Go to Post When a vomit shooter runs out of balls, is it dry heaving? :p - Lil' Lavery [more]
View Poll Results: Would you support a longer autonomous period?
Yes 93 46.73%
No 76 38.19%
Maybe...I'll have to think on that one. 30 15.08%
Voters: 199. You may not vote on this poll
  #31   Spotlight this post!
Unread 25-03-2007, 12:35
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Re: Autonomous Longer????
This years autonomous mode is quite the challenge, It takes a solid mechanical bot and a extraordinary programming team. I'm not under the impression however that an additional 5 seconds will do anything to help out the process. There are very few teams that are " Just Missing " consistently, don't get me wrong they are out there.. but there aren't too many. If you add 5 seconds there are still gonna be those just misses.
With the extra 5 seconds I believe all you are going to be adding is an additional 5 seconds of announcers making things up to say. The task was difficult this year and the problem is, unlike last year, there is no simple task to complete. If you could not find the target last year you could just do guess work, point your bot at the target and shoot. If you were a low ball scorer it was even better. Just a drive straight code for 5 seconds and release your balls.
I believe we really just need more effective preparation for the season. Teams need to have in their repertoire built and tested code for each one of the sensor packages, so that what ever may be the most important for that particular year and your particular robot. A programming team needs as much time if not more than a mechanical team. Robotics is a programming intensive field, and thats hard to say for a Mechanical Engineer in training who has a desire to go into a Robotics Field. The beauty of it is that you can bench test most of these sensors without even needing the huge robot. You can get your team to use vex, or the practice bot or even just a piece of cardboard with wheels and a motor attached to the cpu and your able to build the code. After 5 weeks playing with vex robots, the mechanical team handed our programmers the bot and in just about 2 day ( 1 day of calibrating sensors, and 1 day of actual programing ) they had the bot running autonomous.
I know its hard for this to happen, and it seems like mostly only larger teams who are even able to cap in autonomous effectively, the same argument is always made from the Mechanical End " Well they build at GM, or they build at NASA, of they have 1231232 CNC Machines. " But programming is the area where the mediocre robot can make up in their competitiveness. I know I know, this years autonomous may be not worth as much or some people think its " too short " but what about autonomous sub routines, or ease of driver use by pre-programmed positions, all of these things are extraordinary successes from a programming point of view.
So in conclusion I don't believe autonomous needs to be longer, If your drive team can cap a tube that it starts with in under 15 seconds, your robot should autonomously be able to as well. In fact I'm of the impression and will make the argument that your robot should quite possibly even do it faster/more efficiently than your drive team. Hehe I know this would rarely happen but I'd love to see this competition get to that point. If your robot can't cap under 15 seconds well than, maybe in your case 5 extra seconds is a valid argument from a purely programming point of view. Otherwise, work on it and develop it, just because it may not happen during the season, that does not mean its not a success. Success, at least within the realm of this competition, comes when you complete the challenge, and if you can learn to complete a challenge as hard as this one, I guarantee you'll be able to complete nearly anything thrown your way throughout your academic and your professional career.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
  #32   Spotlight this post!
Unread 25-03-2007, 12:52
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
I really wouldn't mind it but as the second poster said the point is to do with what you have. Thats what the challenge is. I would however support something that would make any keepers scored in auton more valuable. ie. in FLR the teams that could reliably score in auton mode really didn't have a great advantage.
  #33   Spotlight this post!
Unread 25-03-2007, 13:05
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I think a longer autonomous mode would be great. If kids in FLL can have a robot run for 2 minutes(i think) totally autonomous, then why can't FRC? FRC should be a step up, and having only ten second autonomous, that most teams don't even use, is backwards.
I understand that autonomous is a challenge, but with EasyC, KOP sensors, and encoders on the drive, it isn't much harder to write an autonomous for FRC than FLL.
I'm not trying to say we should abolish user control, but a 30-45sec autonomous wouldn't be bad, if teams would do it. Even for audiences not involved with robotics watching autonomous mode can be exciting. FLL can do it.
EDIT: I forgot to say I think the games need to made with autonomous in mind. A long autonomus mode in "Aim High" would have been boring, but a longer autonomus mode in a game made to be played autonomously could be great.
Eric Haskins KC9JVH
  #34   Spotlight this post!
Unread 25-03-2007, 13:07
Bharat Nain's Avatar
The autonomous is long enough. Maybe the task they give us should be more feasible and worth a little more.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
  #35   Spotlight this post!
Unread 25-03-2007, 13:17
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
I think it is the right length.
Many robots do not move, so a longer time would not add anything.
I have not seen any robots run out of time - most that work are complete in 10 seconds.
At first I thought the point vaue was low, but it is really the point potential that makes it worth it - you have the start of an 8 row or 3 column that cannot be spoiled - and that can be worth a lot of points.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
  #36   Spotlight this post!
Unread 25-03-2007, 13:45
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Reading Dan's post it gave me an idea for a new auto mode.
As soon as your bot succesfully rings the keeper, then the drivers can go to the controls, others have to wait until auto mode time is over.
With this option 1902 probably could have 2-3 ringers up before others even started playing. Talk about making auto mode important.
Doug Leppard
  #37   Spotlight this post!
Unread 25-03-2007, 13:53
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
That's because there's still a lot of human interaction during the autonomous portions of FLL. This human interaction delt with the kids acutally handling the robots, chosing modes, etc. You cannot do this with FRC.
  #38   Spotlight this post!
Unread 25-03-2007, 14:57
AKA: Eric Haskins
I don't think a 2 minute autonomous would work, but having a 30 second autonomous is not unreasonable. I mentored two FLL teams last year(1192(Microlasers) and 1193(Phoenix NanoTechs)), and they each had at least one routine that was longer than 30 seconds. They where both new teams, and their programmers were learning during the season.
