Go to Post We also have a CNC mill and CNC lathe, but we're interested in doing this only if we can do it quickly. Milling anything takes too long for my MTV-generation attention span. :) - Madison [more]
Unread 02-04-2007, 20:30
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: 1189 - Human-Bot Arm Control
Originally Posted by vivek16 View Post
umm.... what? they just program like they normally would with a joystick drive...
edit: oh sorry misread your post. yeah what do you do?
It has a hanger om the OI and gets put on following auton... costs us some time.
Mark
Brick walls are for other people. - Randy Pausch
Unread 02-04-2007, 20:43
jmcr8on jmcr8on is offline
AKA: Jim Creighton
FRC #1189 (Gearheads)
jmcr8on is on a distinguished road
I will give a couple of answers:
Autonomous: The vest/arm hang on the OI board. At the end of autonomous the operator walks up, puts the vest over hear head (and safety glasses) and slides her arm in to the supports...the velcros the straps. In the meantime the driver starts to move the bot.
Sneezing or something: A concern we had was getting distracted and turning to talk to someone, etc. Just like driving a car, and sneezing, care must be taken. The arm disable button could be pressed on the onset of the sneeze...if the operator had their wits about them. If not...then the robot arm would move the same way the human arm did durign the sneeze....and then would move to the position the human arm was in 'after' the sneeze.
In our pit area and the practice area we set up orange cones around our work cell/area and warned people to not enter the area. We also called 'clear' when the arm was enabled...and completely cleared the area when the turret was to be used.
Team 1189 - Gearheads
Unread 02-04-2007, 20:48
LightWaves1636's Avatar
LightWaves1636 LightWaves1636 is offline
is all over it.
AKA: Sarah Le
LightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to behold
Send a message via AIM to LightWaves1636 Send a message via Yahoo to LightWaves1636
That is really cool. Way to go on safety as well.
FLL Team - Hackberry Hill Elementary - Arvada, CO ('08 - '10 Coach)
FRC Team 1636 - Reds Robotics - Arvada High School - Arvada, CO ('05 - '07 Alumni)
FRC Team 1583 - Rambotics - Ridgeview Academy - Watkins, CO (Volunteer/Supporter)
FRC Team 2859 - Blasterbots - CSM Robotics Outreach - Golden, CO ('09 - '10 Coach)
FRC Team 3320 - Miracles & Machines - Eastside Memorial High School - Austin, TX ('10 - '12 Mentor)
Unread 02-04-2007, 20:49
kramarczyk's Avatar
Originally Posted by sanddrag View Post
What happens if you like, sneeze or something? Does the robot go crazy?
If she sneezes it autonomously hangs 8 ringers... in the code we call it 'A.Baker'. Getting the accelerometer and gyro to set-up to detect that took hours. Unfortunately, now she only has a raspy cough.
Seriously though, there is an enable/disable button on the handle in her hand as well as buttons to rotate the wrist CW/CCW. FYI... the $60 bionic arm also controls turret rotation.
Mark
Unread 02-04-2007, 20:55
AKA: Jim Creighton
More info.... (Mark and I are playing off each other's posts).....
LEDs on the joystick handle attached to the arm:
- Red only (arm disabled)
- Green only (arm enabled)
- Red and Green (arm enabled and turret enabled)
Buttons:
- enable/disable arm
- enable/disable turret
- rotate wrist left
- rotate wrist right
We looked at using the tophat to control the wrist...but the position of the tophat was not ergonomically 'good'...and we ran out of time to do more work on the arm to make it usable.
Unread 02-04-2007, 22:44
Animus
Posts: n/a
About the sneezing... I learned to do most things lefthanded. Including eating Wheat Thins with only vertical arm movements to avoid rotating the turret - when I wasn't wearing the arm. And yes, I most often had it deactivated anyway.
After autonomous, it took me about fifteen seconds to get myself completely strapped into the hockey pads (donated by one of the team members as an attachment for the arm). I learned to do it on my own so the driver was free to move the bot for the first 10 seconds of the match - I had three or four seconds of lag time between the buzzer to end autonomous and the activation bell. Not that this came down to any sort of precise art.
Unread 03-04-2007, 07:55
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
What did you mount the arm to? Football shoulderpads or something? Cut in half? Or did you guys lay your own fiberglass?
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 03-04-2007, 09:01
kramarczyk's Avatar
-q
They are a set of lacrosse pads that are basically unmodified.
Mark
Unread 03-04-2007, 11:20
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
where did you guys get your potentiometers?
ive been looking and i cant seem to find any that specify that the input from them is through pwm cables
"we don't build robots, we build people"
Unread 03-04-2007, 12:56
AKA: Jim Creighton
Yeah....well...I am not sure that any company would really want to embrace PWMs as a connection standard....
That being said we clipped PWMs and soldered the female ends to the pots.
***Ugly #1*** We use cable bundles to get from the RC up the mast/arm with a DB15 disconnect between chassis and mast. PWM cables are soldered to the DB15 on the chassis. PWM cables are soldered into the cable bundle to connect to the PWM cables soldered to the pots and other sensors.
*** Ugly #2 *** For this human-arm application we used DB15 (game port) to Cat5 cables to modular connectors...to Cat5 cables to the vest....then to modular connectors...back to Cat5 cables..then soldered on PWM cables...to the pots. We wanted the ability to disconect the vest assembly in multiple places therefore the use of Cat5 modular connectors.
and...we are always looking for a better way to manage connections across the bot and also the OI. Suggestions?
We used the pots referenced in this white paper: http://www.chiefdelphi.com/media/papers/1743
We bought the pots from Allied Electronics (www.alliedelec.com)....the account exec was VERY helpful and even assisted in getting pots from another supplier when he was short of stock.
Unread 03-04-2007, 13:33
vivek16's Avatar
AKA: vivek
yeah after a bit more research pwms are not used primarily on pots...
thank you, this is going to make a great after season project
we might have time trials to see what we can get accomplished in six weeks.
Unread 03-04-2007, 16:15
AKA: Jim Creighton
We have a 'white paper', to use the term loosely, though..it is actually yellow due to the team colors, that includes:
- Arm features
- code snippets for arm control, PID, etc.
And we could add in the OI wiring that was done.
Available for the asking....
Unread 03-04-2007, 17:24
vivek16's Avatar
AKA: vivek
could i have this white paper?
i am trying to do an easier way to wire the pots to the OI and your designs would be very helpful.
thanks
Unread 03-04-2007, 17:31
WahooWa's Avatar
WahooWa WahooWa is offline
Owner of the Skills
AKA: Greg Forton
FRC #0476 (Wildcats)
Team Role: Student
WahooWa will become famous soon enough
That is really cool. Great job guys. We were going with something like that, but decided to switch to a minature model of the arm instead.
http://www.youtube.com/watch?v=7mF8CKpf-80
Part of that is how far we got on the similar design.
Cool Controls 1189.
Unread 03-04-2007, 17:43
vivek16's Avatar
AKA: vivek
and also here is a pic of the OI
where on here did you wire the pots to? on the ifi site it says that it has 16 analog inputs but i cant see them on here anywhere.
thanks
Ramp bot vs. Arm bot SSMike Technical Discussion 49 22-01-2007 21:03
Arm Placement on Bot? Po-ser Technical Discussion 7 13-01-2007 15:19
Human Arm based controller Andrew Schuetze Control System 5 09-10-2005 15:05
Slave Control Arm aaronD341 Control System 1 26-04-2005 17:13
2-Segment Arm Control Orborde Programming 1 20-01-2005 01:40
