Go to Post Actually, FIRST Is hoping the reverse, that your bot will be "Ball damage proof" - Rombus [more]
View Poll Results: What IDE Do You Use?
MPLAB with Default Code 25 48.08%
MPLAB without Default Code 8 15.38%
Microsoft Robotics Studio 0 0%
VI or VI Clone 4 7.69%
Other (Please Specify) 15 28.85%
Voters: 52. You may not vote on this poll
Unread 02-04-2007, 18:46
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Re: IDE
We setup a tree of components and use gmake to tie everything together. We do not use mplab at all, but we do use c18 in command line mode to do the builds.
We don't have a particular GUI, but we use a variety of tools to edit the source.
We can build components individually with their own main() and test functions. Thus we can build a file that only knows how to run the drive train, or we can build a program that only knows how to manipulate the tube lifter.
Most sub projects know only about themselves and some of the central services (ie timers). One sub project pulls in all the others to create the code that runs the complete robot.
We use Subversion for source code control.
This setup is very modular, but we have had a few instances where we needed to be careful of the limited path lenght support in C18.
Portable IDE Nitinol Programming 14 04-02-2007 03:23
Piklab IDE Adam Y. Programming 0 20-01-2007 16:07
MPLAB IDE rholokleolke Programming 13 08-12-2006 18:32
IDE buss Programming 2 08-01-2005 16:16
Php Ide Raven_Writer Website Design/Showcase 8 22-08-2003 21:35
