Go to Post Don't criticize them for what they have, learn from what they do. - xSAWxBLADEx [more]
Unread 03-04-2007, 09:33
ZackCraig's Avatar
ZackCraig ZackCraig is offline
The Walking CPU
FRC #1856 (GEARHEADS)
Team Role: Webmaster
ZackCraig will become famous soon enough
Lightbulb Close Inspection
Did anybody have an inspection where you barely passed?
Our robot was 119lbs and fit the square space perfectly.
Eye passd a spellng "B" b4
Unread 03-04-2007, 09:40
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Close Inspection
At first we barely DIDN'T pass. We weighed 120.8 lbs. and were 1/16th of an inch to tall. Didn't take much to fix though and ended up short enough and 119.3 lbs.
BTW does anyone know why lbs. is an abbreviation for pounds?
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
One hint for everyone who builds a robot that fits "perfectly": build it one inch smaller in all directions next time. Ask yourself how much of an advantage you gain by keeping that inch, and consider what happens if your frame gets twisted, or you want to add something, or the inspection box is undersized (and nobody notices). Also remember that you can't be pushing on the walls of the bounding box (or the virtual walls, in the case of this year's sizing box); you must fit inside unconstrained.
There are probably cases where you need to build your robot almost exactly to the maximum size, but realistically, most maximum-sized robots aren't examples of this.
Also, as we're on the topic, remember to keep track of weight. There was one team at GTR which arrived something like 37 pounds overweight (due to their own malfunctioning scale). Don't let that happen to you!
It's from the Latin, librum, for scale.
Unread 03-04-2007, 09:45
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
At Philly, we were around a pound over the limit, so we cut off a few inches of the middle support of our ramp (taking away 30% of its support, but it still worked out), and landed exactly at 120 lbs.
Interesting question...
Originally Posted by Wikipedia
The word “pound” comes from the Latin word pendere, meaning “to weigh”. The Latin word libra means “scales, balances" and it also describes a Roman unit of mass similar to a pound. This is the origin of the abbreviation “lb” or “℔” for the pound. The “s” at the end of “lbs” simply denotes the plural form.
Edit: Tristan beat me.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 03-04-2007, 10:02
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We design to be 1" shy on all dimensions and it is amazing how things always seem to grow during build season and we end up being close to max size.
This year we had zero problems with dimension or weight for the first time ever.
Having a weight budget spreadsheet is a must!
Unread 03-04-2007, 10:05
Billfred's Avatar
Billfred Billfred is online now
Ours was painless--102ish pounds, in by a good half-inch all around. I don't know of anyone who had size or weight problems at Palmetto, though I did inspect size issues at UCF and Chesapeake. (Some Palmetto teams did get burned on other issues, like not having the Rockwell block.)
Unread 03-04-2007, 14:43
We take 1/4" off all sides and the top. Minimum. This is to allow room for bolt heads and the like.
Weight budget: with us everything goes on it individually, and we use it for our BOM. Hey, it works, and it needs less work.
Unread 05-04-2007, 11:09
Mister_Juggles's Avatar
Mister_Juggles Mister_Juggles is offline
The good-looking one.
AKA: Joey
FRC #0422 (Green Dragons (under review))
Mister_Juggles is just really niceMister_Juggles is just really niceMister_Juggles is just really niceMister_Juggles is just really niceMister_Juggles is just really nice
Send a message via AIM to Mister_Juggles
I remember last year (06) our robot was weighing in at a tenth of a pound or so overweight. We let the air out of the pneumatics and it put us *just* under 120
"Who do you want to be remembered as the greatest horn player ever, you or some felonious monk?" --Terry Pratchett
http://xkcd.com/c246.html
http://xkcd.com/c123.html
Unread 05-04-2007, 11:53
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
In Spanish libra means pound, originating from Latin as mentioned before.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 05-04-2007, 12:00
That shouldn't have worked. Assuming that you have two Clippard AVT-32-16 tanks with 16 in3 each at 120 psi, and four 24 in stroke, 2 in bore Bimba Cylinders on board (realistically, that's way more than you'd expect, even neglecting the tubing), at 120 psi and 60 psi respectively, the amount of air on board is only about 0.06 lb.* If you went from 120.1 down to 119.9 ("*just* under 120"), there's a leftover 0.14 lb to be accounted for. More likely, you just got lucky with the error in the scale.
And here's a question to which I don't really want to know the answer: do you need to weigh the robot with or without its compressed air?
*This assumes an air temperature of 21°C; in reality, the air is probably hotter than this due to being mechanically compressed. And that lowers the density even more.
Unread 05-04-2007, 12:13
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
That happened to us this year at Boilermaker. We were 120.2 pounds. We were told to let the air out of our three clippard tanks. We than weighed 120.0 We have to have our tanks filled because we use the air to back fill our cylinders to keep the gas struts compressed
We also always build 1" short of the width and length dimensions. We have never been too big but we have removed plexiglas from the box due to bolt heads
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Inspection willross General Forum 4 25-02-2004 18:28
Streamlining Inspection sevisehda General Forum 7 09-09-2003 22:53
Inspection Sheet Mike Norton Rules/Strategy 3 12-02-2003 15:55
So close, but not close enough archiver 2001 1 23-06-2002 23:45
Inspection Mike Martus OCCRA 0 29-10-2001 21:45
