Go to Post I always thought a trained bio mechanical monkey wrapped in aluminum foil would be the best robot, but every year my team says "No Pete, go sit down." - BuddyB309 [more]
Unread 03-04-2007, 23:50
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: First time wiring a robot
a "ground stud" in these robots is not really "grounded", it is just a common negative battery connection. It can be a bolt, 1/4" would be a reasonable size (a 1/4" diameter bolt has a 7/16" hex head, some folks get confused about which size is the actual bolt size)
Put the bolt thru a piece of plastic, so you can mount it, and make sure it stays away from any other wiring or metal parts. Keep ALL wiring insulated and secured so the conductor does not contact the metal robot chassis or any other metal parts.
pic: 1368 summer time robot savage Extra Discussion 5 15-10-2006 05:16
Robot Storage Time Limit Jherbie53 General Forum 10 30-05-2006 20:56
Wiring the robot in inventor. vVigglEs Inventor 15 06-03-2006 11:35
Optical sensor wiring with the EDU Robot Geoffrey4283 Electrical 3 15-01-2003 21:03
Time spent building robot jdawson General Forum 12 25-02-2002 17:53
