Go to Post All the "official game hint" is is an "official red herring" - Cory [more]
Unread 03-04-2007, 00:41
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
First time wiring a robot
Our team is made up of mainly seniors and sophomores. We rely on our seniors for most of the programming and wiring, so we decided to try and create a working electrical setup without them. I have been looking all day for diagrams of how to wire everything but i still haven't been able to find anything. does anyone have anything like a tutorial or wiring diagram?
EDIT: We do not have the power distribution blocks and we are only wiring CIMs and fans
Unread 03-04-2007, 00:54
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: First time wiring a robot
Andy,
Congrats to your alliance on the win this past weekend. We thought we had a chance but your alliance was just unstoppable. We've been Finalists now 3 times, Semi-Finalists twice - but still no blue banner.
Anyhow, have you seen this - maybe it's a good place to start.
Good luck and we hope to see you at Davis again next year.
Unread 03-04-2007, 01:00
Andy L's Avatar
FRC #1458
Sorry i forgot to say we are using 2006 hardware and do not have the power distribution blocks
Unread 03-04-2007, 01:03
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
In addition to the robot rules (section 8 of the FRC manual), and the diagram linked above, you should read the Tips, Guidelines, and Good Practices manual. It contains a lot of helpful information about building and wiring the robot.
There are links to all these documents here (some are links to more links)
Unread 03-04-2007, 07:42
Andy,
Since this is not a competition bot you can take some short cuts. If you do not have a lot of weight or a need to push around a lot of weight, you can run the Chalupa motors on 30 amp breakers. All you need to do is wire the battery through a 120 amp breaker to a small fuse panel, insert the fuses for motors and the RC (or whatever controller) and use the same wiring technique from there for speed controllers and motors. A platform like this becomes a great tool for working on software and other development ideas during the off season and for demos.
Unread 03-04-2007, 09:26
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Do you have any of last year's hardware? If so, you can take a look at this:
http://www2.usfirst.org/2006comp/Dra...STRIBUTION.pdf
If you don't have the power distribution block, don't worry about it. Just tie all your grounds together at the stud.
Or, if you have a 2005 IFI breaker panel (rare), you can look at this:
http://www2.usfirst.org/2005comp/Dra...STRIBUTION.pdf
But this isn't too realistic, seeing that it looks like FIRST will never reinstate the breaker panel. So it wouldn't be good practice for your freshys to wire this up, because its a lot easier than the current system.
Just some thoughts.
Jacob
--Remeber, good posts deserve good rep!
Unread 03-04-2007, 23:29
Andy L's Avatar
FRC #1458
Second noobie question: ground stud, what is it? was it supplied or do i make it? how should i make it?
I know what it's for just like should i make it or do i have to buy something special.
Unread 03-04-2007, 23:33
AKA: Jacob Komar
I've just used a little 1" 7/16 bolt/nut... This will work fine, just make sure you tape it up.
I wasn't on FIRST pre-2005, so I don't know if there is an 'official' grounding stud. Perhaps some older vets can shed some lights on this.
Jacob
Unread 03-04-2007, 23:50
MrForbes's Avatar
AKA: Jim
a "ground stud" in these robots is not really "grounded", it is just a common negative battery connection. It can be a bolt, 1/4" would be a reasonable size (a 1/4" diameter bolt has a 7/16" hex head, some folks get confused about which size is the actual bolt size)
Put the bolt thru a piece of plastic, so you can mount it, and make sure it stays away from any other wiring or metal parts. Keep ALL wiring insulated and secured so the conductor does not contact the metal robot chassis or any other metal parts.
Unread 03-04-2007, 23:53
AKA: Jacob Komar
Thanks for the correction. I yell at kids all the time on my team for calling a 1/4" bolt a 7/16" bolt... And here, I did it, on the forum!
But yeah, the idea is that you can tie together all of your grounds in one place without using a power distribution block. Or using the chassis. This is bad.
Jacob
Unread 04-04-2007, 00:10
Andy L's Avatar
FRC #1458
how bad of a shock would that be if it touched the chasis
Unread 04-04-2007, 00:32
AKA: Jacob Komar
lol. Probably none. It's just bad practice.... Your body would not be providing a path to the battery ground, so you wouldn't feel anything. Some applications actually use the casing/chassis for neutral to avoid running neutral wire everywhere. This is bad practice. Use the black wire.
Jacob
Unread 04-04-2007, 00:40
MrForbes's Avatar
AKA: Jim
There is some danger with shorting the positive and negative power wires....lead acid batteries can explode if shorted. Also things get very hot very quickly when a battery is shorted, you could get burned trying to disconnect the battery (I saw this happen at the first regional I attended, a team had a demonstration device with a motor connected to a battery, the wires shorted and started smoking, and a student burned his hand attempting to disconnect the battery cable)
Unread 04-04-2007, 00:58
Andy L's Avatar
FRC #1458
since i already have this topic i'll add the question
how to wire a disable switch?
Unread 04-04-2007, 01:18
AKA: Jacob Komar
Well, your master 120Amp breaker is required between the battery and everything else (as per the diagram). This will, in all cases, disable everything.
As far as a disable switch on your operator console, check out this diagram:
http://ifirobotics.com/docs/competit...guide-reva.pdf
DO NOT REVERSE THE PIN #S!!!!!! make sure that pin 1 is pin 1 on your connector. THATS RIGHT!!! P1 is not PIN 1... the trace with the number 1 is pin 1. I have reversed this, and it costs $150+shipping to fix.
And of course, you can always do a programmed e-stop, which only works as long as your program works (that is what you are trying to test... right?)
Jacob
pic: 1368 summer time robot savage Extra Discussion 5 15-10-2006 05:16
Robot Storage Time Limit Jherbie53 General Forum 10 30-05-2006 20:56
Wiring the robot in inventor. vVigglEs Inventor 15 06-03-2006 11:35
Optical sensor wiring with the EDU Robot Geoffrey4283 Electrical 3 15-01-2003 21:03
Time spent building robot jdawson General Forum 12 25-02-2002 17:53
