Go to Post Just remember to never take the "Us vs Them" mentality and you should come out all right. - Ian Curtis [more]
Unread 01-04-2007, 01:43
alysume alysume is offline
FRC #0192
alysume is an unknown quantity at this point
chain tool
Does anyone know a source for chain tools for #25 chain? Our team has been getting along with a bicycle chain tool style one for a while, but we broke it for good recently. There are many tools online for bicycle chain, but we haven't been able to find any that specifically fit #25 chain. Anyone know where we can find one?
Unread 01-04-2007, 02:16
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: chain tool
One chain tool that I know many teams recommend is the Easy-Grip Roller Chain Breaker from McMaster-Carr. That is what our team used this year and it worked well.
You want the one for chain sizes 25-60. Part #6051K15
Unread 01-04-2007, 02:22
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
Re: chain tool
Assuming that you are talking about a chain breaker, id like to advise you against it, from my experience with 25 chain, chain breakers tend to ruin the surrounding links, however an effective method that you could try is with a Dremel and center punch, What we do, is use the dremel to grind away the tip of the pin until just past the surface of the link itself, once its at that point, take the center punch, and align it with the pin, and gently knock it out with the center punch, and voila you then have separate pieces of chain, and assuming it is done right, they will not be damaged...
however if you do wish to use a chain breaker instead here are a few links that can help you out
http://www.mcmaster.com/ ****
http://www.smallparts.com/products/d...ons/rcb-cb.cfm
****page #985 as aforementioned
Blargha!
Unread 01-04-2007, 14:17
AdamHeard's Avatar
Lead Mentor
Re: chain tool
We've been using the easy grip roller chain breaker mentioned above on #25 chain and haven't had any problems damaging links.
Unread 01-04-2007, 14:53
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: chain tool
If you use a chain breaker not meant to be used for #25 chain you will damage the links. If it is made to be used with #25 chain and it is damaging link I highly doubt that the company would still be selling it.
-John
Unread 01-04-2007, 14:54
Dick Linn's Avatar
no team (Synergy)
Re: chain tool
I don't work with #25, but on #35, I just grind off the end of the pins on a bench grinder and gently tap out the link being removed. I grind out part of the sideplate, so it comes out quite easily. It takes very little time, though it cah get a bit hot to hold onto
Here's a breaker made in U.S.A. http://www.pattontool.com/25thru60.htm
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 01-04-2007, 19:39
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: chain tool
We also use the "Easy-Grip Roller Chain Breaker" and have had no problems with it. It takes less than 30 seconds to break a chain: Punch one side, punch the other and then twist the chain - Done
Unread 01-04-2007, 22:53
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: chain tool
I have used the easy grip chain breaker for a good 6 years and NEVER had a problem. I have used it on 25 and 35
-Mike
Unread 02-04-2007, 00:17
CraigHickman
Posts: n/a
Re: chain tool
If you're looking for something like a chain puller, here's what we did: We bought a chain puller made for 35 chain, then took a dremel to the tips in order for it to fit between links of 25 chain. It's been working great for us for years.
As for breakers, we're using one made for 35 chain and bigger... and have never broken a link.
Unread 05-04-2007, 02:46
atifce atifce is offline
Junior Member
FRC #0005
atifce is an unknown quantity at this point
Question Re: chain tool
Hi!
I have to convert : Delphi 5 to Delphi DotNet.
can any one help me?
Regards
Aatif
Unread 05-04-2007, 09:07
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: chain tool
Originally Posted by atifce View Post
Hi!
Regards
Aatif
Perhaps you should refer to this thread that you already started:
http://www.chiefdelphi.com/forums/sh...ad.php?t=56577
Jacob
Unread 05-04-2007, 13:06
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: chain tool
So does nobody actually make chain pullers for #25? I've been trying to hunt one down.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 05-04-2007, 13:17
lancerbotics's Avatar
lancerbotics lancerbotics is offline
FRC #2250 (Lancerbotics)
lancerbotics is an unknown quantity at this point
Re: chain tool
Have you checked Grainger?
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
Dynamic Debugging Tool MarkVH Programming 5 04-02-2005 18:09
New Tool? Raven_Writer Programming 9 09-12-2003 16:57
Tool for one, Tool for all Gadget470 Team Organization 6 01-10-2003 02:41
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
