Go to Post ...if you say "AndyMark" three times we show up... - Billfred [more]
Unread 03-04-2007, 07:42
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: off season mods
Originally Posted by Adama View Post
thanks
now, how to mount a 3in cim...
Uhm...... you talkin about our robot?
Dual 3inch cims drive our elevator... floor to top rack in 1.5seconds.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 05-04-2007, 15:40
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
Re: off season mods
I was thinking more like team 25 but yes, the same idea. Do you have any pics of how your cims are mounted? In fact, anyteam out there that has used a 3 inch cim to drive their elevator, if you would send me some pics it would be verymuch appreciated.
Did you use the timing belt pully thats already on the cim? Is it direct drive? any useful info would be great.
thanks
Unread 05-04-2007, 20:27
AKA: Alex
Re: off season mods
thanks
ok.. unfortuantely i dont have any pictures of that part of the robot. but i can give you some details.
the cims are mounted facing toward the left and right sides of the robot and have a #25 chain sprocket on them running to another sprocket to achieve a 2:1 ratio. this sprocket is on a keyshaft that has several ball bearings on it since this shaft has a good number of pounds on it (around or a little above 100 i believe). the shaft has another cim/chain/sprocket combo mounted on the other side as a mirror image.
On the shaft there are four timing belt pulleys and one larger timing belt pulley to run to the shaft encoder that the servo routine uses for feedback (the elevator moves too quickly for a human to control). the other pulleys run to the very long lengths of timing belt which run the extension of the elevator, ours is a triple-extension arm, if you need explanation on that part i can give one.
we would have used the belt pulley right there on the cim.... but its next to impossible to find that 3mm pitch or whatever it is timing belt. there's places that have it, but its used in many products apparently so they arent too interested in small quantity customers.
-q
Unread 14-04-2007, 21:12
Adama's Avatar
Re: off season mods
-q
thanks
Off-season help Setsanto 3D Animation and Competition 12 24-02-2007 17:26
437 Showing Off it's Off Season NextPerception Robot Showcase 7 06-02-2007 19:03
Off season projects JamesCH95 General Forum 17 13-12-2004 23:32
Off-Season Events Steve-0 General Forum 1 21-04-2004 13:08
Off-Season in Richmond?! Sachiel7 Off-Season Events 17 25-11-2003 00:17
