Go to Post Robot: Aww, the FMS doesn't want to chat with me anymore. Was it something I said? - EricVanWyk [more]
Unread 02-04-2007, 06:49
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: AM shifter problems
Originally Posted by squirrel View Post
Also it will help us help you if you give a complete description of your drivetrain/chassis....ratios, width, wheelbase, number of wheels, tread type, whether the center wheels are lower than the end wheels and by how much, etc.
Long, narrow, 4 wheel robots with sticky tread, and not much final drive reduction, just don't turn easily. Wide, short, 6 wheel bots with lowered center wheels, not so aggressive tread, and more final reduction turn just fine in high gear.
I'm guessing a 4x4 with a long wheelbase... take a look at this white paper. <edit> Titled: Drive Train Basics
(How to Be Sure Your Robot Will Turn)</edit>
http://www.chiefdelphi.com/media/papers/1443
Mark
Brick walls are for other people. - Randy Pausch
How to turn down gear hubs? sanddrag Technical Discussion 12 20-01-2004 09:10
motor high gear/low gear switch... archiver 2001 6 23-06-2002 23:50
low gear vs high gear archiver 2000 1 23-06-2002 23:07
Robot Turn-in Mike Martus Off-Season Events 0 08-11-2001 19:32
Gear Ratio Doesn't Matter Paul Copioli Technical Discussion 2 27-09-2001 08:18
