Fisher-Price 00968-9012 motor pinion
Does anybody have information on the 19T pinion gear that comes on the Fisher Price motor in the kit?
I think it has a 32 PD and a 20 degree pressure angle??? Thanks in advance Joe P |
Re: Fisher-Price 00968-9012 motor pinion
Yes, in the history of the FP motors, they've generally been 32 pitch 20* pressure angle. The only variance has been no. of teeth.
Hi. The FP gearboxes are metric ie Module. The small pinion on the F-P motor itself is 0.8 Module and it is a 20 degree pressure angle. These calculate out to american 31.75dp. Meshing the F-P motor and native 0.8module pinion with a standard 32dp off the shelf gear from the good 'ol USA is ok for our robot applications. We have done it for two years now and even under a high load they always held up for arms, turrets, transmissions, etc. We cut the gears ourselves. However if you were designing a transmission that will go several billion revs and needed to be ultra-quiet you would obviously mate the pinion with a true Metric gear.
Jeff- team gearcutter Last edited by Superstitions : 03-04-2007 at 19:30. Reason: spelling |
| Fisher Price Motor 9003 vs 9012 | Mike Norton | Motors | 5 | 07-02-2007 19:27 |
| Fisher Price Motor | Andrew Y. | Motors | 2 | 20-11-2006 07:52 |
| fisher-price pinion gear | bill mc gowan | Motors | 6 | 06-03-2006 11:14 |
| Fisher Price Pinion Pressure Angle | alphastryk | Motors | 1 | 04-02-2006 21:06 |
| Fisher Price Motor .. Important! | Paul Copioli | Motors | 7 | 22-01-2003 13:55 |
