Go to Post The very fact that parts are rumored to be being re-used may be sufficient reason for the rule-makers to change a rule to prevent the re-use of that very part (not that they would ever be that devious!) - dlavery [more]
Unread 01-04-2007, 21:43
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: pic: 254/968 Transmission
Lightening the aluminum gears doesnt have nearly as big of an impact as lightening the same sized steel gears, obviously. The weight was removed because it could be. For the designed power constraints and face widths, the added material in the web was of no real benefit. For most of the gears we designed, we were able to remove more than half of the total gear weight using pockets and holes.
These gearboxes have 2 small CIM's per side.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
pic: 254 and 968 on Newton alphaone Extra Discussion 10 17-02-2007 08:28
pic: 254/968 Powder Coated Parts ejSabathia Robot Showcase 26 16-02-2007 13:50
pic: 254/968 Machined Parts Cory Robot Showcase 11 12-02-2007 07:42
pic: more unfinished parts... 254/968 ejSabathia Extra Discussion 1 03-02-2007 12:16
pic: Anodized Parts 254/968... ejSabathia Extra Discussion 12 02-02-2007 15:31
