Re: Bad Call?
It may not be the right call, but it seems consistent with what has been happenning at other regionals. The exact same thing happened to us at GLR.
Re: Bad Call?
It is the right call, as shown by the Q&A answer above.
Re: Bad Call?
In this case though, the tube could have been removed and we would have lost no height whatsoever.
Re: Bad Call?
While I don't like the way the rule is interpreted, the call is the right one (as it conforms with both the rulebook and the Q&A clairification)
**Big hint to all rampbots** Make sure the area is clear, even of deflated tubes, before deploying your ramps. There is a good thread in YMTC http://www.chiefdelphi.com/forums/sh...highlight=YMTC |
Re: Bad Call?
Can I please get a link directly to the Q&A about this?
Re: Bad Call?
#7
Re: Bad Call?
This is the best I can do for you:
http://forums.usfirst.org/showthread.php?t=1522 If you see the thread that Joe linked, there's a lot of discussion as to what "SUPPORTED" means, because it isn't defined in the manual. I'm pretty sure that nobody wants to carry on that particular debate any more. Personally, I don't agree with what the GDC is calling "SUPPORTED", but all I can ever ask for is that the rules are enforced consistently, regardless of how ridiculous the rule is. Tubes that are touching the underside of lifting robots have negated all lifts at every event I have attended or watched, and I applaud the refs for being consistent. |
#8
Re: Bad Call?
We were on the other side of a ruling like this in palmetto. During our semi final match, the opponent had two robots lifted and was ruled that the bottom robot was touching a field element and did not give the 60 points and then we came back for our second match and found out that the ruling had been reversed and we were now the losing team. They stated the reason was that the lifting robot could touch a field element but the two robots on the ramp were not touching anything so they adjusted the score and we lost that match.
#9
Re: Bad Call?
Re: Bad Call?
we were just told that the lifiing bot was touching a tube. And we were not told that until we went to the floor for match two and the announcer said that it was 1-0 red when we thought it was 1-0 blue when we left the floor after seeing the score on the screen. It did not matter, they were a very good alliance with the arms and the ramps together.
#11
Re: Bad Call?
This call was very tough for the refs and i can fully explain the situation. The ramp bot deploys one very big ramp with two sides that are connected with one piece of fabric. the ramp delopys and makes a very big ramp simialr to the aim high ramp. one side of the ramp deployed on top of two innertubes. The platform of the ramp did not rest on any tubes and the only tube under the ramp was stuck on a support leg that was in the middle of the tube so the tube could not be removed. the other tube was under the ramp leader up to the platform an was hold up the ramp, but not the platform that held the robot. Other the other side of the ramp, the other robot got up and there were no tubes under it.
The refs call was that the tubes under the ramp supported the ramp which was connected to the platform which was connected to the other half of the ramp and platform by a piece of fabric so the other robot also did not count. My only dislike with the call was that the second robot was not counted even though their ramp had no innertubes near it. that was a terrible call, but the one 12 inch bonus wouldn't have won the match anyways. |
#12
Re: Bad Call?
We were the victims of the rule at Peachtree and the beneficiary yesterday at Palmetto. After the call at Peachtree, we discussed the interpretation and realized that the approach that First has taken is the only way to consistently enforce the rule. The GDC certainly does not want to make the referees determine whether or not a game piece provides assistance to a ramp, so the mere presence of a tube under the ramp is grounds to disallow points.
I am surprised that the placement of a tube under a ramp bot (before deployment) is not used as a tactic to at least hinder some of the really good ramps, such as 1319. |
#13
Re: Bad Call?
I'm more surprised that taking a 10 point penalty (being in the opposing teams home zone at the end) and stuffing a tube under the ramp bot (thus negating a 60 point lift) hasn't become a tactic.
#14
Re: Bad Call?
it is becoming a strategy, and was used several times at Long Island - knowking the tubes down tubes along the back wall or placing one near a ramp bot to make it tougher for a ramp bot to deploy or for some robots to climb.
#15
Re: Bad Call?
The same thing happened to 195,558,1124 at UTC in the semi-finals when 195 was touching a tube while supported by 558's ramp. This is just a rule that has to be followed. Luckily it was the first semi-final and we won the last two to move on.
| Where did all the "bad call" threads go this year? | sw293 | Rules/Strategy | 5 | 28-03-2006 17:59 |
| Bad Call at Angels Sox game | sanddrag | Chit-Chat | 32 | 20-10-2005 10:57 |
| How "bad" are motors with "bad" stickers? | cooknl | Kit & Additional Hardware | 20 | 12-01-2005 10:33 |
| Call me an optimist... | Eric Tarnowski | General Forum | 3 | 02-10-2001 16:55 |
