Timer Question
Hi, our incredible plans to create an autonomous mode has failed (once again
) and im thinking we will have to rely on timers again. Last year, we used EasyC, but this year we're using MPLab. We have the idea of having a timer based on the number of loops. We believe each loop is 26.2 ms, so can we take this number and loop it xx times and increasing a counter each loop until it reaches the specific time?example, we want to move 5 seconds forward 5s = 5000ms = 190 loops. static int timer = 0; **move forward**; if (timer <190) timer = timer +1 ; if (timer >=190) **stop**; Thanks!! |
Re: Timer Question
That would work except that I think your autonomous code will start running a little before the disabled_mode is turned off so it will time out faster as a result. You could add
if (disabled_mode) timer = 0; in your autonomous loop and then it will not actually start to increment until the autonomous period actually starts. If you want you can use a more capable e timer capability. I posted the team 116 timer library which allows you to run up to 10 software elapsed timers and 10 event timers that actually will call a routine when they time out. If you are interested in that look toward the bottom of this thread. http://www.chiefdelphi.com/forums/sh...dware+t imers Good luck, Greg |
Re: Timer Question
Yes, that will work.
About 38 cycles = a second so you could do something like: int delaySeconds = 38 * sec; int counter = 0; MOVE_FOWARD; if(counter < delaySeconds) { counter++; }else{ STOP_MOVING; } Remember to declare the int's at the top of the routine and good luck! ![]() Note: You could use software timers like the one posted above, but just for simplicity, fastness, and realiblity, it won't matter if you choice either one. Last edited by pheadxdll : 28-03-2007 at 22:45. |
Re: Timer Question
but we are VERY short on time, planning to program this on the spot so we have a moving robot in autonomous =D (even if it does nothing useful). so i think its best for us to stick with a simple timer code. By the way, u said there may be some problems with disabled mode? is the if (disabled_mode) timer = 0; the actual code for it? as in, can we use this exact code and ensure the program will work? thanks |
Re: Timer Question
Re: Timer Question
There is a global variable named "disabled_mode" that is set true for a while after autonomous_mode is set to true and your autonomous code will start. What will happen is you will turn on PWM output for the motors but nothing will happen because the robot is disabled. The 15 sec autonomous period does not start until disabled_mode is set to false.
Check out Mark's post on this thread. http://www.chiefdelphi.com/forums/sh... onomous_mode " Re: _mode flag summary?? -------------------------------------------------------------------------------- Last year we reset our autonomous whenever the robot was disabled. The drivers didn't have to remember to reset for the second practice match. Last year the actual sequence at the SBPLI Regional was: Disable bit set before the match started Both disable and autonomous bits set Then disable was turned off to start the autonomous mode Finally the autonomous bit went off as the user_mode came on One team had their autonomous timer ticking off while the robot was disabled at the beginning of the match, so the robot always thought it was partway or completely through the 15 seconds, before they were enabled and allowed to move." |
#7
Re: Timer Question
That is an excellent idea. Here's how I've been implementing it for the last few years; first the code, then an explination:
First off, I have two macros, all defined in auto_next.h ("DEBUG" is a macro defined elsewhere which will either call printf, or do nothing) Code:
#ifndef __AUTO_NEXT_H__
#define __AUTO_NEXT_H__
#define AUTO_NEXT_STEP(x,name) \
if (auto_counter >= x) \
DEBUG((name "\r\n")); \
DEBUG(("auto_counter(%d) >= %d ", auto_counter, x)); \
++auto_step; \
DEBUG(("advancing to state %d\r\n", auto_step)); \
auto_counter = 0; \
#define AUTO_NEXT_STEP_COND(x,y,name) \
else if (y) \
DEBUG((#y)); \
DEBUG((" (%d) ", auto_counter)); \
++auto_step; \
auto_counter = 0; \
#endif // __AUTO_NEXT_H__
// These are used for state in autonomous mode static unsigned int auto_counter = 0; static char auto_step = 0; And finally, in your slow loop autonomous function, do something like this: Code:
void User_Autonomous_Slow_Loop(void)
auto_counter++;
switch (auto_step)
case 0:
robot_drive(127,192);
AUTO_NEXT_STEP(120, "drive forward");
break;
case 1:
bool turn;
turn = robot_turn_to_angle(90);
AUTO_NEXT_STEP_COND(400, turn, "turn robot");
break;
case 2:
robot_all_stop();
break;
The two variables, auto_step and auto_counter keep track of the state. The macros help manipulate them. AUTO_NEXT_STEP two paramaters, a time, and a string which is the name of the current mode. Each time through the slow loop, the auto_counter gets incremented. If it reaches the time paramater of AUTO_NEXT_STEP, the counter gets reset to 0 and the auto_step gets incremented. The advantage to doing it this way over something like a bunch of chained if statements Code:
if (timer < 120)
// drive forward
} else if (timer < 400)
// turn
The AUTO_NEXT_STEP_COND macro is like AUTO_NEXT_STEP, except that it also takes a condition. If you have a function like "robot_turn(90)" which returns a boolean value of TRUE when it is completed and FALSE when it is not, then you can use AUTO_NEXT_STEP_COND to advance to the next state as soon as a condition is met, rather than waiting for a time. This is particularly useful if you have functions to drive a certain distance based on encoder counts, or move an arm to a certain position, etc. Good luck! --AJY |
#8
Re: Timer Question
if (disabled_mode) timer = 0; is the same as: if (disabled_mode == true) timer = 0; right? thanks again .Last edited by lightning_blast : 28-03-2007 at 23:38. |
#9
Re: Timer Question
For practical purposes, yes,
if(disabled_mode) // not disable_mode - my bad is really the same as if(disabled_mode != 0) If you look at ifi_default.h you will see the following defines: #define FALSE 0 #define TRUE !FALSE It might make more sense if the way you coded it was simply in your logic to increment timer if(!disabled_mode) // disabled_mode == FALSE timer += 1; |
#10
Re: Timer Question
If true = 1, then yes.
#11
Re: Timer Question
Re: Timer Question
thanks for all of your help guys
. im going to.. try out an autonomous tomorrow (GTR regionals ). i doubt we'll do so well but FIRST isnt all about winning right? ![]() |
#13
Re: Timer Question
Alan,
I don't know for a fact what the competition port sequence is this year but User_Autonomous_Code() gets called from main() if autonomous_mode is set regardless of the independent disabled_mode flag. It seems to me that to insure that Process_Data_From_Master_uP() is never called until the end of autonomous mode then disabled_mode and autonomous_mode would have to be set true at the same time. Maybe not for long but autonomous_mode has to already be set before disabled_mode is turned off. We aren't taking any chances so we wait until disabled_mode is turned off and autonomous_mode is turned on to start our autonomous play. Do you know what the timing is for 2007? |
#14
Re: Timer Question
Re: Timer Question
| Timer questions | Rick TYler | Programming | 3 | 12-02-2006 19:24 |
| Quick Timer Question | et1337 | Programming | 3 | 02-02-2006 15:19 |
| Accelerometer Timer Question | psquared | Programming | 3 | 12-02-2005 01:34 |
| timer | omega | Programming | 3 | 30-03-2004 18:52 |
| Timer Preview | Nate Smith | General Forum | 2 | 05-03-2003 12:25 |
