Go to Post last year's tradition is this year's rule change! - EricH [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 31-03-2007, 23:49
CraigHickman
Posts: n/a
Why Solidworks over Inventor?
Hey all-
I've been looking at some new CAD options, to learn more and spread out my knowledge. And so I decided I'd check out Solidworks. So here's my question: Why Solidworks over Inventor? The kind of answer I'm looking for is a concise list of advantages, and maybe some cons. In all, convince me to migrate over to Solidworks. Keep in mind I'm advanced in Inventor, so basic CAD principles (dimensioning, machinability, weight, etc.) are all basic knowledge.
So why should I go to Solidworks?
Unread 01-04-2007, 00:45
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Why Solidworks over Inventor?
I felt it was incredibly easy to pick up solidworks, while it is still very powerful as you get more and more advanced. Its user interface is stunningly intuitive, and the tutorial works wonders.
Unread 01-04-2007, 03:02
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
No to both. Autodesk all the way!!!! VIVA!
Unread 01-04-2007, 14:25
burkey_turkey burkey_turkey is offline
AKA: Andrew
FRC #0422 (MechTechs)
burkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to behold
i recently switched over to solidworks from inventor because of a mentorship im going to be doing this summer. One of the biggest advantages of solidworks is that it is the industry standard moreso than inventor. It is also on the rise. advanced solidworks prowess will be more beneficial careerwise than inventor. I agree that solidworks is alot more intuitive than inventor. I also like all of the different viewing options in solidworks alot.
some cons to solidworks are its movement. One thing i miss about inventor is that the scroll wheel clicking pans for you, in solidworks it rotates your view instead. I like pan alot more, especially when im working off 2d sketches. Another con of solidworks is the buttons. Its like it was made for blind people. you have a couple of massive buttons on the top bar and small ones off the screen that take 2 clicks to get to. in inventor you had plenty of small buttons on the left that you remember where they are so you dont need to see them that well. i think that modifying the toolbar some cna change this though.
all in all, i would choose solidworks. the switch to solidworks from inventor is easy, so get an educational copy and start learning. It will pay off in the longrun.
Unread 02-04-2007, 18:56
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
I find Solidworks a LOT more user friendly like the others have said. There are a ton of options and its easy to pick up, especialy if you already know inventor.
If you hold down ctrl + Middle mouse button then you pan instead of rotate. I think you can change the buttons to do different things in the options too somewhere, there is a lot of customization possible, but not needed.
Unread 03-04-2007, 00:59
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
Alot more companies use SolidWorks. I'm told its a good intro to ProE but I don't know about that. It is easier to make a bill of materials in solidworks. Some of the calculations are easier to do, like measuring. SolidWorks can be used with other more complex programs to find things like vibration effects or FEA. SolidWorks can also be used to create machining programs automatically.
Unread 03-04-2007, 14:47
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Huh? How is that?
JD Mather
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 03-04-2007, 18:06
CraigHickman
Posts: n/a
Alright, I like what I'm hearing. I like it enough to look into getting a copy or license of Solidworks. Anyone know the best way to go about this as a FIRST student and soon to be college ME student?
Unread 03-04-2007, 21:29
Contact Solidworks and tell them that you are considering switching to solidworks.
One of our mentors is a certified solidworks professional and uses it at work. He got solidworks to sponsor us with 15 or 20 licenses. It rocks!
Unread 03-04-2007, 22:08
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
I have a student trial version and it doesn't have all the features of the regular version. If you decide to get a student version, make sure that it has everything you're expecting.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 04-04-2007, 19:13
AKA: Andrew
seeing as you are:
1) a student likely to use 3d modeling in your future
2) a current inventor user
3) considering a switch at such an impresionable time in your life
im sure solidworks would love to convert you. to them, a free copy now while a student just makes you dependent on them so that by the time youre out of college you need to buy their next edition (what number are they on now? 7?) which will cost tons of money. they profit by giving you cheap software, so go for it. just explain the circumstances and ask for an educational copy or a regular copy.
Unread 04-04-2007, 19:14
CraigHickman
Posts: n/a
seeing as you are:
Already been done , and my copy is in the mail.
Unread 04-04-2007, 21:57
Good luck and have fun with solidworks!
Unread 05-04-2007, 18:38
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Ummm....I am not sure if you are aware of this but have you ever heard the phrase "Autodesk Inventor"?
Invetor is an Autodesk product.
-John
Unread 07-04-2007, 02:34
pakratt1991's Avatar
pakratt1991 pakratt1991 is offline
AKA: Tim L.
FRC #0997 (Spartan Robotics)
pakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nice
Send a message via AIM to pakratt1991 Send a message via MSN to pakratt1991 Send a message via Yahoo to pakratt1991
I also Am going to switch to Solidworks... maybe
It is the industrial standard around where I live, and we have allot of high tech companies around here. one of our biggest sponsors is willing to hook us up with some licenses.
The only reason I See to switch is that it is more common.
2010 Oregon Autodesk Regional Winner (997, 2130, 1515) (Event Volunteer)
2008 UC Davis Semi-Finalists
2007 Championship Semi-Finalist (494, 254, 997)
2007 Davis Sacramento regional Champs (100, 997, 1458)
2007 PNW regional, Champs (997, 272, 1087)
SolidWorks vs. Inventor sanddrag Inventor 48 22-09-2008 22:57
Inventor or Solidworks? CalvinEiber SolidWorks 6 09-01-2007 14:00
showdown: SOLIDWORKS vs. INVENTOR negfrequency Inventor 14 18-04-2006 08:08
inventor to solidworks Greg Needel Inventor 1 07-05-2004 07:48
