Go to Post Hype levels are reaching critical levels... - wjd13 [more]
Unread 30-03-2007, 01:42
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
weird question that came up today
Is it possible to use 2 batteries to power a robot?
we were just thinking about it today and didn't know the answer
Unread 30-03-2007, 02:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: weird question that came up today
Possible? Yes. Legal in FIRST? No.
Unread 30-03-2007, 13:13
lenergyrlah's Avatar
lenergyrlah lenergyrlah is offline
FRC #1731 (Fresta Valley Robotics)
lenergyrlah is an unknown quantity at this point
<R46>
Items specifically PROHIBITED from use on the robot during competition matches include:
 More than one primary battery, or more than one back-up battery.
This is only part of the rule (other things are also prohibited).
2007 Rockwell Automation Innovation in Control Award
2006 Highest Rookie Seed Award
2006 Judges Award
Unread 30-03-2007, 19:42
Andy L's Avatar
FRC #1458
i know it isn't legal i was jsut wondering how
Unread 30-03-2007, 20:55
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
It's legal and it's recommended.
provided one of the batteries is a backup.
Hi!
Unread 30-03-2007, 21:06
I think he meant two 12V batteries
2006 Judges Award
Unread 30-03-2007, 22:06
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
If your questions is "How?" the answer is pretty much that you can wire them in either serial or parallel.
If you wire them in parallel you will still have 12 volts but twice as much current available. This may also mean larger conductors of you plan on drawing that current quickly. If you did this in your currrent robot configuration now it would basically extend your run time to approximately double.
By wiring them in series you will get 24 volts and about the same amount of current capability you have now. Obviously this would mean a change to any components that would be sensitive to this higher voltage.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 30-03-2007, 22:22
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Just to make this clear, he means DON'T DO THIS unless you replace all of the electronics with something that can handle 24 volts. Doubling your voltage is a good way to fry stuff.
Hooking 2 batteries in parallel would be a good idea for the old show robots. It's a pain to have to change the batteries every 5 minutes
Real programmers use vim.
Unread 30-03-2007, 22:37
Andy L's Avatar
FRC #1458
how do you wire them in Parralel(sp)
Unread 30-03-2007, 22:53
Scott team 48's Avatar
Scott team 48 Scott team 48 is offline
FRC #0048 (Delphi E.L.I.T.E.)
Scott team 48 is a jewel in the roughScott team 48 is a jewel in the roughScott team 48 is a jewel in the rough
Send a message via AIM to Scott team 48
To wire in parallel you just run a wire from the positive of one battery to the positive of the other, and then to the positive end of your Anderson connector. Do the same for the negative.
Delphi Elite
Unread 30-03-2007, 23:08
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Or see this attached image from http://www.vdcelectronics.com:
Unread 30-03-2007, 23:15
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
You can also just bolt another anderson connector on top of where the current one is attached to the main breaker and fuse block. Red to red, black to black. We did this for our t-shirt cannon because we were running two compressors, and it really helped.
Unread 30-03-2007, 23:18
Andy L's Avatar
FRC #1458
and then for future reference if I if i use two anderson connectors on a battery and plug one into bot and one into charger would i be able to plug it in and run without interruption?
Unread 31-03-2007, 09:43
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
No, the FIRST provided chargers wouldn't keep up with the amount of current that most robots draw. This also makes the charger work harder too, as it's trying to charge the battery but the battery is being drained as it's charging. You would also have a tether now on the robot bringing up another problem driving around.
I would suggest getting an extra battery or two for demonstrations. We keep our old ones that are still good for this purpose. Even though they are illegal for comp they can be used inaddition to the current ones for demos. We just keep swapping them out as they weaken/die and rotating them with charged ones as the others get placed on chargers.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 31-03-2007, 17:57
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
Wiring in series will fry all components sensitive enough. Can you place the ends of the two anderson connectors into the same holes/sockets in the fuse blocks, effectively creating a parallel circuit? Just a though, would it also increase battery life?
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
pic: Our wheels finally came in... funstuff Robot Showcase 15 23-08-2007 15:41
Weird question X-Istence Programming 2 16-07-2006 13:09
Just Came from Comp.!!!! NeedMoreEngines Regional Competitions 1 04-03-2005 19:17
to Me? or not to Me? That is the question. Coco the Monkey Chit-Chat 11 21-07-2003 01:39
Tables we came up with in Silicon Valley archiver 2001 2 24-06-2002 02:48
