Go to Post each year the chairmans award is given to the team the judges think deserve it the most, for that year. How can it be any other way? - KenWittlief [more]
Unread 02-04-2007, 20:48
Caseavong's Avatar
Caseavong Caseavong is offline
The Karaoke Champ!
AKA: Casey Viriyavong
FRC #0191 (X-cats)
Caseavong is a jewel in the roughCaseavong is a jewel in the roughCaseavong is a jewel in the rough
Send a message via AIM to Caseavong
Who Has Changed there Robot Design?
I have seen from the two regionals (FLR and Buckeye) I’ve been to that a lot of teams change there initial robot design, some teams even went as far as completely rebuilding there robot, with championships on the way i was wondering which teams has change there bot for the better or worst? Also are we going to see some surprises from some teams?
-Passion builds a robot-
Im asian
Unread 02-04-2007, 20:56
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: Who Has Changed there Robot Design?
675 will probably be adding a California plate to our Robot at Nationals.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 02-04-2007, 21:02
triggerhappy336's Avatar
triggerhappy336 triggerhappy336 is offline
Driver
AKA: Craig Porter
FRC #2228 (CougarTech)
triggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of light
Send a message via AIM to triggerhappy336
As you guys saw at FLR, we had some tube troubles. So we made an adjustable suction arm so we can optimize the cup placement and also we made a small attachment to help out stability.
We also decided that from now on, we should finish reassembling our lift before quaterfinals, that way when we use it, it works.
'07 FLR Rookie All-Stars
'07 FLR Highest Rookie Seed
Unread 02-04-2007, 21:04
SSMike's Avatar
SSMike SSMike is offline
The Guy with the Big Blue Two
FRC #0250 (The Dynamos)
Team Role: Operator
SSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond repute
At FLR we had to remove either our arm or our ramps/platform. We opted to remove the ramp because many teams could score but a lot had trouble climbing ramps.
Long Live #4
Just when I find the key to success, someone goes and changes all the locks.
"It's kind of fun to do the impossible" -Walt Disney
When you put 'THE' and 'IRS' together, it forms 'THEIRS'. Coincidence? I think not!
Why is the name of the phobia for the fear of long words: hippopotomonstrosesquippedaliophobia?
"There's no such thing as a winnable war......." Bring our Troops Home
I will never let you fall
I'll stand up with you forever
I'll be there for you through it all
Even if saving you sends me to heaven
--The Red Jumpsuit Apparatus
Unread 02-04-2007, 21:13
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Wheels. Swapped ifi traction wheels for tandem on each side moutainboard wheels to drastically increase traction, you'll see em in atlanta.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 02-04-2007, 21:19
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
696 has not changed their design
Unread 02-04-2007, 21:21
Grant Cox's Avatar
Grant Cox Grant Cox is online now
Back for more.
FRC #0148 (Robowranglers)
Team Role: Tactician
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
Some minor changes to our grabber are being tested out. Arm was adjusted to be more robust.
And whatever happened to those wings.... hmm...
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
Unread 02-04-2007, 21:35
No change here either. Hey, it works, so why change it? (We did have a minor change at L.A.--have two motors on our arm or two ramps. We chose the ramps after Friday.
Unread 02-04-2007, 21:49
Scion13's Avatar
Scion13 Scion13 is offline
AKA: Steve
FRC #1727 (REX)
Scion13 is on a distinguished road
We switched our rotory arm for a telescoping arm and put our claw on a hinge for Chesapeake. We might replace our claw for the Championship because we popped two ringers in Annapolis.
REX 1727
www.dulaneyrobotics.com
2007 Chesapeake Chairman's Award
2007 Chesapeake Safety Award
2007 New Jersey Entrepreneur Award
2006 Pittsburgh Rookie All-Star Award
2006 Pittsburgh Website Award
2006 Annapolis Best Seeded Rookie Award
Go BAA!
(Baltimore Area Alliance)
Unread 02-04-2007, 21:51
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
1629 made some minor additions to our robot at Pittsburgh and Chesapeake: strategically-placed velcro to keep the platform from folding, a support leg to stabilize the ramp and platforms, and a different set of drive gearboxes to change the ratio and cut back on the speed. Other than that, our troubleshooting was mostly taken care of during build season.
