Go to Post I guess this is where theory vs reality comes into play. - PhilBot [more]
Unread 30-03-2007, 16:57
bcieslak
Posts: n/a
Re: Simple dead-reckoning autonomous
Team 1675 just updated their autonomous programming tool - AutoFlex2..no more messy cables and dangling laptops.
With a couple mods to your code, you basically push a record button on your OI then drive for 15 seconds. Whatever you recorded is what your robot will do during the autonomous mode. The input commands are stored in the RC's internal EEPROM.
Just go to the practice field, hit the record button, drive up to the rack and score the goal. Now its in memory. Make sure you start from the same position out on the playing field.
Its quick and easy. It takes about 15 minute to integerate into your code and learn to use.
We have modified a version of the default code you can use as an example for modifying your code along with some documentation.
Drop us an email at K9WIS@yahoo.com or stop buy our pit in Atalnta we'll have you up and runnning in no time.
Brian
Team 1675
PS it also works with VEX...
Autonomous: CMUCam or dead reckoning? Andrew Blair Rules/Strategy 18 26-02-2005 19:36
dead reckoning st28 Programming 1 24-02-2004 11:34
Dead Reckoning Ryan Cumings Programming 3 24-02-2004 10:57
A DEAD reckoning program rcubes85 Programming 5 19-03-2003 14:21
Probably already covered, but curious, Dead-reckoning or no? Dave Technical Discussion 3 11-01-2003 01:14
