Go to Post I don't care if my team wins. I care if they try their hardest to win. - pfreivald [more]
Unread 30-03-2007, 22:06
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Re: weird question that came up today
If your questions is "How?" the answer is pretty much that you can wire them in either serial or parallel.
If you wire them in parallel you will still have 12 volts but twice as much current available. This may also mean larger conductors of you plan on drawing that current quickly. If you did this in your currrent robot configuration now it would basically extend your run time to approximately double.
By wiring them in series you will get 24 volts and about the same amount of current capability you have now. Obviously this would mean a change to any components that would be sensitive to this higher voltage.
2016 Season; Game Announcer at
NYC Regional
SBPLI Long Island Regional
pic: Our wheels finally came in... funstuff Robot Showcase 15 23-08-2007 15:41
Weird question X-Istence Programming 2 16-07-2006 13:09
Just Came from Comp.!!!! NeedMoreEngines Regional Competitions 1 04-03-2005 19:17
to Me? or not to Me? That is the question. Coco the Monkey Chit-Chat 11 21-07-2003 01:39
Tables we came up with in Silicon Valley archiver 2001 2 24-06-2002 02:48
