Go to Post We need to start building FIRST competition arenas and leasing them in the off-season to the sports teams and conventions ;) - protoserge [more]
Unread 24-03-2007, 10:57
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Why 26ms update rate?
Why does it take 26ms to get updates from the master processor.. This seems like an extreamly long time. Anyone know why it takes so long?
Unread 24-03-2007, 11:15
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Why 26ms update rate?
This is as fast as the master processor gets a full data packet from the radio modem. Consequently, you won't get updates from your joysticks any faster than that, so theres little point in updating the user processor faster than that for most things. Why so long between packets from the radio? The modem runs at 19200 bps. That's all. Not coincidentally, that update makes for about 512 bits per update. Just 64 bytes of data per packet to carry: 4 joysticks at probably 5 bytes each, plus team number and channel info, competition control data, presumably checksums and/or error correcting info, stuff I haven't thought of, and possible room for future expansion.
So, mostly, the update is that fast because that's as fast as it can reasonably be made and still get data everywhere it needs to go.
Unread 24-03-2007, 20:39
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Using Easy/C the necessity to think about the 26 msec from the Master is removed, the compiler lets your code run in a tight loop and simply updates the Master processor at appropriate intervals. So if next year, the Master updates every 28 msec or 22 msec instead - who cares?
With the provision of the Easy/C (WPILIB)Timer() functions, it unnecessary (IMHO) for code to base any calculations on the 26 msec interval, or programmers to be concerned about same.
Kevin's explanation of 'why' is clear enough, and it is clear enough that the robots work just fine at this rate.
Why should I update my 2006 code? amateurrobotguy Programming 4 09-01-2007 21:09
Rate my sig/avatar BadKarma Chit-Chat 15 01-02-2006 16:14
ADXRS300EB Rate Gyro rmeenaks Electrical 18 05-04-2004 22:37
Yaw Rate Sensor gburlison Electrical 23 21-01-2004 09:08
Yaw Rate Sensors dense Technical Discussion 4 10-01-2002 08:28
