Go to Post If I had a dollar for every time I thought we'd get a legitimate hint....Well, I might have a few dollars... - Andrew Blair [more]
  #61   Spotlight this post!
Unread 24-03-2007, 12:57
Billfred's Avatar
Billfred Billfred is offline
Re: Most Unique Features
A feature that 1618's robot has this year that its past robots didn't? It's tall.
I can't say that there's anything particularly innovative about "What robot?"* this year--when I did any design work, I immediately looked back to what had worked in the past. Borrow 1293's 2006 drivetrain, add a speed, and switch your source of rolling stock from Texas to Indiana, and there you go. For the arm, borrow loosely from one picture of 330, add a wrist to let you reach the floor, and make it so fast, you'll be glad you're behind lexan. (I'll have to find the video on my iBook to post.)
The arm is all PVC and angle aluminum, with a little bit of flat to mount a 12:1 BaneBots gearbox. (Granted, I'm still a little worried about running a BaneBots gearbox, but we felt the loads it'd see, both normally and otherwise, aren't going to be as severe as what it'd see (and wither in the face of) on a high-grip drive system.) The second stage is the Denso motor handling a little bit of PVC; I don't expect that exact end effector to see action on Friday, but its replacement is currently a known unknown. (Good thing we can bring bandsaws to events again...)
The drive system is an AndyMark two-speed, with gearing through sprockets for fast and faster. I've got a few ideas percolating for Palmetto as to how we can best use that to our advantage. (I've also got a few more ideas percolating as to how we can handle defense better if need be, since this competition is proving a just a smidge more physical than planned.)
Perhaps more unique is that we were able to do all this with seven kids, one engineer, a PLTW teacher, and a slightly-eccentric marketing major, in a room with two bandsaws, a grinder, a couple of drill presses and a chop saw**, and still come in about ten pounds underweight as of ship day. It might not be the prettiest dame at the ball, but we hope to fill up its dance card.
*That's another unique feature to this year--it's got a name!
**Chop saw.
  #62   Spotlight this post!
Unread 24-03-2007, 16:59
cziggy343's Avatar
cziggy343 cziggy343 is offline
cziggy343
AKA: Chris Z
FRC #0343 (Metal-in-Motion)
cziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond repute
Send a message via AIM to cziggy343
if i had to pick a unique part about our robot, i would say it is the "foot" under the gripper. this is a flat piece of polycarbonate that flattens to the ground when the arm reaches the ground. it works much like a doorhendge.
http://metalinmotion.com/
scroll down on the sit for a picture.
Diamond Bullet Studios Co-Founder
http://www.dbsgames.net/index.php
  #63   Spotlight this post!
Unread 24-03-2007, 22:33
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
Originally Posted by Hachiban VIII View Post
When I say we spent six weeks designing our robot I mean we spent six weeks designing our tube manipulator.
We carefuly prototyped every part of it to make sure the final design would work perfectly.
-Urethane belts give extra traction
-belts aranged in a "V" configuration - work like rubber bands
-Made from 9 ply baltic-burch plywood - very light and strong
-Lego tires for added pick-up traction
-Uses two game buttons to sense tube orientation
-All pulleys are covered with individual plastic guards to prevent belts from falling off.
-The belts cannot be removed without dissasembly
-Can rotate, shoot, or suck tubes (or cakes)
-It also looks cool
arcade buttons FTW
  #64   Spotlight this post!
Unread 25-03-2007, 12:19
Kelli Fultz's Avatar
Kelli Fultz Kelli Fultz is offline
FRC #0234 (Cyber Blue)
Team Role: Student
Kelli Fultz will become famous soon enough
Our robot has two small wheels on the bottom of the gripper to help pull the tubes in, then a limit switch triggers a pneumatic to grip the tube so it can lift them.
It also has pre-set limits on the arm for each level of scoring.. so that is one more thing the drivers don't have to worry about getting so precise.
  #65   Spotlight this post!
Unread 25-03-2007, 22:21
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
You forgot about team 79 (krunch) who was one of the fastest robot scorers that i saw at the Florida regional.
  #66   Spotlight this post!
