Go to Post Yeah, if we didn't have robots then we could concentrate on all that outreach stuff! - marshall [more]
Unread 23-02-2007, 20:14
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: pic: 254/968 Transmission
Sounds Awesome. You go to Cal Poly Pomona right?
Yes
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 01-04-2007, 21:20
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
That is quite amazing, but why #25 chain? We used it our rookie year and it broke almost every match we had (However mind you we were using a plywood robot and had a heavily cantileavered kit drill motor transmission, and a really bad tensioner!). Has 254 and 968 had those problems?
Unread 01-04-2007, 21:33
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Nope. No problems. In the two years I've been on the team, we've never broken a chain. As long as it's properly aligned and tensioned it should be fine.
2001-2004: Team 100
2006-Present: Team 254
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Travis,
This is just another beautifully made/designed part of your robot. While building our robot, we're almost always limited by our machine shop, and the time spent on the machines. Do you know how much weight all the lightening holes and treepans remove? I'm trying to determine how much "time for weight" is involved in these transmissions. (I won't even ask about all the heat treating and anodizing time!)
Also, I believe this is a single CIM gearbox, right? Have you found any lack of pushing power even when you're in low gear? We used the Dewalt 3-speeds with a single CIM last year and found that we were still being pushed (well, rammed) around by kitbots.
Thanks,
BEN
Unread 01-04-2007, 21:43
Engineering Mentor
FRC #0254
Lightening the aluminum gears doesnt have nearly as big of an impact as lightening the same sized steel gears, obviously. The weight was removed because it could be. For the designed power constraints and face widths, the added material in the web was of no real benefit. For most of the gears we designed, we were able to remove more than half of the total gear weight using pockets and holes.
These gearboxes have 2 small CIM's per side.
-Travis Covington
Unread 01-04-2007, 21:44
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
I figured out how it weighs so little! It doesn't weigh in lbs., it weighs in # of transmissions on the scale.
Very nice job, looks cool too.
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 01-04-2007, 22:12
chaoticprout's Avatar
chaoticprout chaoticprout is offline
can't wait for next years VRC
AKA: Michael Montazeri
FRC #1138 (Eagle Engineering)
chaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant future
Send a message via AIM to chaoticprout Send a message via MSN to chaoticprout
I told Kirk this in LA when he was showing it to us, simply amazing. I'm very saddened to hear that you guys are not going to Atl this year. Awesome job in general, the gearbox is awesome.
2009 Los Angeles Regional - Chairman's Award
2009 Granite State Regional - Engineering Inspiration Award
2007 Los Angeles Regional - Engineering Inspiration Award
2006 Southern California Regional - Regional Champions
Unread 01-04-2007, 22:25
CraigHickman
Posts: n/a
Just a question for us in the California area looking to improve our transmission weight for next year (aka me)...
Where did you guys purchase your delrin sheets? And how did you go about getting the 7075 and 7068 gears?
Unread 01-04-2007, 22:38
Engineering Mentor
FRC #0254
We got our delrin from mcmaster.
The gear blanks were all made from round aluminum barstock, turned, milled, hobbed, pocketed, and anodized by either Kirk or one of our teams few local sponsors.
SDP and others sell some aluminum gears, but nothing in the face widths, pitch, or materials that were required to build the transmission we wanted.
-Travis Covington
Unread 01-04-2007, 22:50
CraigHickman
Posts: n/a
Say I were interested in finding my own way to get gears this light... Would it even be plausible to look around at local companies to have them done? Basically, what kind of cost went into these, and was the weight loss worth it?
Unread 01-04-2007, 22:55
pepe pepe is offline
The one and only
AKA: Chris Lee
FRC #0254 (Cheesy Poofs)
pepe is an unknown quantity at this point
I'm sure if you look around you can probably find some company who may offer to sponsor you with some materials. The majority of the cost went into the machining process, which was graciously donated by the sponsors.
The reason we cut down the weight on the gearboxes (from 4.6 lbs to 1.3) was to have more room to work with weight-wise.
Go Poofs!
See you at nats!
Unread 01-04-2007, 23:02
Engineering Mentor
FRC #0254
I have told this to those who asked me similar questions in person, and I will go ahead and say this to everyone interested.
If this were not Kirk and my senior project, there is no way we would have taken on this much work for this much (little) weight savings. While 2+ lbs per transmission is significant, the 500+ hours that went into getting these made was most definitely not worth it. For us, we were killing two birds with one stone, which made sense. We would have had to put in a similar amount of time doing a senior project totally unrelated to FIRST, so why not spend that time on the robot?
Bottom-line, for a FIRST robot, this is beyond overkill. Next year we will be designing everything around what andymark already makes and sells for a ridiculously low price. A few of his gears with our own sideplates and shafts, and I am a happy camper. Time and resources are spent much better elsewhere, take my word for it.
-Travis Covington
Unread 01-04-2007, 23:10
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
How does the output shaft work?
And by that i mean, it appears the shaft with the dog is the same line as the output shaft, from looking at this picture.
Because the shaft moves side to side to actuate the dog it would seem that the entire output shaft would shift from side to side. It would cause a problem if a wheel was attached to a shaft that slides from side to side each time the transmission is shifted. What kind of mechanism keeps this from happening?
Also, apparently there are two sprockets on the inside, (or one double sprocket), but there is also that big red thing sticking out one end. Is is right to assume that the red thing powers the center wheel and the two sprockets power the front and rear wheels, and that the big red thing also contains the mechanism i was wondering about earlier? and if so, why does the blue one shown on the scale not have the this mechanism?
Unread 01-04-2007, 23:15
Engineering Mentor
FRC #0254
The shaft does not move. The shifting shaft (not shown) which the dog screws into moves inside of the output shaft.
The red thing is stricly a bearing housing which mounts to the side rail. The center wheel mounts on the smallest hex of the output shaft. The front and rear wheels are powered with chain and sprockets, as you guessed.
-Travis Covington
Unread 01-04-2007, 23:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
The output shaft does not move axially/linearly. There is a hole drilled in the back end of it, and a "shifting rod" inside it which connects the pneumatic cylinder to the shifting dog. Just like any other dog shifting transmission I've ever seen (andymark, etc)
The "red thing" is a pillow block that carries the outer bearing for the output shaft. It does not move. The wheel is driven by the hex milled in the end of the output shaft. Not shown is the frame rail to which the gearbox face mounts. The frame "red thing" goes through the frame rail. Tha flange sits on the outside, and the face of the gearbox sits smack up against the other side of the frame rail. Very clean.
EDIT: Travis beat me to it. But yes, what he said ^^
pic: 254 and 968 on Newton alphaone Extra Discussion 10 17-02-2007 08:28
pic: 254/968 Powder Coated Parts ejSabathia Robot Showcase 26 16-02-2007 13:50
pic: 254/968 Machined Parts Cory Robot Showcase 11 12-02-2007 07:42
pic: more unfinished parts... 254/968 ejSabathia Extra Discussion 1 03-02-2007 12:16
pic: Anodized Parts 254/968... ejSabathia Extra Discussion 12 02-02-2007 15:31
