Go to Post Honestly, I can't understand why anyone wouldn't want to be a mentor. The fools don't know what they are missing. - Steven Smith [more]
  #61   Spotlight this post!
Unread 26-03-2007, 16:35
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: 2007's Best Robot Ramps
Originally Posted by EmilioM View Post
Technichalities aside...
Ya, we know that... but we still lift at least 120 pounds of our own robot (the gas springs themselves are relatively insignificant weight-wise) which is reason to be stoked... as for that Jedi hunt, lemme know if you find one, might come in handy... Who knows
Can you explain a bit more about how your robot is designed? Specifically, I'm curious how many gas springs you use, their force, stroke and location and -- the biggie -- how they're restrained and released at the end of each match.
I was told y'all need something like 8 people to reset them. How do you get the machine off the field at the end of a match and how do you reset it?
--Madison--
...down at the Ozdust!
  #62   Spotlight this post!
Unread 26-03-2007, 17:13
They're a box with an arm inside. From what I've seen during reset, it looks like 2 gas springs per lift, on opposite corners. Might be more. To get the bot off the field, they fold up the ramps somehow first without collapsing the springs.
  #63   Spotlight this post!
Unread 26-03-2007, 17:25
EmilioM's Avatar
EmilioM EmilioM is offline
FRC #1717 (D'Penguineers)
EmilioM is a name known to allEmilioM is a name known to allEmilioM is a name known to allEmilioM is a name known to allEmilioM is a name known to allEmilioM is a name known to all
Send a message via AIM to EmilioM
Well... Our robot has sandwich structure panels composed of 1.5" thick pvc-foam sandwiched between to .020 plates of aluminum held together by lots of gorilla glue (lots). We'll post more details on these panels later - the design is truly sick, they weigh around 20 pounds and can easily support over 200 pounds point-loaded each with less than a 1/4" of deflection; they're amazing and one of the things we are proudest of on our robot.
These aforementioned panels fall are held up by servos which realease them; they are then pulled down by gravity. The panels then are extended 12" in each dimension thanks to fold out flaps (look at the pics we have already posted and the videos to come to see how these fold out). The dimensions are about 46" by 44" and have an area of about 2000" each and can easily hold any robot with no tipping issues at all and room to spare. These panels lock into the chassis of our robot upon falling.
The 150 lb. gas springs (4) are located at the point closest to the panels in the front and farthest in the back (look at the silver piston mounts in the pics) and each have a 16" throw. They are reverse-mounted inside of the previously mentioned aluminum housings to create a piston design placing the weaker rod of the spring inside of the houing and allowing the stronger casing of the spring to extend down.
They are restrained via an internal locking mechanism that comes stock with the springs we chose. This pin extends beyond the top of the housing and is depressed by a lever/cap... Each lever/cap is pulled - thus depressing the pin and releasing the spring - by four bike cables which are pulled by a leadscrew system driven by a banebots motor attached to the inside of the frame. Each spring/cable is individually tuneable, so we can determine when each spring releases and in what order. That being said, we chose to have the front springs release a split-second earlier in order to allow the other robots to roll back against ourback rails to locate the robots.
As for the last question, yes it takes 10 people to depress them LOL. We fold up the panels on the field and let the springs stay extended and then depress them in the pits/practice field...
So that was the readers digest version of our panels haha... Theres a lot more to them so feel free to ask any and all questions. Good luck at nationals
1717 - BALLIN'
2007 San Diego Finalist
2007 San Diego Imagery Award
2007 Los Angeles Semi-Finalist
2006 Los Angeles Rookie All-Star
2006 Arizona Semi-Finalist
2006 Arizona Rookie Inspiration
  #64   Spotlight this post!
