Go to Post FIRST really does enjoy watching us squirm with their teasers, don't they? - Anupam Goli [more]
Unread 01-04-2007, 22:15
JohnMorenski's Avatar
JohnMorenski JohnMorenski is offline
AKA: Rusty
FRC #1647 (Iron Devils)
Team Role: Driver
JohnMorenski is an unknown quantity at this point
Robot doesn't turn in high gear
well i know that this has been posted before but i also know that other teams are having this problem and im sure they want all the info they can get. it seems that we are not getting the full potential out of our andy mark shifters not in low gear, low gear works great, but in high gear. we cannot turn in high gear, the battery voltage on the O/I drops and the motors seem to stall, we are using 1 big cim and 1 little cim on each gearbox any input????
would it be a smarter choice to switch to 2 small cims on each gearbox??
thanks
Unread 01-04-2007, 22:22
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: AM shifter problems
You're generating more torque in low gear, which means your robot will experience more torque when trying to turn, resulting in better turning. There are a number of ways to solve this problem. Increasing the torque in your shifters (by switching to 2 small CIMs) is one option. Another would be reducing the ratio between your shifters and wheels, and/or using smaller wheels (both of those would reduce your speed though). You may also want to consider lowering the traction of your wheels, or even using a pair of omni wheels to improve turning.
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
thanks
How fast are you going while in low gear? It sounds like your after-gearbox ratio may be too low... you may need bigger sprockets on your wheels to slow down a bit.
Andy B.
Unread 02-04-2007, 01:20
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Also it will help us help you if you give a complete description of your drivetrain/chassis....ratios, width, wheelbase, number of wheels, tread type, whether the center wheels are lower than the end wheels and by how much, etc.
Long, narrow, 4 wheel robots with sticky tread, and not much final drive reduction, just don't turn easily. Wide, short, 6 wheel bots with lowered center wheels, not so aggressive tread, and more final reduction turn just fine in high gear.
Unread 02-04-2007, 06:49
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
I'm guessing a 4x4 with a long wheelbase... take a look at this white paper. <edit> Titled: Drive Train Basics
(How to Be Sure Your Robot Will Turn)</edit>
http://www.chiefdelphi.com/media/papers/1443
Mark
Brick walls are for other people. - Randy Pausch
Unread 02-04-2007, 08:14
This is a classic symptom of too much friction in turns. As other have pointed out, your drivetrain and final gear ratio couple to produce near stall current on the drive motors. The small Chalupas stall at 129 amps while the larger ones stall at 96 amps. Add that up and you are likely drawing something in the neighborhood of 300+ amps even if your wheels are turning. With a fully charged battery with an internal resistance of .011 ohms, you are already dropping 3.3 volts at the battery, plus whatever series resistance you have in the wires. Remember that the RC will go to backup mode when the input voltage falls below 8 volts and all outputs are disabled. As you draw current from the battery, that voltage drop takes you seriously close to the magic 4 volt drop and RC shutdown.
Unread 02-04-2007, 11:57
AKA: Rusty
Team Role: Driver
Re: Robot doesn't turn in high gear
its definatlly the fact that we have the 1 big and 1 small cim, were going to have to swap over to 2 small cims
thanks guys
Unread 02-04-2007, 12:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
thanks guys
This will help some, but I still think either your wheels are too grippy, your wheel base is too long, your track width is not wide enough, and/or you do not have enough reduction between the gearbox and the wheels, with the latter being most likely.
How many teeth are on the sprocket on the wheel? How big are the wheels?
Unread 02-04-2007, 12:08
Brandon Holley's Avatar
thanks guys
Im sure a big cim and small cim will work just fine, but i think the easiest fix would be to get some bigger sprockets on those wheels.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 02-04-2007, 12:21
Billfred's Avatar
Billfred Billfred is offline
thanks guys
I'm not so fast to pin it all on the large CIM. Sure, it's got its faults (weight and relative lack of power compared to its smaller sibling being the largest), but it does have its highlights. (We ran this exact setup at Palmetto in a 6WD configuration, and it turned smooth as butter.)
I'm also inclined to pin it on a configuration issue along the lines of sanddrag's post, we can't be sure without getting more details (sprocket sizes, wheel coefficients of friction, etc.) without pictures (CD-Media is a wonderful thing) or more details.
Unread 02-04-2007, 12:48
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
I've seen their setup first hand. They have four 8"(?) custom traction wheels in back and 2 AM omni's in front. After watching them at Philly, their low gear was relatively fast, very similar to our speed, but we used the AM Single Speed Gearboxes on a 1 to 1 output to wheel ratio. So I would suggest that you increase the size of your sprockets on the wheels, decrease the size from the gearbox, or even both. That hopefully should help with the turning problem.
