Go to Post I quickly realized that, "hey, I'm looking at a wonderful piece of technology that defies gravity" and I calmed down quite a bit. - Elgin Clock [more]
Unread 02-04-2007, 08:14
Re: AM shifter problems
Originally Posted by JohnMorenski View Post
low gear works great, but in high gear. we cannot turn in high gear, the battery voltage on the O/I drops and the motors seem to stall,
This is a classic symptom of too much friction in turns. As other have pointed out, your drivetrain and final gear ratio couple to produce near stall current on the drive motors. The small Chalupas stall at 129 amps while the larger ones stall at 96 amps. Add that up and you are likely drawing something in the neighborhood of 300+ amps even if your wheels are turning. With a fully charged battery with an internal resistance of .011 ohms, you are already dropping 3.3 volts at the battery, plus whatever series resistance you have in the wires. Remember that the RC will go to backup mode when the input voltage falls below 8 volts and all outputs are disabled. As you draw current from the battery, that voltage drop takes you seriously close to the magic 4 volt drop and RC shutdown.
How to turn down gear hubs? sanddrag Technical Discussion 12 20-01-2004 09:10
motor high gear/low gear switch... archiver 2001 6 23-06-2002 23:50
low gear vs high gear archiver 2000 1 23-06-2002 23:07
Robot Turn-in Mike Martus Off-Season Events 0 08-11-2001 19:32
Gear Ratio Doesn't Matter Paul Copioli Technical Discussion 2 27-09-2001 08:18