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 02-04-2007, 21:54
Athleticgirl389's Avatar
Athleticgirl389 Athleticgirl389 is offline
I Am The Robot
AKA: Ashley Marshall Aka Sharpie
FRC #0102 (Gearheads)
Athleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond repute
Send a message via AIM to Athleticgirl389 Send a message via MSN to Athleticgirl389 Send a message via Yahoo to Athleticgirl389
102 re-made our boom. We made it smaller and lighter so we can add our two motors back to get the power we wanted. May not seem like a huge change, but it made all the difference from the NJ Regional to the LI Regional.
2010: New Jersey Regional Quarter Finalist, J&J Gracious Professionalism Award. Connecticut Regional Champions (With 1124 & 383)
2009: New Jersey Regional Quarter Finalist. SBPLI Long Island Semi-Finalist, Motorola Quality Award. Newton Division Semi-Finalist (2970 & 33), BR^2 Champion (With 2793 & 136) & Highest Scoring Match Award
2008: New Jersey Regional Quarter Finalist, Judges Award (Innovative Financial Management). SBPLI Long Island Regional Winner (With 2487 & 2010), Entrepreneurship Award. Fastest Robot In The World
2007: SBPLI Long Island Engineering Inspiration Award Winners
2006: SBPLI Long Island General Motors Industrial Design Award Winners, Brunswick Eruption Champions
2004: New Jersey Regional Motorola Quality Award
2003: J&J Mid-Atlantic Regional Winners
2000: National Finalists
1999: Mid-Atlantic Regional Regional Finalist
Team 102
"Teamwork Is The Fuel That Allows Common People To Accomplish Uncommon Results." - Jeff Gordon
Unread 02-04-2007, 21:59
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Changed the stopping mecanism on our ramps so each lift is worth 12" every time. It required about 20 minutes of work.
Other than that, we added a variety of autonomous modes, and used some surgical tubing to tension our tube scoring elevator upwards for faster and less stressful lifting.
We also turned a custom machined bracket for our grabber into two pieces of angle aluminum with drilled holes (KISS).
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 02-04-2007, 22:28
Jonathan Norris Jonathan Norris is online now
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Talk about change.... my team has had to basically totally change our arm system from our first regional in New Hampshire. We came into New Hampshire suffering from the banebot's flue, having to change the motor that powers our main arm joint to a window motor and a large gas spring. Then we figured out our turret was not necessary for this game, and that our manipulator was not effective enough. So in New Hampshire we worked tirelessly in the machine shop, while we were playing some mean D, to create a new manipulator.
For our second event in Waterloo we had a totally different manipulator, using the power of the roller claw, one which was (arguably) the quickest at sucking up the tubes and turning them onto the rack (and seemed to pop a few too many... sry ). After some consistency issues at Waterloo we made more upgrades on thursday at GTR, finishing in 8/63 and got picked second overall. The new manipulator also won us two technical awards at Waterloo and GTR.
I was very proud of how my team was never satisfied with the quality of our robot, and took the mentality to continually improve it. One thing I have learned from building robots is to never give up on a design, and always strive to make your design more effective for the challenge.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 02-04-2007, 22:40
Kellen Hill's Avatar
Kellen Hill Kellen Hill is offline
Strategist
AKA: The user formerly known as 'hill'
FRC #1746 (OTTO)
Kellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond repute
Those who watched St. Louis and Midwest could easily tell we changed our arm. We went from a telescoping arm on a turntable that was pretty flimsy to a combination of 217's, 148's, and 45's arms/tube grabber. Our arm probably would have been rather succesful but we never got time to practice with it and resorted to defense. Over my three years this was the biggest change we have made to one of our robots.
1625 Winnovation Member: 2005-07
1625 College Mentor: 2007-11
525 Swartdogs Mentor: 2011-12
1746 OTTO Lead Mentor: 2013-Present
Unread 02-04-2007, 22:46
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We trashed our arm/manipulator setup and are going with a short strong arm and simple gripper for scoring on the bottom row only.
We are taking the weight left over and filling in the gaps of our ramp. The ramps are our best feature anyway,
Who has a finished robot? FTtyler Rumor Mill 44 07-02-2006 20:26
Who has their own, personal robot? Caleb Fulton General Forum 1 14-04-2003 10:26
Has FIRST Ever Changed Rules During Nationals? IMDWalrus General Forum 2 08-04-2003 15:29
Who has their 2003 robot complete? LBK Rules General Forum 30 09-01-2003 22:48
who here uses autocadd to design their robot if not everyone archiver 2000 16 23-06-2002 22:52
