floating point or lose any accuracy through integer math. You can go further than that too if you limit where you want to lock your camera so you only use about a 45 degree range - tracking with the camara isn't necessary if you've got a gyro and geartooth encoders, you simply need your initial angle and distance.
  #47   Spotlight this post!
Unread 23-03-2007, 08:49
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
you still need the camera because they spin the rack..
  #48   Spotlight this post!
Unread 23-03-2007, 12:35
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
I think he meant you just need the camera to tell you where the rack is initially, you don't need to keep tracking it the whole autonomous period.
It looks like we've finally figured out our autonomous problems in the fix-it-windows, which means we should have a working auto at the Championship (didn't have enough time for it at AZ). I hope we don't have camera tracking problems there, I'd like to see a good amount of autonomous modes there.
  #49   Spotlight this post!
Unread 23-03-2007, 13:11
Tom Line's Avatar
Exactly right.
You need the camera once. So to avoid all the problems we've seen and have experienced, we get close, stop, and take one snapshot of where we are vs. the light.
It doesn't lend itself to any fancy turning / driving. We just turn once and then we drive straight ahead. But we do it often enough that we are pretty happy.
  #50   Spotlight this post!
Unread 23-03-2007, 13:38
Vogel648 Vogel648 is offline
Student Programming Leader
FRC #0648 (QC Elite)
Team Role: Student
Vogel648 is on a distinguished road
It's already been mentioned how to change it is Kevin's code(as I recall there's also an online window you could change it from), in EasyC they have a camera config menu, go to that and then offset your two ends of the three colors away from eachother by whatever seems apropriate.
edit: also dead reconing off your initial camera value means that if your steering is just a little bit off you might not get it, I personally think think tracking is the way to go.
No Tracking During Autonomous jdejoannis Programming 4 10-02-2007 14:46
Camera Tracking Target Jade Programming 3 20-01-2007 01:41
How should we call camera tracking functions during autonomous mode? SHerpich Programming 1 15-02-2006 18:33
Autonomous Capping Regionals Collmandoman Regional Competitions 15 15-03-2005 22:48
Autonomous at Regionals Babyhueyhnx Regional Competitions 34 14-03-2005 20:00