Unread 26-03-2007, 18:43
Duke_of_Hazard's Avatar
Duke_of_Hazard Duke_of_Hazard is offline
FD3S>Z28>All
FRC #0233 (The Pink Team)
Team Role: Driver
Duke_of_Hazard has a spectacular aura aboutDuke_of_Hazard has a spectacular aura about
As a member of their eliminations alliance in UCF, I may be biased, but I've seen few ramps that compare to 180 SPAM. I can't find a picture right now, but it wasnt nicknamed the aircraft carrier by more than one person for nothing....
"I drift not because it is a quicker way around a corner, but it is the most exciting way" - Keiichi Tsuchiya
"...and remember, don't be an Initial D-ouche, Drift Responsibly" - Me, after showing a few members Initial D
The next statement I make is true. The last statement I made was false.
Pink Team Awards (Click it, you know you want to)
Base Driver 2k7!
Attending : Krunch Off-Season?
  #65   Spotlight this post!
Unread 29-03-2007, 17:10
SSMike's Avatar
SSMike SSMike is offline
The Guy with the Big Blue Two
FRC #0250 (The Dynamos)
Team Role: Operator
SSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond repute
Easily one of the best lifting bots I have seen was 316 at FLR. They got 60 BP almost every match. I love their bot. Actually I'm still looking for pictures of it...
Long Live #4
Just when I find the key to success, someone goes and changes all the locks.
"It's kind of fun to do the impossible" -Walt Disney
When you put 'THE' and 'IRS' together, it forms 'THEIRS'. Coincidence? I think not!
Why is the name of the phobia for the fear of long words: hippopotomonstrosesquippedaliophobia?
"There's no such thing as a winnable war......." Bring our Troops Home
I will never let you fall
I'll stand up with you forever
I'll be there for you through it all
Even if saving you sends me to heaven
--The Red Jumpsuit Apparatus
  #66   Spotlight this post!
Unread 02-04-2007, 19:13
shamuwong's Avatar
shamuwong shamuwong is offline
pretty little words.
AKA: Mike Wong
FRC #0469 (Las Guerillas)
shamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to behold
Hate to toot our own horn, but I was didn't fully realize the size of our ramps until one of the Martians did a 360 on top of us, remaining on for the 30 points.
I'd also like to cast a vote for Team 27, who has a huge, constant, flat ramp. If you have any ground clearance and some driver ability, you'll be able to make it on them. Plus, they've got a very effective roller gripper to go along with their ramp.
Team 93 also had impressive ramps. They were nice and easy to climb, being only about 2" tall, and it lifted reliably.
ΜOΛΩΝ ΛΑΒΕ!
attending: great lakes regional, west michigan regional, detroit regional, the championship
  #67   Spotlight this post!
Unread 02-04-2007, 19:18
Billfred's Avatar
Billfred Billfred is offline
I was impressed with SPAM's ramps at UCF--wish we could've climbed those for a bit.
Of all of the ramps 1618 climbed at Palmetto, I'd say that my favorites were 900 and 1102--both nice and crazy wide, giving our driver plenty of fudge factor (though he was quite adept at getting the robot pointed right).
  #68   Spotlight this post!
Unread 02-04-2007, 19:19
b-rant's Avatar
b-rant b-rant is offline
AKA: Brantley Brokaw
FRC #0364 (TEAM FUSION!!)
b-rant is a jewel in the roughb-rant is a jewel in the roughb-rant is a jewel in the roughb-rant is a jewel in the rough
Send a message via AIM to b-rant
definitely team 57 they worked every time, it was easy to get up and it wasn't too big so it was hard to get a tube stuck under it. Definitely my favorite ramp good job team 57 it's always great being paired with you guys
  #69   Spotlight this post!
Unread 02-04-2007, 19:22
Jared Russell's Avatar
Taking a year (mostly) off
I gotta say 357.
Their ramps are perfectly flat (allowing ANYONE to get up) and have a smooth, powerful scissor jack. The ramps elevate perfectly straight up, leaving no chance of tipping whatsoever.
In fact, we were so impressed with them that in the semis at Philly, we were prepared to take as many incursion penalties as necessary to keep them from getting the other robots on!
