Go to Post I love FIRST because it makes the dreams of tomorrow seem so much closer. - WakeZero [more]
Unread 24-03-2007, 00:58
yoyodyne yoyodyne is offline
AKA: Greg Smith
FRC #0116 (Epsilon Delta)
yoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to behold
Re: VICTOR RESPONSE DELAY? - AGAIN
Originally Posted by PhilBot View Post
For what it's worth, I wouldn't totally trust the output of the KOP gyro.
See my related thread here:
http://www.chiefdelphi.com/forums/sh...ad.php?t=55200
My experience with the gyro indicated that it has a long time constant of it's own. I did some basic tests, simply moving the gyro (mounted on a block of wood) by hand and I could see quite a long run-on effect (the gyro was still indicating motion long after the motion had stopped).
With a moderate turn rate (say 90 degrees in a second) the gyro would take a good part of a second to come to a complete stop after the turn had completed. Simulating the gyro with a pot showed none of the same run-on (so it wasn't a software issue).
This made it almost impossible to control the motors with the gyro in anything except a straight line run (where any turn was only due to variation in the motors/friction etc)
The other annomily was that this latency only appeared at the end of a turn, not the beginning, which makes me think there is some other processing/filtering going on the sensor board itself. Either way it was a mystery I couldn't resolve.
Thanks for the info. Delayed gyro data would also explain what I am seeing but I haven't noticed that before. I think I can run a little test by rotating the gyro and stop the rotation with closing a limit switch and look at the timing from when the SW sees the digital input change to when the gyro heading changes stop. I do know that the gyro is dead on accuracy wise after it is calibrated but there could be a lag. I'll post the results of the lag experiment.
Thanks,
Greg
Delay Help! waiakea2024 Programming 7 21-02-2007 12:41
Autodesk's response Koko Ed 3D Animation and Competition 7 20-01-2007 16:52
NERDS Delay... Andy Grady General Forum 21 14-03-2006 21:52
Delay Gal Longin Programming 1 09-12-2004 10:37
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
