Go to Post We're not here to build robots. We're here to build students. - GreyingJay [more]
Unread 02-04-2007, 18:02
CraigHickman
Posts: n/a
Re: pic: 114: How we roll
Originally Posted by JoelP View Post
Single bolt tensioner system? Sounds interesting, how'd you do that?
Our outer shafts are mounted in two bearing blocks inside a milled out pocket in the 2x1 frame bars, and the bearing blocks are linked via a plate on standoffs. From a plate at the front of the drivetrain, a bolt goes back to the linking plate, and can be tightened to pull the chain. Look here: http://www.chiefdelphi.com/media/photos/27585
You can kinda see the tensioner at the bottom corner.
Originally Posted by sanddrag View Post
Just curious, why did you chose to go to dead axles? (or so it appears).
The axles are live, with an eighth inch key in them. They sit in bearing blocks that are pulled to tension the sytem.
Originally Posted by CrosbyAR View Post
where did you get that blue nitrile tread?
McMaster. It's blue nitrile, food grade conveyor. We love the stuff.
Originally Posted by Rich Ross View Post
Any chance on a paper with the gearbox? Nice job on a sweet drive.
I'm not too good at making papers. However, these transmissions may soon be sold from Trossen Robotics, in a partnership with Outback Manufacturing. Keep an eye out.
Unread 02-04-2007, 19:11
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It's actually not, just on the same page as the food grade conveyors. The nitrile is incline belting.
Unread 02-04-2007, 19:12
CraigHickman
Posts: n/a
Bah, same difference. We love INCLINE BELTING then...
But yeah, it only slightly wore down, and only on the middle wheels. I have a feeling the wear was because of our ability to score extremely well, and so we were targeted with heavy defense the whole time...
Unread 02-04-2007, 21:26
run the trap!!!
Team Role: Human Player
How often did you use high gear?
-Philip J. Fry
Unread 02-04-2007, 21:28
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Having 114 on our Alliance at Davis was awesome, though. 675 (us) and 2159 (Robopirates) played Defense while Eaglestrike had fun with the rack.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 02-04-2007, 21:50
CraigHickman
Posts: n/a
Our driver didn't use it nearly as much as he could have. However, there were a couple notable sprints where it came in handy. I'm working on an idea to make the driver take advantage of it more next year.
Unread 02-04-2007, 22:40
JoelP JoelP is offline
whats the P for? Pazhayampallil
FRC #1155 (Bronx Science Sciborgs)
JoelP is a jewel in the roughJoelP is a jewel in the roughJoelP is a jewel in the rough
Send a message via AIM to JoelP
Just a few more questions,
Whats the weight of the gearbox alone?
Whats the weight of the entire drive base (including wheels, chain, gearboxes, motors, electronics)?
Why did you choose to go live axle without the benefit of being able to quickly change wheels (your outer side plate looks welded on)?
Thanks!
The Sciborgs
2006 NYC Engineering Inspiration Award Winner
2007 NJ Regional Finalist
2007 NYC Regional Best Website Award
2007 NYC Regional Chairman's Award Winner
Unread 02-04-2007, 23:52
CraigHickman
Posts: n/a
Thanks!
Weight of the gearbox alone: 9 pounds with motors and pneumatics.
Weight of the entire drive base: somewhere around 40 pounds.
We have the ability to pull off that outer bar by undoing 4 bolts (you can't see them in this shot), and then it's simple to pull and swap wheels, gearboxes, and wheel modules. It was really a great system, mostly because I never needed to maintenance it.
Unread 03-04-2007, 18:37
pakratt1991's Avatar
pakratt1991 pakratt1991 is offline
AKA: Tim L.
FRC #0997 (Spartan Robotics)
pakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nice
Send a message via AIM to pakratt1991 Send a message via MSN to pakratt1991 Send a message via Yahoo to pakratt1991
I had my doubts as to if you guys could get up on our platforms with your small wheels...
but I must say that in Davis your drive train REALLY proved itself to me. it got right up and your drive team was excellent, only needing a few seconds to do it :-)
Plus, those blue wheels kind of grew on me
2010 Oregon Autodesk Regional Winner (997, 2130, 1515) (Event Volunteer)
2008 UC Davis Semi-Finalists
2007 Championship Semi-Finalist (494, 254, 997)
2007 Davis Sacramento regional Champs (100, 997, 1458)
2007 PNW regional, Champs (997, 272, 1087)
Unread 03-04-2007, 18:40
AdamHeard's Avatar
Lead Mentor
is it any coinidence that you, 604, 254 and 968 all chose 4" wheels the same year? I know 254 has talked with 604 about wheels before, have you as well?
Unread 03-04-2007, 18:41
CraigHickman
Posts: n/a
Our wheels are done in an entirely different style than 254/968. And we don't really communicate, so no relation. Theirs is a two piece bolt together setup, where ours are a one piece sold object. In the past I've noticed less trouble with our design over the two piece.
Unread 07-04-2007, 23:10
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
1072 would like to say that they like the way 114 rolls
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 07-04-2007, 23:29
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
The four inch wheels are nice. We like em so much we used 8 of them. The one thing I would have changed this year is the tread its done fine on traction but we have had to change them every regional due to them wearing down. But I was just wondering what the speeds of that tranny are. Nice Job too. Good luck
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
Unread 08-04-2007, 01:03
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Just coincidence. We used 4" wheels this year because it acted like another gear reduction to go in tandem with our custom transmission this year. I would even venture to say that this is the same reason why 114, 254, and 968 had 4" wheels this year.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 08-04-2007, 02:25
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by Gabe View Post
Just coincidence. We used 4" wheels this year because it acted like another gear reduction to go in tandem with our custom transmission this year. I would ever venture to say that this is the same reason why 114, 254, and 968 had 4" wheels this year.
yup... 4" wheels=much smaller initial reduction needed for the same speed=smaller gearbox=less weight.
2001-2004: Team 100
2006-Present: Team 254
pic: 114 Tread V 2.0 CraigHickman Extra Discussion 4 08-01-2007 01:34
pic: 114: Stripped! CraigHickman Robot Showcase 5 04-04-2006 23:49
pic: 114 wheels CraigHickman Robot Showcase 12 31-01-2006 15:50
Tank treads, how we roll plutonium83 General Forum 6 08-01-2006 14:51
pic: Team 114 Teaser James114 Robot Showcase 2 13-02-2005 02:18