If middle school kids with little or no programming and engineering skills could build and program a robot to run for 30 seconds autonomously then why can't we?
Eric Haskins KC9JVH
  #39   Spotlight this post!
Unread 25-03-2007, 15:24
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
There is a difference between FLL and FRC auto-modes...is the number of robots on the field. All it takes is for one auto-mode to disrupt another auto-mode and you will have and additional 15 seconds of nothing.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
  #40   Spotlight this post!
Unread 25-03-2007, 15:52
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Originally Posted by Bongle View Post
Why not arm unfolding? Because you can do that in the time it takes your human player to run forward and toss the first ringer
Why not move forward? Risk of ringer-ing yourself or an alliance member ringer-ing you on the first toss. You're safer in the 'shadow' of the driver wall.
Why not move across the field and prepare to defend? I saw a few teams get tangled on the rack trying this. In order to avoid entangling yourself, you need the gyros and accelerometers as well as the programming skill to use them, which is nearly as hard as the camera.
Totally agree with this. You CANNOT make an effective autonomous mode from scratch at the competition, unless you have a godlike hardware team. At the competition, there will always be repairs to be done, bolts to be tightened, kajiggers to be lubed and polished. The programming team only gets robot access when all those things are done, which is never. You need substantial alone time with the robot during the build period in order to develop and test autonomous mode, which requires a fast hardware team.
If you put sensors on your arm like you _REALLY SHOULD_, and have the PID code already tuned for it, unfolding your arm is not difficult. We only had to write 2 extra lines of code to set up our arm.
Even if you have a godlike hardware team (or really good luck, in our case) and your robot is working properly and doesn't require any hardware adjustments between matches, it's very difficult to write a proper autonomous mode. We abstained from making an autonomous mode simply because our robot was working well enough that we didn't want to make any changes at all.
I agree with a lot of the people on this thread - autonomous mode isn't worth nearly as much as it could be. Yes, it could mean a lot of points, but it's one tube. Even the spoiler factor isn't worth all that much. In a row of 7, if the keeper is placed in the center, if you spoil one spot off center, that row is still dropped to 20. We focused on improving our teleoperated mode code enough that it would help us score at least one more tube. It worked.
Real programmers use vim.
  #41   Spotlight this post!
Unread 25-03-2007, 20:14
AKA: Eric Haskins
I do agree having multiple robots on the field could be a problem with previous games, but those games weren't designed for six robots to be moving in autonomous.
A game designed with autonomous mode in mind shouldn't have that problem.
Eric Haskins KC9JVH
  #42   Spotlight this post!
Unread 25-03-2007, 20:16
technoL's Avatar
technoL technoL is offline
AKA: Noelle Manning
FRC #0108 (SigmaC@T)
technoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud of
Send a message via AIM to technoL
Although I do agree with the importance of software rising in FIRST, I do disagree with extending autonomous. Making the autonomous challenges harder and worth more will inspire better software, not just allowing more time, or making it easy to score.
Many teams already disregard autonomous all together because it is too difficult, and they rather make up for it by making an efficient robot, or at least putting more time into their robot and not wasting* time on things that that have no clue how to do.
Being forced to watch an extra 5-10 seconds of a robot beauty contest doesn't benefit anyone but the teams that are already strong in autonomous. It has been a very rare occasion that I have seen a tube dropped immediately after autonomous, if the robot moves at all. And if you're just a spectator brand new to FIRST, it can be the most boring part.
I do like the way that Vex is setup though. Perhaps it could be a bonus to your score (not required) to complete an extra autonomous challenge on a separate field, or during another time of the day.
-No L
*in no way do I mean that software is a waste of time, although it can be if you have no clue of what you are doing
Team Leader | Mechanical | Driver | SOAP | Anything
2008: NJ GM Industrial Design Award, 4th Seed | FL Rockwell Automation Innovation in Control Award, 1st Seed, Semifinalists
2007: FL Finalists | LV Xerox Creativity Award, Quarterfinalists | Mission Mayhem Champs
2006: FL Delphi's Driving Tomorrow's Technology | Curie Quarterfinalists
  #43   Spotlight this post!
Unread 26-03-2007, 00:30
pyrome's Avatar
pyrome pyrome is offline
Driver, Programmer, Engineer
FRC #0852 (Athenian Robotics Collective (ARC))
Team Role: Operator
pyrome is on a distinguished road
Team 852 only unfolds its arm during autonomous for two reasons:
1: we didn't give our programmer enough time with the robot to get it done
2: our programmer then said that the camera was too inaccurate to have an effective autonomous.
Mark Ellis
A.K.A.
Markapopalis
Markola
Markali
Markalis
Markolas
Polo
Marco
  #44   Spotlight this post!
Unread 26-03-2007, 00:39
Vogel648 Vogel648 is offline
Student Programming Leader
FRC #0648 (QC Elite)
Team Role: Student
Vogel648 is on a distinguished road
You didn't have your robot done until halfway through your competition?
Otherwise you shoulda just told him/them to crack down and skip lunches.
  #45   Spotlight this post!
Unread 26-03-2007, 02:31
yodameister yodameister is offline
The Mad Chemist
FRC #2791
yodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant future
I said no (at least this year) because the auto has seemed basically meaningless and why drag on a match even longer than we already have to endure?
Banebot transmission no longer COTS? flightofone Motors 24 02-02-2007 16:41
Joystick Triggers No Longer Work amateurrobotguy Technical Discussion 7 04-04-2006 13:58
IE No Longer Getting Updated HFWang Website Design/Showcase 62 01-11-2003 03:25
I will no longer be doing FIRST¡K archiver 2001 12 24-06-2002 04:20
longer PMs? Joe Ross CD Forum Support 1 10-08-2001 18:06