Unread 26-03-2007, 08:29
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
at buckeye i saw two very cool things
1. one of the martians, maybe both, had a full window's computer onboard. they were going to use it to pick up tubes and place it on the rack without using the cmu-2 cam. it was truly amazing
2. the killabytes i believe had these ultrasonic sensors and were doing some great work to program them on the practice field when i saw them. it was real interesting all the work that goes into a project like that.
2005- NJ rookie all-stars
2006- NJ judges award winners
NJ&Palmetto safety credit award winners
Palmetto finalists
2007-NJ Website award winners
NJ Motorola quality award and J&J sportsmanship award winner
Buckeye Motorola quality award winner
NJ #3 seed and semifinalist
2008NJ Chairman's Award
JOHNY FIVE is ALIVE!!
  #67   Spotlight this post!
Unread 28-03-2007, 23:50
EmilioM's Avatar
EmilioM EmilioM is offline
FRC #1717 (D'Penguineers)
EmilioM is a name known to allEmilioM is a name known to allEmilioM is a name known to allEmilioM is a name known to allEmilioM is a name known to allEmilioM is a name known to all
Send a message via AIM to EmilioM
Originally Posted by efoote868 View Post
Also, we are one of the few robots that hold the tube from the inside
We also picked up tubes via what we termed a "spreader" design, a claw which would pick up rings by exerting pressure on the inside of the tube. Pics to come...
Also, I'm not sure if there are many (or any) pictures of 207's claw. I saw the robot at LA and they had a fully articulating wrist on the robot which a 3-fingered claw. Very complex and cool...
1717 - BALLIN'
2007 San Diego Finalist
2007 San Diego Imagery Award
2007 Los Angeles Semi-Finalist
2006 Los Angeles Rookie All-Star
2006 Arizona Semi-Finalist
2006 Arizona Rookie Inspiration
  #68   Spotlight this post!
Unread 29-03-2007, 12:29
rsilverstein's Avatar
rsilverstein rsilverstein is offline
Ross Silverstein
rsilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant future
Send a message via AIM to rsilverstein
I don't know how to post pictures on a thread reply yet (if anyone wants to tell me that would be great), but here are photos of the "spreader" Emilio was talking about.
http://www.chiefdelphi.com/media/photos/28017
http://www.chiefdelphi.com/media/photos/28018?
Team 1717
9x Regional Winner
2x Division Finalist
16x Engineering/Design Awards
www.dpengineering.org
  #69   Spotlight this post!
Unread 29-03-2007, 13:45
TennBikeBerk TennBikeBerk is offline
FRC #1717
TennBikeBerk will become famous soon enough
Wink Re: Most Unique Features
  #70   Spotlight this post!
Unread 08-04-2007, 15:28
Hairygutball's Avatar
Hairygutball Hairygutball is offline
AKA: Slopsema
FRC #1504 (Desperate Penguins)
Team Role: Driver
Hairygutball has a spectacular aura aboutHairygutball has a spectacular aura about
that was our origonal design but we voted that it would take too much time to line up an grab. and its also alot harder to remove spoliers (as if its not hard enough as it is). I think that it gets a much stronger hold though. The arm design we ended up with is 12 inches long and has shifting size pneumatic that powers the finger, it works great except that it too weak under 45 psi.
Our Safety Captian lit his cat on fire
  #71   Spotlight this post!
Unread 08-04-2007, 16:19
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
FRC #0008 (Paly Robotics)
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
we had a great roller-based grabber (like 100). actually, we had three. the SVR one was popping tubes!
we also used a gas spring instead of surgical tubing to take the load off of our arm, and allow us to use the window motors to move our arm, which did have two motors on the end of it for the rollers. the part is pretty unique... i'll try to upload a pic when we can get back into our lab later this week.
they may not be the most elegant features, but they're pretty useful.
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
Most Impressive/Advanced/Unique/Cool drivetrain you've ever seen sanddrag Technical Discussion 41 03-06-2005 09:31
The most revealing teaser of any team yet!!! TEAM 41's UNIQUE BOT DoomdayX Robot Showcase 10 02-02-2005 20:12
What is your most loved and most hated video games of all time? Elgin Clock Chit-Chat 64 25-10-2004 09:41
What is your most loved and most hated video games of all time? Elgin Clock IT / Communications 8 14-07-2004 18:31
Unique FIRST archiver 2000 0 23-06-2002 22:53
