Go to Post At this point I think I've absorbed more aluminum into my blood than the iron that was already there. - hectorcastillo [more]
Unread 04-04-2007, 07:14
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: pic: Internal view of the Dewbot
Originally Posted by Qbranch View Post
You had to have paralleled those batteries... are you having any issues with the batteries voltage eqalizing (running high current between eachother) when you plug them in?
Usually the only way to stably put multiple batteries in a system is in series.... unless maybe your charging them on the same charger/leave them parralelled at all times?
-q
Checked the batteries carefully for bad cells, and ran them charging and running as a matched set at all times. This isn't the final wiring, though. I want to add a second main power breaker and run as an "A" battery source and a "B" battery source. The battery access hatch is pretty tight so I'd rather swap sources by opening one breaker and closing the other. Then we can exchange batteries away from the public's view.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
pic: The Mountain Dewbot - 1 artdutra04 Chit-Chat 14 22-07-2007 12:18
pic: Art and the Mountain Dewbot! artdutra04 Extra Discussion 11 02-04-2007 22:09
pic: Bottom view of The Red Dragon redbarron Extra Discussion 27 02-02-2007 10:20
pic: A View From the Top CMB Extra Discussion 2 10-01-2007 22:21
pic: The Nonnebot - Team 38 - Profile View Heretic121 Robot Showcase 1 22-02-2006 19:49
