Go to Post The proper way to advance forward is by bringing the bottom up, not by limiting how high the top can fly. - artdutra04 [more]
Unread 04-04-2007, 14:31
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Re: Banebot 56mm transmissions are Available
97 ran with only four motors total this year: 2 for drive with 56mm BB 12:1's, one for the main arm joint with 42mm BB 256:1, and one for the wrist joint with 36mm BB 64:1. I've spent many hours making, installing, and testing hardened spares as a precautionary measure, but in actuality none of our stock plates of any size showed any signs of deformation.
I'm not saying the problem didn't exist. In some situations (2 CIMs, for example) the safety factor on the stock plates was not adequate. But if BaneBots returns with an improved product next year, we would probably use it again. Lightweight, cheap, easy to mount (and cool-looking) transmissions are great and the more supplier options available to FIRST teams, the better.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Banebot 56mm Gearbox - Repair Docs & FAQ kmcclary Motors 0 22-02-2007 01:47
Banebot 56mm gearbox - double D - V3 - It's Show Time. Joe Johnson Motors 34 18-02-2007 19:00
Banebot 56mm gearbox - double D - RELOADED Joe Johnson Motors 82 09-02-2007 14:07
Banebot 56mm gearbox - double D related Joe Johnson Motors 78 31-01-2007 23:55
Attempting to Cut BaneBot 56mm Shaft edthegeek Motors 6 15-01-2007 08:51