-Chuck
Unread 02-04-2007, 14:28
newton418's Avatar
newton418 newton418 is offline
AKA: Ryan Newton
FRC #0418 (Purple Haze)
Team Role: Driver
newton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to all
Team 418 used a 6 wheel drive, 4 small CIM-DeWalt transmission drive train. We lowered the center wheels 3/32", which is enough to sink the center wheels in the carpet, but still have all 6 wheels contact the ground. In 2nd gear we realized we had some difficulty turning (the RC was resetting, I believe), and after talking with the electronic guys we think we figured out why. When designing the drive train, I figured we could run each small CIM at 40 amps (since they are on a 40 amp breaker); however, I was informed that the power distribution block is rated for 85 amps (I'm not exactly sure, but around this number). This means we weren't getting the current, and thus the torque, we had planned on. Perhaps you guys are facing a similar problem.
Team 418 Purple Haze
http://www.lasarobotics.org/
Unread 02-04-2007, 15:01
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
That's a start. It's going to give you more power and less traction (as small CIMs will save a good chunk of weight). But seeing as the description of your gearing, you will probably have to reduce your speed to get better results (it's too late to adjust your wheel base most likely). Get some bigger sprockets and/or smaller wheels.
Unread 02-04-2007, 15:22
This is another one of the myths of electrical design. The Rockwell blocks are designed for continuous current of 85 amps per block. The 40 amp breaker will function with up to 600% of it's current trip rating for several seconds. Neither of these devices limit the current to that of their ratings. But there are limiting factors in the wiring of the robot. Things to consider are the series resistance of the wire, terminals, Victors, and distribution. A simple rule of thumb I use is the "wire/foot" or WF. It is simple to equate series resistance with the resistance of a foot of #10 wire which is .001 ohms. Using this as a rule of thumb, then the battery has 11 WF internally, the #6 feed wiring has 0.5 WF per foot of wire (you must include both the postivie and negative wire) while the #12 has almost 2 WF per foot, the Victors have 4 WF of series resistance and you can have between 1 and 3 WF for every crimp if not done with proper tooling, not tight on the block or screw terminal or not fully crimped. So, how does this affect your design? At 100 amps of current (roughly the stall current of either Chalups motors or the old FP motors) each wire foot will drop 0.1 volt. Just take a look at the circuitry that feeds your motor, add up the resistance using this method and multiply by 0.1 to find the voltage drop to your motor.
Ex. 4 ft #6 wire, breaker panel, one victor, 4ft of #12 from fuse panel to Victor to motor, 20 connections= (4x0.5)+1+4+8+20=35x0.1=3.5 volts drop in all losses at stall. This translates to a loss of about 1/3 of the available current or about a loss of almost 100 oz.in. of torque and a drastic change in the efficiency.
Unread 02-04-2007, 19:41
newton418's Avatar
AKA: Ryan Newton
Team Role: Driver
I was aware that the 40 amp breakers could be pushed past their limit for small amounts of time, but decided to design the drive train such that we wouldn't need to constantly push the breakers, since we could get sufficient performance at 40 amps. I am much less familiar with the Rockwell blocks, since they are new and I do not work on the electronics. I figured that since they are rated for 85 amps they could be pushed past this limit, but I have no idea by how much or for how long. Could you further explain what the Rockwell blocks can actually handle?
As for the resistance in the circuitry, we kept the wire lengths to a minimum, and will definitely be more conscious of it in the future; however, I do not understand how this would fully explain our problem. At 40 amps, a small CIM outputs ~.8 N*m (please correct me if my calculations are wrong), and IF we could run them significantly beyond this, say, near stall current, then even if you take the ~2.2 N*m stall current then the wire resistance would have to be somewhere around 76 WF. Though I am not the most familiar with our electronics system, I am confident it does not have this much resistance. Now, I did make several assumptions when calculating the torque needed to turn in 2nd gear, so in actuality .8 N*m of torque might not have been enough; but, assuming that the difference is negligible, how do you explain the problems we faced?
Also, I have just talked to our electronics/code mentor and he suggested that we bypass the Rockwell block to see if it is (at least in part) the problem. He also suggested we monitor the voltage on both sides of the Rockwell block using a USB DAQ, so when we get those results I will make sure to follow up on this.
How to turn down gear hubs? sanddrag Technical Discussion 12 20-01-2004 09:10
motor high gear/low gear switch... archiver 2001 6 23-06-2002 23:50
low gear vs high gear archiver 2000 1 23-06-2002 23:07
Robot Turn-in Mike Martus Off-Season Events 0 08-11-2001 19:32
Gear Ratio Doesn't Matter Paul Copioli Technical Discussion 2 27-09-2001 08:18
