Go to Post If I thank everyone that I want to, we might be here for a while - Karthik [more]
Unread 01-04-2007, 17:23
Generalx5's Avatar
Generalx5 Generalx5 is offline
Hard Core Inventor
AKA: Jun(John) Zheng
FRC #1346 (Trobotics)
Team Role: Student
Generalx5 will become famous soon enough
Program State red blinking
My program was running fine untill I shorted something out and after the Program state started blinking red. As if its in an infinit Loop, I can't Press the program bottom after, the LED would turn orange for a split second and go back to blinking red....Anyone know how to solve this problem? Or is there something wrong with my Mini RC...
Unread 01-04-2007, 17:53
Generalx5's Avatar
Hard Core Inventor
Team Role: Student
Re: Program State red blinking
I also tried the hold down program botton before the power on bottom and releasing the power before the program thingy, the result I get is Power on blinking with a solid green Program state. I cant press program or turn off at this point...Don't know whats wrong...
Unread 01-04-2007, 18:57
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
I could not find anything that would help you on IFI's website, but if you still can not figure out what is wrong, I suggest you call IFI [Tech Support (903.453.0801)] and ask them to help you. They may even be able to replace it for you if it is still under warranty.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 01-04-2007, 20:34
Generalx5's Avatar
Hard Core Inventor
Team Role: Student
I cant aford to rma my stuff, I have a science fair presentation comming up and I will be needing the MINI RC in my project....gosh, Im so owned. I wish the IFI support could call me back tomorrow and suggest a fast solution that we are all not aware of.
Unread 01-04-2007, 20:54
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
What did you short out? And, try resending your code even though the controller says that its not in program mode..
Unread 01-04-2007, 22:16
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
According to the Mini RC Manual .. Section 12 lists all the LED information
Continuous blinking – Program is in an infinite loop.
Five blinks before turning solid – Invalid register accessed in user
program.
http://www.ifirobotics.com/docs/lega...2004-Mar-1.pdf
Something worth pointing out from Section 14 ..
Also, if the PROG button is pressed at the same time as you turn on the unit, diagnostic mode will be entered and the LEDs will cycle through a distinctive pattern. This mode is not useful for users and the user program will not execute. Simply power cycle the unit to return to normal operation.
You should be able to program the RC though .. maybe IFI can shed some light on this.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 01-04-2007, 22:58
Generalx5's Avatar
Hard Core Inventor
Team Role: Student
I've tried that, I cant upload any code even at the diagnostic. I've contacted them via voicemail and email. Hopefully They can let me know how to fix it without sending it back...
Unread 01-04-2007, 23:17
Generalx5's Avatar
Hard Core Inventor
Team Role: Student
Im not sure...I think I did because I saw a small spark...but right after that...the program crashed and indicated infinit loop. recovery was not possible. Even the FORCE PROGRAM does not work, I just get a blinking Battery power LED and a solid Program state LED..Sigh.
Unread 02-04-2007, 12:05
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
A spark across what pins?
By the sound of it, you may have killed the user processor. (Although they tend to safeguard the processors pretty well, I think.) If the master processor is still operating but the user processor is dead, it might create the symptoms you are seeing.
Has IFI said anything yet?
Unread 05-04-2007, 00:38
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
1351's usual procedure for unknown blinking light problems:
1. Cycle power. Eliminates some hardware problems.
2. If that doesn't fix it, load default code. Eliminates problems with your code.
3. If that still doesn't fix it, reload master code. Effectively puts software back to factory state.
4. Call IFI. Never got this far before.
Your spark leads me to believe that it's a nasty hardware issue though.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 05-04-2007, 18:39
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
i'm having a similar problem....see my post in the 'control systems' forum...
Unread 05-04-2007, 19:01
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
I'd be inclined to agree with that. Short protection can only do so much for microcontrollers, their IO pins are only really meant to source low current draws (typically less than 100-200mA). What voltages are you using it with? If you have greater voltages on board than the RC's logic voltage and they got shorted onto an input it could very easily blow it out. I had this problem about a month ago in one of the designs I was working with where a 12V line got shorted onto the 5V bus taking out two micros and an LCD, even though the short was only for about 1-2 seconds. I hope you get it fixed but from the sound of things it may not be doable unfortunately.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Blinking Red Light teh_pwnerer795 Programming 8 21-12-2006 23:13
Program light is blinking red elsacr FIRST Tech Challenge 1 27-02-2006 10:23
Blinking Program light on RC jgannon Programming 2 16-02-2005 22:45
'Program State' LED stays blinking yellow after download clynch Control System 5 18-02-2004 19:34
RC program state problems Max Lobovsky Programming 3 14-02-2004 15:02
