Go to Post "Your really pretty and I like your bot" - prettycolors91 [more]
Unread 26-03-2007, 14:45
Team_486 Team_486 is offline
FRC #0486
Team_486 is an unknown quantity at this point
Angry Easy C Relay Programming
for easy C,
i know you can set a relay to a button and have that relay in a set position when you hold the button, but can you, in easy c, have it so you click the button once and the relay stays on, and click it again to switch the relay reverse or off? i know the wording of this question is not too great, but if you can decipher it, an answer would be great!
Unread 26-03-2007, 15:01
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Team Role: Electrical
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
Re: Easy C Relay Programming
You want the relay to toggle. Its not too complicated to do.
This example will toggle a relay when the trigger is pulled on the first joystick.
char relayPos = 0;    //Holds the current position of the relay
char relayRelease = 1;    //Holds if trigger has been released yet
if(GetOIDInput(1, 1) && relayRelease)    //If trigger is pressed after being released
    if(relayPos == 1)
        SetRelay(1, 0, 1);
        relayPos = 0;
    }else
        SetRelay(1, 1, 0);
        relayPos = 1;
    relayRelease = 0;    //Set trigger as pressed
}else if(GetOIDInput(1, 1)==0)    //trigger released
    relayRelease = 1;
Note that the above is for a double solenoid. If you are using a single solenoid then change the SetRelays to SetRelay(1, 0, 0) and SetRelay(1, 1, 0)
2007 UTC Champions Thanks 1124 and 558
2007 UTC GM Industrial Design Award
2006 Newton Divisional Winners
2006 Championship finalists
(Thanks 25 and 968 for picking us!)
2006 National Innovation in Control
Pneumatics (Spike Relay, Solenoid etc.) Programming oceansidehs Programming 8 10-02-2007 13:58
Easy C programming Problem fredliu168 FIRST Tech Challenge 6 19-11-2006 22:44
Relay Programming Questions... comwiz7 Programming 11 21-02-2006 13:04
Easy C programming , Worth teaching? Nine9cracker Programming 16 19-01-2006 00:45
Easy-C Programming CD Jeff K. Programming 2 09-01-2006 02:20
