Go to Post Give us six more motors in the kit, and we'll try and come up with something... - Karthik [more]
View Poll Results: What Six Wheel Drive Is Best?
Traction wheels at the center and omnis at the front and rear 12 6.82%
Wheels at the center wider apart than the others, and an Octagon base 8 4.55%
Six traction wheels; Brute force turning 17 9.66%
Drive with lowered center wheel 129 73.30%
Other, please specify 10 5.68%
Voters: 176. You may not vote on this poll
Unread 03-24-2007, 07:03 PM
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Best Form Of Six Wheel Drive?
I have been doing a bit of research on drive trains for next year I am currently leaning toward some form of six wheel drive. I have noticed numerous variations on the conventional six wheel drive. I have narrowed it down to:
A six wheel drive with two traction wheels in the center and 2 omnis in the front and back
A six wheel drive with a wider track at the center and an octagon shaped base(Haven't chosen wheels yet)
A six wheel drive with six traction wheels and a lot of power (to brute force the turns)
And A six wheel drive with the center wheel slightly lower than the others ( I personally dislike this design)
Any advice or examples would be greatly appreciated.
-Dustin
-Dustin Benedict
Unread 03-24-2007, 07:18 PM
Robo_Coyote's Avatar
Robo_Coyote Robo_Coyote is offline
Cheap_Shot
AKA: Chris Chandler
FRC #1323 (MadTown Robotics )
Robo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to behold
Re: Best Form Of Six Wheel Drive?
Drive with lower centered wheel and all six are traction wheels
2005- Uc Davis Spirit Award
2006 nationals second highest score thanks to 233, and 1184
We need a longer highlight list....... sigh
"To invent all you need is imagination and a pile of junk" - Thomas Edison
Unread 03-24-2007, 07:22 PM
Tom Saxton's Avatar
Tom Saxton Tom Saxton is offline
no team (Issaquah Robotics Society)
Tom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud of
Our team uses a six-wheel design, with the center wheels lowered slightly (1/8 to 1/4 inch). A bunch of teams in the Pacific Northwest use this basic design. We learned it from team 492.
The past two years, we've used high traction IFI wheels in the center and Skyway wheels at the corners. If you can keep your robot reasonably balanced over the center wheels, you get a powerful base that can turn in place, pushes well no matter how the weight is distributed and climbs ramps very well.
Tom Saxton
http://www.idleloop.com/
Unread 03-24-2007, 07:25 PM
Gerry Salinas's Avatar
Gerry Salinas Gerry Salinas is offline
Ninjaneer
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Gerry Salinas is an unknown quantity at this point
Send a message via AIM to Gerry Salinas
-Dustin
What about this design do you dislike? We've been using it at 418 for three years counting '07 and it's worked great. Some people like to lower the wheels a lot, effectively creating two 4WD bases that you rock between, but you don't necessarily need to do that. If you lower the center wheel only very very slightly, then what happens is that you just sink into the carpet a little bit and more of your normal force ends up on the center wheels. The robot doesn't really rock back and forth, but it does turn well.
Gerry Salinas
Team 418
Class of 2007
2006 Lone Star RadioShack Innovation in Control
2006 Lone Star Regional Champions (231, 1421, 418)
Unread 03-24-2007, 07:36 PM
run the trap!!!
Team Role: Human Player
-Dustin
Our team used a 6-wheel drive with pneumatic skyways this season. We used 2 speed AM shifters and lowered our center wheels 1/8"
Video
Another Video...
You can see how agile and speedy it was on pavement.
Well it didn't work that well on carpet... Although it still turned in low gear, it was completely unmenuverable in high. It also started to vibrate horribly after spinning in place for a few seconds. After we lowered the center wheels some more it started to turn better.
Brute force turning is successful at low speeds - but it won't work at all if you start going faster. Omnis are the way to go when it comes to making fast turns.
-Philip J. Fry
Unread 03-24-2007, 07:56 PM
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
We at 665 use a somewhat different system. We use two pneumatic tires in the back for each side. Then we use an omniwheel on each side in the front. The back two wheels are closer together to give more traction from getting pushed from the side and the omniwheels are really close to the front, giving us a good turning radius. The robot turns like a dream, there is no jumpy problems and it is fairly accurate and we can do some good pushing. Even with those omnwheels.
As seen here: http://www.flickr.com/photos/60426630@N00/399274777/
The omniwheels are kind of a black blur, you'll have to take my word for it that they are omniwheels.
-Greg
Unread 03-24-2007, 08:00 PM
Lifelessimp Lifelessimp is offline
FRC #0192 (GRT)
Lifelessimp has a spectacular aura aboutLifelessimp has a spectacular aura about
With 6 traction wheels, a lot of robots have trouble turning without lowering their center wheels. However, certain teams (team 25 comes to mind) have such a powerful drivetrain that they can skid wheels when turning without a problem. I think they even went 8 wheels this year without anything lowered.
Unread 03-24-2007, 08:13 PM
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Yeah, we prefer to "brute force" our turns. We use 9x2 skyways. We custom cut them so that the outer wheels slip a little bit more than the inner ones, which helps a lot with turning. We've been going with a similar design since 2003 and have never had a problem with turning at all.
If you want to check out our drive train, we will be bringing a display one from our practice base to Atlanta (you might have seen it at NJ or UTC). Feel free to stop by and look at it. We'd be happy to answer any questions to have about it!
