Re: chain tool
We've been using the easy grip roller chain breaker mentioned above on #25 chain and haven't had any problems damaging links.
Re: chain tool
I don't work with #25, but on #35, I just grind off the end of the pins on a bench grinder and gently tap out the link being removed. I grind out part of the sideplate, so it comes out quite easily. It takes very little time, though it cah get a bit hot to hold onto
![]() Here's a breaker made in U.S.A. http://www.pattontool.com/25thru60.htm |
Re: chain tool
We also use the "Easy-Grip Roller Chain Breaker" and have had no problems with it. It takes less than 30 seconds to break a chain: Punch one side, punch the other and then twist the chain - Done
Re: chain tool
I have used the easy grip chain breaker for a good 6 years and NEVER had a problem. I have used it on 25 and 35
-Mike |
Re: chain tool
If you're looking for something like a chain puller, here's what we did: We bought a chain puller made for 35 chain, then took a dremel to the tips in order for it to fit between links of 25 chain. It's been working great for us for years.
As for breakers, we're using one made for 35 chain and bigger... and have never broken a link. |
Re: chain tool
So does nobody actually make chain pullers for #25? I've been trying to hunt one down.
#7
Re: chain tool
Have you checked Grainger?
| Chain Drive chain | Damelvin | 3D Animation and Competition | 2 | 15-02-2005 00:19 |
| Dynamic Debugging Tool | MarkVH | Programming | 5 | 04-02-2005 18:09 |
| New Tool? | Raven_Writer | Programming | 9 | 09-12-2003 16:57 |
| Tool for one, Tool for all | Gadget470 | Team Organization | 6 | 01-10-2003 02:41 |
| Chain and chain breaker source? | kmcclary | Off-Season Events | 4 | 22-10-2001 22:51 |
