Go to Post EXPERIMENT in the off season! - DonRotolo [more]
Unread 25-03-2007, 00:08
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: pic: Buckeye Regional Pits
Those look pretty spacious compared to say GLR's pit setup...
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 25-03-2007, 00:23
Sean Marks's Avatar
Sean Marks Sean Marks is offline
AutoCAD User
AKA: Sean Marks
FRC #2016 (Mu Mu Psi)
Team Role: Student
Sean Marks is a jewel in the roughSean Marks is a jewel in the roughSean Marks is a jewel in the rough
Send a message via AIM to Sean Marks
lots more room there then at NJ this year.
2008-NJ Semi-Finalist (Thanks 694 & 1279) / Chesapeake Winners (Thanks 1418 & 11) / Newton Finalists (Thanks 1574 & 141)
2007-NJ Rookie All-Star / Monty Madness Champs
Unread 25-03-2007, 08:46
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
I am ot happy with how FIRS set up the pits this year with the high/low number setup. It's very hard to find teams. If they do this at the championship it will be near impossible to find teams and make scouting very very difficult.
I must also say Buckeye's pits were more spread out than FLR's pits which were for some reason all squished together even though there was like 50 feet of empty space to the south towards the shop.
Unread 25-03-2007, 09:45
Gene Williams's Avatar
Gene Williams Gene Williams is offline
FRC #0070 (More Martians)
Gene Williams is a splendid one to beholdGene Williams is a splendid one to beholdGene Williams is a splendid one to beholdGene Williams is a splendid one to beholdGene Williams is a splendid one to beholdGene Williams is a splendid one to beholdGene Williams is a splendid one to beholdGene Williams is a splendid one to behold
Before I say anything too much about pits I must say that I truely enjoyed the Buckeye venue. I like this Regional. It is well run and the town has some great things going for it. I also like the fact that there is a Team Social for all to enjoy! Kudos to the planning committee and all those that helped.
About pit size, dimensions and room (or lack of): At Buckeye we had a corner pit and had more room (or so it seemed) than we did at GLR. I don't know if FIRST has a "standard" for pit dimensions, but I'd like to see it increased if they do. If we preach so much about safety...then to insure that we are not tripping over everything (safety hazard) we need to come up with a solution to allow easy movement in our pits (both inside the pit as well as the isles). After GLR I went out this past week and purchased some shelving and a new tool box to help consolidate pit "clutter" which drives me absolutely crazy! I will continue to try to maximize on the minimum that we get for our pits. We are working on solutions to make the compact size of pits work to our advantage. As you look around and see the vast amount of stuff we drag in to support our robots it truly becomes necessary to give some thought to this subject.
As far as team number placement, yes it becomes very difficult to locate teams BUT I understand that we need to mix low number teams (older teams with experience) with those high number teams (newer team still learning) so as to be able to offer help and guidance. Just think if we had such a rigid system that place teams in the same numeric order at every Regional. We could easily find each other but then we'd never have new pit neighbors to meet and become friends with.
My 2 cents
Gene Williams
Team 70, More Martians
Xerox Creativity Award 2006 Buckeye Regional
#1 Seed 2006 Wisconsin Regional
Finalist 2006 Wisconsin Regional (Thanks 494 and 1781)
Underwriters Laboratories Industrial Safety Award 2006 Wisconsin Regional
Winner 2006 West Michigan Regional (Thanks 451 and 503)
#1 Seed 2006 Championship Event Curie Division
Finalist 2006 Championship Event Curie Division (Thanks 1114 and 48)
Best Robot Design 2006 Kettering Kickoff
Top Sore of the Day 2006 Kettering Kickoff (70, 703, 1720)
Finalist 2006 Ford FIRST Robotics Invitational (1213, 70, 248)
2007 Just not our year!!!
GM Industrial Design Award 2008 West Michigan Regional
Winner 2009 Kettering District Event (Thanks 245 and 2619)
GM Industrial Design Award 2009 Kettering District Event
Unread 25-03-2007, 09:56
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
My 2 cents
Well if we were never next to 1714 Jeff Huspen would never have been as available to help them fix their robot just like he may not as been as available to help 1765 in FLR in 2006 if they weren't next to us. It's easier to notice you neighbors problems when you are witnessing them firsthand all day long then on the other side of the pits (it also helps to have a robot that doesn't require alot of reapirs).
