Go to Post We are all insane aren't we? I just want to build a robot now. :P - Lowfategg [more]
Unread 29-03-2007, 01:05
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Neat Wires
Originally Posted by Rich Ross View Post
I can't help but wonder how much all those zip ties weigh....
At one point this build season, I took off a quarter of a pound on the bot just cutting off the ends of zipties ... There were so many, I just had to weigh them when I was finished. I wound up re-doing the whole board anyway on a different piece of material, and this time designed it so that I could use less zipties....
I'll find a picture somewhere of all of those ziptie ends on a scale...
Jacob
Unread 29-03-2007, 07:31
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
Re: Neat Wires
Is that mid-build, or are you really just using two small CIMs in the drivetrain?
Off topic but, We only use 2 small CIMs with banebots gearboxs and we can push arround other robots, climb up ramps, and manuever better then most teams. We geared it down to a theoretical speed of 7ft/s, so we have plenty of torque and are slow enough to handle easily.
Unread 29-03-2007, 08:43
AKA: Jacob Komar
Re: Neat Wires
It really is sad....
Gone are the days of using only 2 small CIMs to drive your bot around. Now everything has to be a pushing match. It really is scary how you *usually* need the 2 large CIMs or 4 small CIMs just to be competitive, especially as a defense bot / good offense bot that can't be pushed around.
[/OFFTopicRealization]
Jacob
Unread 29-03-2007, 13:26
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Re: Neat Wires
Jacob
That is why first has a limit on motors. also weight becomes a factor. so its not like the teams are not giving up to get the pushing power.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 29-03-2007, 17:13
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: Neat Wires
Originally Posted by Qbranch View Post
Ok... can't help it... robotics kid and all.... Is the picture of that wiring job from a large motor controller? With the large caps, fuses, heat sinked thing (most likely ac triacs)... leads me to think so.
Anybody know what that thing is?
-q
That's not an ac triac. It's a three phase bridge rectifier. I actually managed to find the part number because the package looked similar to others I've seen from the same company. The also color coded for three phase power (Red Blue and Black). The round clynidrical objects below the relays are power resistors and are most likely wire wound. Even the ones with the bands on them are beefier than usual. It almost looks like part of a motor testing bench from my perspective. I'll go into more detail later about the how the setup works though later.
Unread 01-04-2007, 14:49
Re: Neat Wires
It looks like a lot of equipment I work on. Please note the layer of dust on everything, indicating that it has been in service for quite some time. Note the wire colors in use on the two capacitors, one with red and black and one with blue and red, indicating that there is a positve power supply and a negative power supply. The other rectifier is just out of the frame on the left. In addition the power resistors shown are likely either bleeders for the caps or inrush current limiting resistors that are switched out a few seconds after the power is applied by one of the relays in the picture. Other interesting things to note are the meter shunts just above the two large fuses. A shunt is essentially a very samll resistor that is placed in parallel with an ammeter, to directly read a large current. Although it is hard to tell exactly what device this is, transmitters take on the same look. If this is a transmitter, it is either a very low power device or just the control cabinet.
Unread 01-04-2007, 15:59
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Neat Wires
There's a surprise waiting for you in the specifications of the large and small CIM motors. The large CIM outputs 270 W, while the small one outputs 330 W. This means that 2 large CIMs are not nearly as powerful as 4 small ones.
Unread 01-04-2007, 16:32
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
Re: Neat Wires
Originally Posted by Priyadarshy View Post
well no one from 612 wired that thing thats for sure...
thats for sure, your electronics board was wood right? I shouldn't point fingures, our was horrendous! We didnt even tie our stuff down!!
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
A Neat Victor Fix kitscuzz Programming 2 12-02-2007 01:10
skype and other neat programs mechanicalbrain Chit-Chat 16 18-07-2005 14:27
Neat & Organised Electric Wiring thoughtful Electrical 30 13-12-2004 22:46
Neat gmail programs Joe Ross Chit-Chat 5 21-07-2004 02:03
neat feature not seen here....... Clark Gilbert CD Forum Support 2 21-11-2001 04:53
