Go to Post We build because we can. - Danaca [more]
Unread 31-03-2007, 13:53
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Download from RC back to computer?
I know it's been covered, but searching is rather tough for it, and I took the time to try.
We just started our 5 hour fix-it window, and our test sled (last year's bot) has a broken gearbox. We're going to switch out test sled to our tetrabot, but we don't have the code backed up anywhere. While it wouldn't be that hard to reprogram it, we'd like to extract the code to dump back onto it after we're done.
Is this possible to do, and if so, how do we do it?
Ladies and gentlemen, you have 5 hours to provide answers.
Unread 31-03-2007, 14:22
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Download from RC back to computer?
You can use IFI Device Reader to read the hex file from the robot(I think).
I have never tried it and you won't be able to modifiy code, but it should work.
Eric Haskins KC9JVH
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
There is no way to get the source code back off the RC. You can get the hex file back but its not something that you can edit.
http://ifirobotics.com/docs/device-reader.zip
Unread 31-03-2007, 14:38
geeknerd99's Avatar
Fire Hazard
AKA: Daniel Lin
Thanks. I'll give it a try. We don't need to edit the source code, we just needed to keep a copy of the hex so that we could reload it after we're done.
Unread 31-03-2007, 15:02
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Wow. I didn't know that this existed! Very cool.
Jacob
Unread 01-04-2007, 23:12
Jared Russell's Avatar
Taking a year (mostly) off
Note that you can also (through long, tedious, and often error-prone methods) generate assembly code from the HEX file. Not that I think that anyone really uses assembly for RC programming when C is available, but if you just absolutely need to change one constant or something and re-download (assuming you know PIC assembly reasonably well), it is an option.
Unread 01-04-2007, 23:18
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
To avoid this type of problem in the future, maybe it would be a good idea if teams taped a CD with the code on it to the robot before mothballing it?
That way, 5 years down the line when no one on the team had the code, it will be sitting there on the CD with the robot.
Just a thought!
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 01-04-2007, 23:41
Just a thought!
CVS server. (CVS stands for Concurrent Versioning System.) What it does is it keeps old versions of code and changes to said code around for until they are removed. This way, you can make a change and still get your working code back if the new code "dies". Not only that, but multiple programmers can work on the same code without having to send each other code bits or even talk to each other. (To use here: keep the most recent code for each year on the server, until that robot dies totally and completely. Then use code to teach newbies...) Just be careful--mechanicals and photographers may also want to use the CVS to share stuff! (By the way, I'm not a programmer and don't know how to set one up.)
Unread 02-04-2007, 12:22
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I'd recommend Subversion over CVS. It is less painful to set up, more flexible in terms of operations, and less quirky.
Just be warned: The 2004-2005 controllers used the PIC18F8520, while the 2006-2007 controllers use the PIC18F8722. Code compiled for one will not work on the other. It may be easier to swap the controllers.
Unread 02-04-2007, 18:31
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
We used subversion, but when we tried using branches late in the project, we had a lot of trouble getting things to merge back and sync up. If you have a pointer to any documents that cover this with examples I would greatly appreciate hearing about it.
We used the command line and tortise SVN for a windows GUI. I've read the SVN manual and tortise documentation about branches, but I think I'm missing something since I don't think it should be so hard.
Unread 02-04-2007, 18:37
ericand's Avatar
AKA: Eric Anderson
We used the device reader to unload code (and subsequently reloaded that code later). We found it worked well and was easy to use.
Our plan (never fully realized) was to archive a binary copies of "good" versions, after they had proven themselves by running in a robot. We have been burned on a few occasions by archiving out of the build (after testing on the robot) only to find out later that what we archived was not exactly what we had been testing. Either someone had made "just one little tweak" while we were off testing, or the person who did the archiving got a path a bit wrong and saved a different version than intended.
Saving the binary off the robot eliminates any chance of confusion. You save exactly what was running.
Contorl Solenoid direct from computer idahorobot Pneumatics 10 18-02-2007 23:52
Download code from robot Luminous Programming 4 25-05-2005 13:32
Download PowerPoints from conferences RudimentaryPeni Championship Event 1 25-04-2005 07:55
Trying to get my computer back... Ashley Weed Chit-Chat 16 04-08-2002 14:14
Download Free 3-d Software from PTC Matt Reiland Inventor 1 07-03-2002 12:48
