Go to Post 118 embodies everything this entire program is supposed to be about: INSPIRATION. Respect that. Acknowledge that. Support that. - barn34 [more]
Unread 30-03-2007, 11:22
thunderbolt thunderbolt is offline
FTC #3537
thunderbolt is an unknown quantity at this point
Using a limit switch
Help!!
how do i use a limit switch to stop a motor at a given point. i need this in autonomous mode
Unread 02-04-2007, 19:36
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Using a limit switch
var = GetDigitalInput(1);
if ( var == 1 )
SetPWM( 1, 127); // Stop the motor
Limit Switch for PCM GeorgeC Programming 4 16-02-2007 13:21
limit switch wedellm Electrical 4 16-02-2007 13:01
Limit Switch Basics JWSnedden Programming 6 30-11-2006 19:48
Limit switch in easy c? chadbarbe Programming 6 02-02-2006 09:51