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Out of all the ones I have worked with, I like this one that was Inspired by Team 1114.
Unread 03-24-2007, 08:34 PM
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
This year team 1726 went with 6 wheel drive with all traction wheels and a lowered center wheel (seen here). After it's remarkable performance, I doubt that the team will be changing it any time soon.
Unread 03-24-2007, 08:36 PM
CraigHickman
Posts: n/a
I'm personally in favor of the kind that drives, and preferably drives only when under operator (or autonomous) control....
But anyway, we've gone with a all traction wheel, all driven system the past two years, and it's treated us great. This year we added on a 2 speed gearbox, and buffed up the whole setup, and we've been running great the whole time.
Unread 03-24-2007, 08:41 PM
cziggy343's Avatar
cziggy343 cziggy343 is offline
cziggy343
AKA: Chris Z
FRC #0343 (Metal-in-Motion)
cziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond repute
Send a message via AIM to cziggy343
in my opinion, the six-wheel base that we are using this year is the best idea that we have ever had. this base has a lowered center wheel, so the robot can rock ever soooo slightly.
http://www.virginiafirst.org/FRC/ima.../target94.html
Diamond Bullet Studios Co-Founder
http://www.dbsgames.net/index.php
Unread 03-24-2007, 08:42 PM
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
Ive designed our 6wd the last 2 years for 1015, both were a success.
2006: center wheels were lowered slightly and had tread on it. Outer wheels did not have tread on it, but i cut groves into them using a soldering iron.
2007: Center wheels were treaded, and ever so slightly larger then the other 2 wheels, and outer wheels were just the kit 6" wheels.
Both worked real well for turning, because the outer wheels act sort of like omni wheels because they can slide along the carpet, however not so much that we are easily pushed arround. I think we have the perfect balance.
Unread 03-24-2007, 08:58 PM
Billfred's Avatar
Billfred Billfred is offline
I've done two kitbot-derived 6WDs in my days, both with the little bit of center-wheel drop inherent with the kitbot.
In 2006 with 1293, we used an 8x2 IFI wheel in the center and Skyways on the corners. The result held up fine through Palmetto, and some off-season thrashing the team did following my departure. (Suffice to say, I noticed some grass around the kit gearbox output shaft when I paid them a visit.)
This season with 1618, we had a bit of funding to use on the drive system, so we switched to AndyMark Gen2 Shifters with a big and small CIM on each side. (We were using one of the small CIMs elsewhere, so we couldn't just go four smalls.) This year, we're using six AndyMark kit wheels, each skinned of its gray rubber surface and replaced with roughtop or wedgetop with rivets. We didn't get the chance to test it on carpet, but tests in the hallway were impressive. (Ask me in a week for better results.)
I haven't experimented with other forms of 6WD yet, but the one I have used hasn't let me down yet.
Unread 03-24-2007, 09:01 PM
John Wanninger's Avatar
John Wanninger John Wanninger is offline
FRC #1732 (Hilltoppers)
John Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond repute
Any advice or examples would be greatly appreciated. -Dustin
First of all, this is only our second year, so take this for what it's worth, we're still new at this; that said:
1732 uses grippy (roughtop) 1.5"W x 6" dia, six wheel drive with the center wheels dropped. We use a kitbot chassis setup for a 13" wheelbase. With 2 CIMs per side we can turn from a standstill easily in Low gear (geared for 5 ft/s max), and reluctantly in High (geared for 11 ft/s max). (We use 36tooth wheel sprockets and 2 speed AndyMark shifters to achieve these 'gearings').
We 'totter' very slightly and our turning axis shifts between mid-front and mid -back depending on instantaneous force distribution between the front and rear wheels (longhand for 'which way we're tottering').
Ease of turning is a double edged sword. By managing the ratio of wheelbase to track (width between wheels)and lateral friction coefficient of the wheel, you can achieve the degree that works best for you.
A robot that is too difficult to turn wastes power in turns and handles 'clumsily' (or doesn't turn at all). However, that same robot drives straight much more easily, which is is often helpful for driving up ramps (especially when combined with the traction bonus of grippy wheels).
A robot that turns too readily can generally be easily ‘directionally reoriented’ by opposing robots, and often tends to oversteer (keeps turning even when you want to stop turning).
My thinking is the optimal lies somewhere in between these two extremes; at least for standard four and six wheel ‘tank style’ drive types.
But then, there are several teams that can change lateral mobility on the fly. Some have used casters that are only deployed for turns (341 and others?), or a perpendicular set of wheels to roll sideways (175), or use swerve drive.
"A hundred times every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving..."
--Albert Einstein
2001: FLL852 |2002: FLL20/FLL21 |2003: FLL23/FLL25 |2004: FLL14/FLL16 |2005: FVC22/FLL124 |2006: FLL3/FLL2986/FVC22/FRC1732 |2007:FLL3/FLL34/FLL56/FRC1732
2008: FLL3/FLL18/FRC1732 |2009: FLL101/FLL8963/FRC1732 ...(etc.!)
pic: FRC488 - Six Wheel Drive Chassis Madison Technical Discussion 38 01-23-2007 10:58 AM
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 01-17-2007 01:21 AM
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 03-29-2006 10:16 PM
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 02-18-2005 08:24 PM
Which form of connecting a rod to a wheel is the best? SilverStar Technical Discussion 2 03-27-2002 08:30 PM