Unread 25-03-2007, 10:01
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
They did that last year at Las Vegas and this year at UTC. The only reason I can see for this is that the rookies have much easier access to some veterans who can help them with any problems they have. It would also allow them to share resources much easier. Instead of going across the pits to borrow a tool that may have been left at home or to grab a programmer, they just need to lean over into the neighboring pit and tap someone on the shoulder.
I agree, though, it does make it hard to find teams sometimes. At NJ, they stuck with just doing highest->lowest.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 25-03-2007, 10:14
Billfred's Avatar
Billfred Billfred is offline
Chesapeake, IMHO, had the best pit layout I'd seen, roof leaks notwithstanding. You'd have a whole row of teams in numerical order, then shuffle the rows around until you had a proper mix. So if, say, I was looking for 75, I knew they'd be in the same row as 007--same if I was looking for a rookie team (they'd be in the high-numbered row). It was the perfect blend of mixing the rookies with the veterans and having a layout where you could actually find folks.
Unread 25-03-2007, 18:31
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
It may look like there was more room, but compared to GLR there is about half of the room..... It was very cramped, but due to having all of the pits in the actual stadium the ventilation was much better, and you could at least breathe, and not have your goggles fog up. I think that overall this was an amazing, and I know that our team will definitely be back.
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 25-03-2007, 18:40
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
Man I wish there was room like this at every regional. Detroit was pretty bad as it usually is. I hope West Michigan is a little bit more spacious than it was last year.
-Josh Murphy-
Unread 25-03-2007, 18:44
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
The place with the most room is the championships.
Compared to the regionals it's like a highway down there.
Unread 25-03-2007, 18:47
AKA: Josh
I second that one.
-Josh Murphy-
Unread 25-03-2007, 18:59
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
PNW had tons of space. The aisles between the pits were big enough to fit another row of pits We also had a complete practice field, which helps when its everyone's first regional.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 25-03-2007, 21:01
Jeremiah H Jeremiah H is offline
FRC #0393 (Full Metal Jackets)
Jeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of light
I thought the pits at Buckeye were quite roomy, compared with other set-ups we've had. I will say, though, that whatever team(s) your pit is next to makes a big difference in how large or small a pit feels. When one of your neighbors doesn't mind your team spilling into theirs during a rushed time between matches, it really helps when there are multiple things that need to get done in a short amount of time, and it somehow makes the pit space seem bigger.
JH
Johnson & Johnson Sportsmanshp Award, Buckeye '07
Johnson & Johnson Sportsmanshp Award, VCU '07
Finalists at Pittsburgh '06
Pittsburgh GM Industrial Design Award '06
Voted 2006 Boilermaker 'Best Defensive Robot' '06
Unread 25-03-2007, 22:12
DonRotolo's Avatar
Back to humble
FRC #0832
Buckeye was definitely roomier than NJ, probably owing to the lack of a hockey rink wall. I also did like seeing the rookies next to the veterans, there was considerable value there.
The venues for Buckeye and NJ are remarkably similar. Buckeye is a bit cleaner, and they have real faucets on their simks (not those hokey 'press and get 5 seconds of water' thinguies), but access to the floor from the stands could be improved.
The aisles at Buckeye were definitely wider than NJ. But, that photo is misleading, the pits were almost empty at the time.
Don
pic: Israel regional - working in the pits David55 Regional Competitions 3 29-03-2006 15:06
pic: Great Lakes Regional Pits Joe J. Regional Competitions 12 14-03-2006 19:04
Field in Pits at Lonestart Regional raphael Regional Competitions 0 22-02-2005 19:28
pic: Very Last Match At The Buckeye Regional CD47-Bot Extra Discussion 4 12-03-2003 17:16
Buckeye Regional Shelley_delphi chick Regional Competitions 37 03-03-2003 14:57