  #70   Spotlight this post!
Unread 02-04-2007, 19:51
Freddy Schurr Freddy Schurr is offline
FRC #0204
Freddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond repute
Team 204 had an impressive ramp robot at the Philadelphia Regional.
  #71   Spotlight this post!
Unread 02-04-2007, 20:09
Philimator's Avatar
Philimator Philimator is offline
AKA: Phil Starski
FRC #0494 (Martians)
Team Role: Human Player
Philimator will become famous soon enough
469 - easy to get up on and wide enough for some elbow room
27 - same as 469's design just different colours (yeah i spelled colours that way )
503 - They are the Martian killers with those ramps, at GLR both of the martian teams laid waste to there awesome froggy power.
703 - Although they didnt get to show off they ramps too much at Western michigan, when those babies fold out you hear the call of the phoenix!
I make the toast!!!
  #72   Spotlight this post!
Unread 02-04-2007, 20:14
O-H
FRC #0048 (Delphi E.L.I.T.E.)
I normally don't pimp my team's own hardware, but I'm really a fan of 48's ghetto-functional Viagra Button-actuated ultrasteel ramps of doom. I enjoy watching them spring up and crash down to the ground every time they deploy. Whether this makes them some of the best ramps, I don't know, but they are certainly some of the most entertaining.
  #73   Spotlight this post!
Unread 03-04-2007, 01:23
Darkswordsmith Darkswordsmith is offline
Allen's Shiznit
FRC #1678 (En-Gen)
Team Role: Electrical
Darkswordsmith is on a distinguished road
Send a message via AIM to Darkswordsmith
Now I cant help but boast our team's ramp. I'm pretty sure it's one of the largest ramp in the nation with an area of 45 sq. ft (half of them ramp, half of them platform) with 15.6 degress elevation. It's literally a portable parking lot and can fit 3 robots on it optimally.
And the nice thing about it is, we used no fancy material, just plain sheet metal with some teflon, stitched together with pop-rivets.
  #74   Spotlight this post!
Unread 03-04-2007, 15:43
Alpha 997 Alpha 997 is offline
AKA: Yi Li
FRC #0997 (Spartans)
Team Role: Operator
Alpha 997 will become famous soon enough
Our teams lifter is pretty good. Buzzer lifter so it gives the team mates more time to place rings. I don't have any pictures from regionals yet. Here's one form a scrimmage:
Ohhh... The EXIT sign is green so that robots can get out during a fire.
2007-Archimedes semi-finalist
2007-Davis Sacramento Regional champion
2007-Pacific Northwest Regional champion
2005-Archimedes semi-finalist
2005-Archimedes second seed
  #75   Spotlight this post!
Unread 03-04-2007, 17:47
Zoheb N Zoheb N is offline
Captain
FRC #0118 (Robonauts)
Zoheb N is just really niceZoheb N is just really niceZoheb N is just really niceZoheb N is just really nice
Send a message via AIM to Zoheb N
I have got to say 476. Although they could only lift one robot at a time, they were very consistent.
2004 Lone Star Engineering Inspiration
2005 Denver Regional Winner
2005 Denver Radio Shack Innovation in Control Winner
2005 Lone Star General Motors Industrial Design Winner
2005 Lone Star Regional Winner
2005 Lone Star Regional Chairman's Winner
pic: 296 Robot 2007 without ramps Rick-906 Robot Showcase 7 11-11-2007 00:06
pic: FRC48 Robot xtremachen10 - Ramps Deployed Travis Hoffman Extra Discussion 5 04-03-2007 19:40
pic: 1712 Robot w/ Ramps Up, February 13 Chuck Glick Robot Showcase 4 14-02-2007 13:34
2007's game Dakota Snow Rumor Mill 74 17-12-2006 20:47
Best robot. Gope General Forum 74 26-08-2003 16:41
