Go to Post we used to walk barefoot through five feet of snow to get to school, uphill both ways, with just barbed wire for mittens, and we liked it! - dlavery [more]
Unread 27-03-2007, 17:22
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Joystick filtering gone horribly wrong...help!
Hey all,
I was asked to make the robot have a curved response in the drive motors, i.e. pushing the joysticks halfway gets you about quarter speed, but pushing them full gets you full speed. I was advised that this will make the drivers' jobs easier. However, it seems to be making my job more complicated...
I have a basic lookup table solution in place right now...but it doesn't work. Ideally, I want to be able to input a number of points on the curve (right now, I have 7) and have the code extrapolate the points in between. I would be able to tweak this curve, adjust the constants in code, recompile, and blast the code down again to have filtered joysticks.
Now, at this point in time, I am getting strange results. The code I have is trying to set outputs to values like 360-something or greater, and I can't figure out why (I know it's out of range. I know PWMs only go up to 254...). I am seeing this code get more and more complex, and I need some help implementing KISS in this situation.
Here's the code I've got right now:
unsigned char DRV_GetFilteredValue(unsigned char joystick)
	static const unsigned char lookup[] = {127,135,140,145,165,200,254};
	int temp_joystick = (((int)joystick-127)/21.1);
	printf("temp_joystick = %d\r\n",(int)temp_joystick);
	printf("joystick is %d\r\n", (int)joystick);
	if (temp_joystick >= 7) { temp_joystick = 6; }
	if ((joystick < 130) && (joystick > 124)) {
		return 127;
	} else if (temp_joystick < 0) {
		printf("lookup[temp_joystick] = %d, lookup[temp_joystick-1] = %d, output is %d\r\n", (int)lookup[temp_joystick], (int)lookup[temp_joystick-1], (int)((joystick - lookup[temp_joystick-1])*(lookup[temp_joystick] - lookup[temp_joystick-1]) / 21) + lookup[temp_joystick-1]);
		return ((joystick - lookup[temp_joystick-1])*(lookup[temp_joystick] - lookup[temp_joystick-1]) / 21) + lookup[temp_joystick-1];
	} else {
		temp_joystick = -temp_joystick;
		printf("lookup[temp_joystick] = %d, lookup[temp_joystick-1] = %d, output is %d\r\n", (int)lookup[temp_joystick], (int)lookup[temp_joystick-1], (int)254-((joystick - lookup[temp_joystick-1]) * (lookup[temp_joystick] - lookup[temp_joystick-1]) / 21) + lookup[temp_joystick-1]);
		return 254-((joystick - lookup[temp_joystick-1]) * (lookup[temp_joystick] - lookup[temp_joystick-1]) / 21) + lookup[temp_joystick-1];
(If you can weed through that, you get a cookie)
You don't even have to look at that code. I just need something that I can put in place to filter the joysticks.
Thanks in advance for any help you can provide.
And I'm willing to throw out the code I've got; I just need *something* to work.
JBot
Aren't signatures a bit outdated?
Unread 27-03-2007, 17:39
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Joystick filtering gone horribly wrong...help!
On this here, you access negative members of an array. The only time you will ever enter this code is when temp_joystick < 0, and then you use it to address your lookuptable.
That's one of a few issues. I'm coding up an integer version right now.
You need to have a power of two number of line points. They are assumed to be evenly spaced between 0 and 255.
#define BITS_FOR_LOOKUP 3 // we're using the most significant 3 bits of the joystick value
#include <iostream>
using namespace std;
unsigned char lookup[8] = {0,31,63,95,  126,158,190,221};
unsigned char joyFilter(unsigned char joyValue)
  unsigned char n = joyValue>>(8-BITS_FOR_LOOKUP);
  // n is between 0 and 7 for sure
  unsigned int last;
  unsigned  int next;
  unsigned  int howFarAlong = joyValue - (n<<(8-BITS_FOR_LOOKUP)); // finds out how along joyValue is between n and n+1
  unsigned  int maxFarAlong = (1<<(8-BITS_FOR_LOOKUP));
  unsigned  int invHowFarAlong = (maxFarAlong - howFarAlong);
  if(n+1 >= 8)
      last = lookup[7];
      next = 256;
  else
      last = lookup[n];
      next = lookup[n+1];
  return (invHowFarAlong*last)/maxFarAlong + (howFarAlong*next)/maxFarAlong ;
Unread 27-03-2007, 18:25
dpick1055's Avatar
dpick1055 dpick1055 is offline
David Pick
FRC #1739 (Chicago Knights)
dpick1055 is on a distinguished road
Send a message via AIM to dpick1055
Your actually making it more complicated then you need to with a lookup table. Using a squaring function and some if statements you can get the curved response you want. Here's the code I used on our robot this year.
        int linput;
	int rinput;
	int loutput;
	int routput;
		if (p1_y < 127)
				linput = 127 - p1_y;
				loutput = 127 - ((linput * linput) / 127);
		if (p1_y >= 127)
				linput = p1_y - 127;
				loutput = ((linput * linput) / 127) + 127;
		if (p2_y < 127)
				rinput = 127 - p2_y;
				routput = 127 - ((rinput * rinput) / 127);
		if (p2_y >= 127)
				rinput = p2_y - 127;
				routput = ((rinput * rinput) / 127) + 127;
					pwm15 = 254 - routput;
					pwm13 = loutput;
Always remember to take your powered wheels off the ground when first testing code. Otherwise you'll end up with holes in the wall like us
Unread 27-03-2007, 18:48
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
I was hoping someone else would find a simpler way of doing this. The lookup table was starting to get out of hand.
