Go to Post I would be kinda creeped out if I was one of the "famous" FIRST people. Why? Because no one is any different than anyone else in my eyes. Granted, some people stand out more, but that is because the other people might not have gotten a chance yet to shine. - Melissa Nute [more]
  #31   Spotlight this post!
Unread 01-04-2007, 23:44
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
Re: pic: 254/968 Transmission
Ok, I understand the pillow block now, but how exactly does the shifting rod work? I dont see how anything is or can be connected to the dog except for the output shaft because it spins with the shaft. You said it was inside the main shaft, only its only connected to the dog and not the other gears?
Edit:
I think i can see the shifting rod here, but im still not sure how it connects to the dog.
  #32   Spotlight this post!
Unread 01-04-2007, 23:55
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
We use a screw to connect the shifting shaft to the dog. There is a slot in the output shaft which gives the screw/shaft/dog clearance to slide back and forth, engaging one or the other gears.
Here is a cutaway that team 45 posted a few years back showing how it works.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
  #33   Spotlight this post!
Unread 02-04-2007, 02:23
How are the gears holding up for you guys? I saw what I consider significant wear on the Poof's practice robot, but I am no expert on gears.
  #34   Spotlight this post!
Unread 02-04-2007, 02:27
Engineering Mentor
FRC #0254
The teflon dry lube was wearing off, I assume. The comp bot has some of that, too. It really is of little concern. The teeth on all four of our bots are in better condition than the steel gears that we ran last year with the same amount of driving time. I am quite surprised with how well they are wearing. The 20 pitch gears show absolutely no wear whatsoever. The 32 pitch show some wear on the endges, but only slight anodize and drylube wear. Again, the teeth look pretty good on all of them though.
-Travis Covington
  #35   Spotlight this post!
Unread 02-04-2007, 02:38
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
After reading the poster, I was wondering what you meant by "clutchless" since you are using a positive clutch for dog shifting.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
  #36   Spotlight this post!
Unread 02-04-2007, 02:46
Engineering Mentor
FRC #0254
It isn't really a clutch. This transmission design is most commonly found on motorcycles, with the addition of a clutch of some sort. An electric motor allows you to remove the clutch, simply due to the fact that the motor works from 0 rpm onward. An IC engine on the other hand, has an idle that would otherwise prohibit the vehicle from stopping completely without a nuetral position or a clutch. The starting and stoping are the primary needs for a clutch with an IC engine/motorcycle tranny. It is quite common to not use the clutch when shifting a motorcycle by simply easing off the throttle and engaging the next gear so long as you are already moving.
By clutchless, I meant lacking a means to engage or disengage the power coming from the motors feeding the output shaft.
-Travis Covington
  #37   Spotlight this post!
Unread 24-04-2007, 14:12
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Have you posted your actual gear ratios and final specs for this transmission yet?
If not, please do so. I was very impressed with the design! I'd specifically be intersted in the gear ratios. Thanks
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
  #38   Spotlight this post!
Unread 24-04-2007, 15:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
deleted - nvm
  #39   Spotlight this post!
Unread 24-04-2007, 15:57
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
irrelevant. -mk
--Madison--
...down at the Ozdust!
  #40   Spotlight this post!
Unread 24-04-2007, 16:12
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Got an drawing of it by any chance? Just curious.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
  #41   Spotlight this post!
Unread 24-04-2007, 16:13
Engineering Mentor
FRC #0254
We still have not completed our final technical paper on the transmissions ourselves for school, so it'll be a while til we make any sort of white paper to post here on CD.
As for the ratios, the initial 32 pitch reduction has 20 tooth pinions and an 80 tooth driven gear. High gear reduction is 45:30, low gear is 60:15, driving a 4" diameter wheel.
-Travis Covington
  #42   Spotlight this post!
Unread 24-04-2007, 16:18
in between teams
AKA: Luke Van Oort
Could you just post your paper for school when it is done?
Team 1219: 2009 - Mentor
  #43   Spotlight this post!
Unread 24-04-2007, 16:25
Engineering Mentor
FRC #0254
We haven't decided. Most likely, if anything, we will write a brief overview of the FIRST related uses of what we did. The rest of the paper really isn't useful or appropriate for the CD community.
-Travis Covington
pic: 254 and 968 on Newton alphaone Extra Discussion 10 17-02-2007 08:28
pic: 254/968 Powder Coated Parts ejSabathia Robot Showcase 26 16-02-2007 13:50
pic: 254/968 Machined Parts Cory Robot Showcase 11 12-02-2007 07:42
pic: more unfinished parts... 254/968 ejSabathia Extra Discussion 1 03-02-2007 12:16
pic: Anodized Parts 254/968... ejSabathia Extra Discussion 12 02-02-2007 15:31
