Re: Lowest Number
I thought I saw the Juggernauts (1) signed up for a regional this year....I suppose I could be wrong.
Re: Lowest Number
Re: Lowest Number
I know they were at Lone Star.
Re: Lowest Number
Team 20 has been around since 1992.
Re: Lowest Number
I searched an hour and a half for this list I made ages ago (it got to the point where I probably would've been better off searching for my ancient yearbooks). It's 100% accurate up to and including 2002 (proof that I made this list ages ago
). Everything 2003 and beyond has been addended to the list through the years a few times, and therefore may not be 100% correct (it's still pretty accurate though).
Now: ::Copies, Pastes, Saves, goes to bed:: |
Re: Lowest Number
#7
Re: Lowest Number
. So you're right on the 1980/1981 change (and the saved list now reflects that). I'm not so sure on the other two changes though. I could've sworn they stopped at 1500 intentionally in 2004, therefore begining in 2005 at 1501. My list also gets a bit muddy on the 2003 cutoff/2004 start; I believe I tacked that on the year after the fact, and haven't been able to find anything more accurate since (we've apparently lost a lot of teams from that year). If you could show me a source or something on those two changes, it'd be appreciated. ![]() We WILL get this list accurate! ![]() |
#8
Re: Lowest Number
See team data from the FIRST site. For example, https://my.usfirst.org/myarea/index....info&team=1498
Just change the team number at the end of the line, and you'll get any team you want. I knew 1999/2000 wasn't the current split, and thought the 1500/1501 was a little too "convenient", if you know what I mean, so I went looking. |
#9
Re: Lowest Number
At least I'll have more sleep tonight... ![]() |
#10
Re: Lowest Number
Registration in 2001 stopped at 716, but began for 2002 with 800. When new registrants reached 999, FIRST began assigning numbers between 717 and 783. Team numbers 784-799 have never been assigned, as far as I'm aware. |
#11
Re: Lowest Number
that would have to be negative infinity. yup defiantly the lowest number
(wonder about the randomness i decided to just post based on title alone without reading what the actual thread was about.) |
#12
Re: Lowest Number
Re: Lowest Number
I'm fairly certain no earlier numbers were reissued to the 2002 rookies as well, but it's possible something slipped through the cracks. |
#14
Re: Lowest Number
Of course, there's always exceptions to the rule....I'm not sure on the particulars but I believe the Martians (494) team is more "experienced" than the More Martians (70) .... both are MI teams (and very good ones at that) and I'm sure somebody on CD can support/completely contradict me.
#15
Re: Lowest Number
Your concept is still true. When older teams split, the new rookie is given a low number. 22 split in 2006, forming teams 22 and 4. 64 was "retired" in 2006, and team 39 was born. Etc. |
| Lowest seed to win a regional | Cody Carey | General Forum | 12 | 02-04-2006 22:34 |
| Lowest Budget?? | Moloch | Regional Competitions | 13 | 28-03-2005 00:21 |
| Number 2 | srjjs | General Forum | 15 | 24-01-2003 08:27 |
| Number of bins? | Rob Ribaudo | Rules/Strategy | 5 | 05-01-2003 09:50 |
| 3 is the number and the number shall be 3... | Joe Johnson | General Forum | 21 | 03-12-2001 17:08 |