Thanks for your help; I will try this.
JBot
BTW, dpick, nice sig. You should get yourself a disable switch, though; you can react fast enough to kill the 'bot if bad things happen...;-)
Unread 27-03-2007, 18:54
dpick1055's Avatar
David Pick
Thanks for the advice : ) We actually have one I just can't find it in the giant box of electrical stuff.
Unread 27-03-2007, 19:32
in between teams
AKA: Luke Van Oort
http://www.chiefdelphi.com/forums/showpost.php?p=547561&postcount=9 And, as an example of the 255 value tables I talked about, here is the 255 value table currently on our robot.
rom const unsigned char expotable[255] =
0, 3, 5, 8, 10, 13, 15, 17, 20, 22, 24, 26, 28, 30, 32, 34,
36, 38, 40, 42, 44, 45, 47, 49, 50, 52, 53, 55, 56, 58, 59,
61, 62, 64, 65, 66, 67, 69, 70, 71, 72, 73, 74, 76, 77, 78,
79, 80, 81, 82, 83, 83, 84, 85, 86, 87, 88, 89, 89, 90, 91,
92, 92, 93, 94, 95, 95, 96, 97, 97, 98, 98, 99, 100, 100,
101, 101, 102, 102, 103, 103, 104, 104, 105, 105, 106, 106,
107, 107, 107, 108, 108, 109, 109, 109, 110, 110, 110, 111,
111, 111, 112, 112, 112, 113, 113, 113, 114, 114, 114, 114,
115, 115, 115, 115, 116, 116, 116, 116, 117, 117, 117, 127,
127, 127, 127, 127, 127, 127, 127, 127, 127, 127, 137, 137,
137, 138, 138, 138, 138, 139, 139, 139, 139, 140, 140, 140,
140, 141, 141, 141, 142, 142, 142, 143, 143, 143, 144, 144,
144, 145, 145, 145, 146, 146, 147, 147, 147, 148, 148, 149,
149, 150, 150, 151, 151, 152, 152, 153, 153, 154, 154, 155,
156, 156, 157, 157, 158, 159, 159, 160, 161, 162, 162, 163,
164, 165, 165, 166, 167, 168, 169, 170, 171, 171, 172, 173,
174, 175, 176, 177, 178, 180, 181, 182, 183, 184, 185, 187,
188, 189, 190, 192, 193, 195, 196, 198, 199, 201, 202, 204,
205, 207, 209, 210, 212, 214, 216, 218, 220, 222, 224, 226,
228, 230, 232, 234, 237, 239, 241, 244, 246, 249, 251, 254
Team 1219: 2009 - Mentor
Unread 27-03-2007, 21:38
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
This is what Team 11 Came up with to put a curve on the joysticks..
int ramp_joystick(int value)
	if (value < 127 )
		return sqrt(127)*sqrt(value);
	if (value > 127 )
		return -sqrt(127)*sqrt(-value + 255) + 255;
	if (value == 127 )
		return 127;
Unread 27-03-2007, 21:58
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Our code looks very similar. We actually have 3 tables available to be loaded into ROM, depending on what kind of dampening we need (2nd order, 3rd order, 4th order)
Cool stuff.
Jacob
Unread 28-03-2007, 08:52
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We use excel. We use 3 points 0 127 to define one curve, and 3 points above 127 to define the 127 - 255 curve. Then you graph those points and have excel do a trendline and give you the equation.
Now you can just change your 3 datapoint values around and the trendline graph will automatically give you the new equation. You can either type the equation into excel and have it give you the values for a lookupt table (it becomes a simple copy/paste) or you can multiply the equation by 10, 100, or 1000 to remove the floats and simply use the equations with integer math in your program.
Once you have the excel spreadsheet set up, it takes about 30 seconds to change the curves then update your program.
EMI Filtering Mike Betts Electrical 1 06-03-2007 15:38
pic: Dodgeball gone wrong. Bharat Nain Extra Discussion 6 23-04-2006 20:11
Genia and Mike's Walmart Frolic Gone Wrong MikeyP Chit-Chat 25 20-04-2005 20:21
Math Gone Wrong psquared Programming 10 23-01-2005 12:18
HELP! My 'Documents & Settings' Folder Is Gone... WITH ALL MY STUFF! Joe Matt Chit-Chat 3 28-10-2004 21:09
