Go to Post changing some 0 to 1s was a lot lighter and cheaper than most of the clutches I found. - IKE [more]
Unread 26-03-2007, 11:50
yoyodyne yoyodyne is offline
AKA: Greg Smith
FRC #0116 (Epsilon Delta)
yoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to behold
Re: VICTOR RESPONSE DELAY? - AGAIN
Originally Posted by PhilBot View Post
Well, your Gyro looks a lot better behaved than mine was.
I'm assuming you are also just using the KOP gyro?
Also, What gyro dead band were you using?
Thanks for the great data... I'm going to look at it in detail.
It also restores my faith in the Gyro a bit
Yes this is the 2007 Gyro/Accelerometer board that we got in trade from another team for our gear tooth encoders that we did not use this year.
#define GYRO_DEADBAND 4
I have some better data with the CCW rate slowing down every cycle with the idea being to determine if the gyro lag has anything to do with the rate. This data also shows some drift. I haven't had the time to really analyze it.
Delay Help! waiakea2024 Programming 7 21-02-2007 12:41
Autodesk's response Koko Ed 3D Animation and Competition 7 20-01-2007 16:52
NERDS Delay... Andy Grady General Forum 21 14-03-2006 21:52
Delay Gal Longin Programming 1 09-12-2004 10:37
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
